Originally Posted by Jivewalker
You need to look at the load chart for the specific tire. My original P dunlops were rated at 2425lbs at 32psi, then derated to 2204lbs being on the light truck (4runner). Cross that over to the TAKO2's LT chart, and 44psi makes sense, 45psi would be 2255lbs.
Yes I understand that, the load chart for the oem limited 20” tire at 32 psi indicates a much lower load rating than the 265/70/17 equipped on the sr5/TRDOR/trdp.
What doesn’t make sense is that the owner of a limited t4r installing k02s will inflate them at 35 psi to match the OE 20” tire load rating, and the owner of an SR5/TRDOR/TRDP will inflate them at 44 psi to match the OE 17” tire load rating, yet as far as I know all t4rs have quite similar vehicle towing and payload capacities (the exact numbers are in my previous post).
It seems like the 265/70/17 oe tire was designed for larger vehicles with higher tire load rating requirements that far exceed those of the 4runner. Toyota would have kept the “overkill” inflation of 32 psi on the 17” tires for the sake of fuel economy, rather than out of necessity to achieve the tire’s specific load rating at that pressure.
At the end of the day, my point is that it appears that one could safely run LT265/70/17 k02s (or any other LT265/70/17) at 35 PSI as long as they don’t exceed the t4rs overall payload capacity, since the tire’s load rating exceeds the limited’s 20” tire load rating.
