03-06-2020, 02:26 AM
#16
Real Name: Pak
Real Name: Pak
Originally Posted by Crikeymike
Usually not. You're pushing it to the max with that kind of lift height, and since KDSS is limited in the rear by shock length, you wouldn't be able to have much down travel left at all.
The piston side of the sway bar contacts the panhard rod just after full extension of the Dobinsons GS59-701 rear shocks, so that's the limiting factor.
Also, I've found that over 2.5" of rear lift, the KDSS system produces a lean that can be really hard to balance out, if at all.
That said, some guys with KDSS are running some of the 3" Dobinsons rear coils. Maybe they'll chime in here with their thoughts on it, and their combination of parts too.
Thanks mike! You think there’ll be a variable spring for KDSS?!
2015 Toyota 4Runner Trail Edition/KDSS, SCS Stealth BR6, C4 rear bumper ,Relentless front bumper ,RCI under armor, 4.88 gears, dual battery, iKamper rtt
03-06-2020, 10:06 AM
#17
No plans to make any shorter height variable rate springs
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
03-06-2020, 02:27 PM
#18
Hey thanks for the feedback!
Currently I’m running the c59-729 and they are toooooo stifff.
My sig had to be updated. Sorry about that. I’m running a c4 dual swing with spare tire, skids, sliders, roof rack, rtt, taking out my drawers putting in a goose gear platform/ fridge. Even with all of this my 729s are too stiff. Is your ride really tall? I was thinking about going down to 727 but saw those variable springs but saw it was a 3” compared to a 2”. What do you think? I don’t want to loose down travel with a 3”er
I'd be hard pressed to make a recommendation for what would work best for you. Is my rig really tall? IDK I guess. My hub to fender measurement in the rear is 23.75" unloaded. I don't think that's especially tall but it's all relative. The coils did settle bout 1/2" after about a month. Your rig is most likely heavier than mine considering the RTT and the drawers. IMHO this is where you just have to play around and see what works for you. Coils are pretty easy to sell if you don't like them and are relatively easy to install. However, the variable rate coils are much taller and are a bit of work to get in.
Again, I would really defer to
@ Crikeymike
for advice specific to your setup. From the specs listed for your current coils and the 701V's it seems to me the 701V's are rated for slightly less load and are variable in addition to that so... maybe?
03-06-2020, 04:28 PM
#19
So this is normally the crossover from a 2" coil with the appropriate constant weight to a 3" coil with the Dobinsons options.
C59-325 - C59-675V
C59-327 - C59-677V
C59-329 - C59-701V
C59-331 - C59-749V
You're already running the C59-329 coils which are suitable for the weight you're carrying. I think you need to take a look at your shocks, as they might be affecting the quality of your ride.
Rear hub to fender at 2" of lift is usually right at 24", as an average.
03-06-2020, 11:39 PM
#20
Real Name: Pak
Real Name: Pak
I’m running c59-729. It is the same as 329?
C59-325 - C59-675V
C59-327 - C59-677V
C59-329 - C59-701V
C59-331 - C59-749V
03-06-2020, 11:43 PM
#21
Yes, just that 729s are offset height for kdss
Sent from my SM-G973U using Tapatalk
03-07-2020, 01:34 AM
#22
Real Name: Pak
Real Name: Pak
Thank you for all this info mike!
03-07-2020, 03:29 AM
#23
Are the TRD Pro Fox shocks at all appropriate to be running with these coils? My rig is heavy enough now that it squats a bit and I'd like to bring that rear end back up.
I am always carrying a Gobi ladder, splitting axe, 100w rigid solar panel, auxiliary battery, steel molle quarter window panels and steel shelf, and cooler. I am also a photographer who routinely also carries ~100lbs of camera gear. It adds up.
I'd rough estimate that I'm about +350lbs over the rear when loaded up, and +250lbs daily.
2020 TRD PRO - Morimoto 2 stroke LED's - KC flex pillar pods - Rigid rack pods - Goal Zero 100w panel/ Yeti 200X - Rago MOLLE panels and shelf - Thule cargo box - Gobi Ladder - Rotopax
03-07-2020, 12:49 PM
#24
looking into these suspension also. still haven't decided which one to go with just yet.
03-07-2020, 02:48 PM
#25
They are probably ok for 2" but I don't know if they're long enough to suit a 3" lift. You would have to get the specs of them or measure the amount of travel they have left from stock ride height. If the shocks aren't long enough, they will hit max extension often and wear out really fast.
03-09-2020, 12:37 PM
#26
Im looking for an option for my pig. I currently have Icon stage 7 with the curved Panhard bar for the KDSS, and OME 2899 coils. I am very heavy (Front/Rear CBI bumpers, Drawers, fridge, RTT, Gobi Rack, Etc. I started out with the Icon 2" and sagged, went to the Icon 3" Overland, and sagged. Swapped out with the DObinsons 701V, and those also sagged. I currently have the OME 2899s, but they dont flex well. What would my options be?
Thanks!
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
03-09-2020, 12:44 PM
#27
Thanks!
You got a build thread? I want to see this beast!
03-09-2020, 12:55 PM
#28
Unfortunately I dont have a build thread, but i have a bunch of pics on IG
IG: expo_t4r
IG: @Expo_T4R
04-02-2020, 06:41 PM
#29
@ Crikeymike
@ Crikeymike
- is is fair to say all of your variable rear springs will settle roughly 1/2''? I'm comparing the C59-675V vs C59-327 and if the 675V settles that much, it might not be as aggressive as it looks on paper.
04-02-2020, 08:34 PM
#30
Originally Posted by offroadarcade
@ Crikeymike
No. The lifts heights I list are the settled height with the appropriate weight on them.
People make the mistake of measuring 5 minutes after installing and before the vehicle has settled and had a chance to break in at all. It takes on average 500 miles for coils to break in and settle.
