Originally Posted by boyfester
How do you access the "nut" to tighten? Is it under the plastic fin cover?
One has to pull down the headliner at the rear. Remove the snap buttons, carefully pull it down a bit, and reach in there and tighten the nut. It is a tight fit, take your time and you will not crease the headliner. As stated above, this did not work for me, the roof metal was bent a bit right at the spot where the nut goes through the roof. You may have done the same thing. I flattened it when I installed the low profile antenna. You may have to remove the antenna nut, lift the antenna, and bend the roof flat as I did.
4funnr posted some good instructions:
http://www.toyota-4runner.org/2717528-post112.html
Nearly bone-stock 2015 TRDP<paid under sticker!, TRD Supercharger, Helo 904 17x9 rims, 285/70-17 BFG KO2, BMC, MetalTech OPOR Sliders w/extension, Hella Aux Fogs, Ultragauge, Rockford Fosgate Speakers, FJC Sub Woof Box, Kicker Woof, Cheapo Boss Woof Amp, Aux Glovebox Outlet, etsy TRD hub covers, Shaved/trimmed Mud Flaps and Fenders, Cobra WX75 CB, Rear Storage Drawers, Shovel Mount, Radar, FZ-1 Fuzeblock, AVS LP Visors, Window Tint, Painted Roof Rack, Low Profile SiriusXM Antenna, Dash Cam, Exhaust Tip, Accessory Meter Mod, Some Stickers. 2008 FJ Cruiser, FJNE Member DMAND.
Reason: added link
