Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 08-10-2017, 11:05 AM #1
boyfester's Avatar
boyfester boyfester is offline
Member
Real Name: Marc
boyfester is on a distinguished road
Member
boyfester's Avatar
Real Name: Marc
Shark fin antenna separated at rear from roof - Solutions?
I just noticed my 2014 TE antenna has separated from the roof. Any solutions?
__________________
5th Gen TE, lifted and armored
boyfester is offline   Reply With QuoteReply With Quote
Old 08-10-2017, 12:08 PM #2
DEERUNNER's Avatar
DEERUNNER DEERUNNER is offline
Member
DEERUNNER is on a distinguished road
Member
DEERUNNER's Avatar
I did that to mine when I smacked my roof-top box into it. I pushed it back down but it would not stay. You could try pushing it back down and tightening the nut that holds it. I solved the problem by replacing it with a low-profile version. This thread will explain:
Low profile XM (shark fin) antenna swap
__________________
Nearly bone-stock 2015 TRDP<paid under sticker!, TRD Supercharger, Helo 904 17x9 rims, 285/70-17 BFG KO2, BMC, MetalTech OPOR Sliders w/extension, Hella Aux Fogs, Ultragauge, Rockford Fosgate Speakers, FJC Sub Woof Box, Kicker Woof, Cheapo Boss Woof Amp, Aux Glovebox Outlet, etsy TRD hub covers, Shaved/trimmed Mud Flaps and Fenders, Cobra WX75 CB, Rear Storage Drawers, Shovel Mount, Radar, FZ-1 Fuzeblock, AVS LP Visors, Window Tint, Painted Roof Rack, Low Profile SiriusXM Antenna, Dash Cam, Exhaust Tip, Accessory Meter Mod, Some Stickers. 2008 FJ Cruiser, FJNE Member DMAND.
DEERUNNER is offline   Reply With QuoteReply With Quote
Old 08-10-2017, 12:23 PM #3
rhariz21's Avatar
rhariz21 rhariz21 is offline
Junior Member
rhariz21 is on a distinguished road
Junior Member
rhariz21's Avatar
i just picked up an 11 that has the same problem! i think mine was hit as well since there are some scrapes on the "spoiler".
rhariz21 is offline   Reply With QuoteReply With Quote
Old 08-10-2017, 09:59 PM #4
boyfester's Avatar
Member
Real Name: Marc
Member
boyfester's Avatar
Real Name: Marc
How do you access the "nut" to tighten? Is it under the plastic fin cover?
__________________
Old 08-11-2017, 08:34 AM #5
DEERUNNER's Avatar
Member
Member
DEERUNNER's Avatar
Quote:
One has to pull down the headliner at the rear. Remove the snap buttons, carefully pull it down a bit, and reach in there and tighten the nut. It is a tight fit, take your time and you will not crease the headliner. As stated above, this did not work for me, the roof metal was bent a bit right at the spot where the nut goes through the roof. You may have done the same thing. I flattened it when I installed the low profile antenna. You may have to remove the antenna nut, lift the antenna, and bend the roof flat as I did.
4funnr posted some good instructions:
http://www.toyota-4runner.org/2717528-post112.html
__________________
Old 08-12-2017, 04:01 PM #6
boyfester's Avatar
Member
Real Name: Marc
Member
boyfester's Avatar
Real Name: Marc
So I tightened up the nut and nothing happened. I have now realized that it is the antenna gasket's adhesive that has caused it pop up. The roof line isn't bent. I added some Liquid Nails between the gasket and roof and put some wood on top for weight. I'll let it dry today and check it tomorrow.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Low profile XM (shark fin) antenna swap weeeee 5th gen T4Rs 241 05-16-2023 08:15 PM
How do I remove shark fin antenna from 2010 4runner? GoneSurfing 5th gen T4Rs 16 07-13-2017 02:52 PM
Tap into shark fin roof XM antenna 38vn38fa 5th gen T4Rs 6 04-15-2015 09:55 PM
Where can I get the Shark fin antenna? Tuge 5th gen T4Rs 7 01-04-2015 03:32 PM
Diversity Antenna solutions WaterMan Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-21-2007 10:41 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
