Old 08-21-2017, 09:12 AM #1
eddie333's Avatar
eddie333 eddie333 is offline
eddie333 is on a distinguished road
eddie333's Avatar
Looking for input on rear bumpers due to damage
Well it finally happened. After using my 4Runner for long overlanding journeys, off-roading, camping, logging, hunting and farming, I ran into something.
I dented the rear bumper on the bottom left and the clips all broke around the left rear wheel-well and along the rear fender leading to the taillight.
Due to needing to fix it, I am contemplating replacing with an aftermarket bumper.
I understand most rear bumpers require cutting of the factory bumper. If I was to get one, I am assuming the factory bumper would still need to get repaired first to add the aftermarket one? I'm looking for suggestions from those with aftermarket rear bumpers what my best course of action might be.
Thank you!
2013 4Runner Limited - (17" Level-8 Bronze MK6, 265/70/17 Duratracs, ToyTec Ultimate 3/2 Suspension, Baja Long Rack, Shrockworks Front Bumper, Smittybuilt XRC Winch, Shrockworks Sliders/Trim Kit, Gobi ladder, LED Reverse and side lights, Cobra CB, Dual Isolated Odyssey Extreme Batteries, On-Board Air Compressor, ARB Awning & Room, Rooftop tent)
eddie333 is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 09:33 AM #2
ECUDrummer's Avatar
ECUDrummer ECUDrummer is offline
Real Name: Andrew
ECUDrummer will become famous soon enough
ECUDrummer's Avatar
Real Name: Andrew
Look at CBI if you don't mind cutting. Not sure where your damage is specifically, but you cut a good deal out of the bumper to make it fit. They make an excellent product.
Expedition One is newer for the 5th gens, but from the looks of things you'll still need to cut.
Shrockworks and Hefty Fab both require cutting.
4x4 labs makes a great product that doesn't involve cutting, but it'll cost a pretty penny.
2013 Trail MGM
Drummer's Adventure Thread
Instagram - @1988coPhotos / @HoppyTrailsOverland
ECUDrummer is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 01:30 PM #3
eddie333's Avatar
eddie333's Avatar
Thanks for the input. This is what I am working with:
Looking for input on rear bumpers due to damage-img-7798-jpg  Looking for input on rear bumpers due to damage-img-7795-jpg
Old 08-21-2017, 01:43 PM #4
bimrunner's Avatar
bimrunner bimrunner is offline
Real Name: Ben
bimrunner is on a distinguished road
bimrunner's Avatar
Real Name: Ben
FYI, the labs bumper is awesome, but it does require cutting - but not the bumper cover. The labs bumper cuts out the entire rear cross-member and has a new one integrated into the bumper itself. Not less work - more. Gives absolute max departure angle you can get but you need to be happy cutting up structural metal. I did that surgery at 10k on the odometer... not for the faint of heart!
2013 LE, All Pro +2 LT Front, CVJ axles, King shocks, Califab rear links, Hutchinson beadlocks, Nitto Trail Grappler 35x12.5x17, 4x4 Labs rear bumper and front bumper and sliders, tints, Bajarack, RCI skids, 4.56 gears and ARB lockers/Compressor, Rigid Lights, Rydeen 360 camera system, KK6JZH...Keeping it mild Build & Pics
bimrunner is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 02:19 PM #5
(none) (none) is offline
(none) is on a distinguished road
are you sure you broke the clips? They pop out of place pretty easily. Try lining it back up and whacking it back in place with the palm of your hand.
2016 Trail and half of an early 90s Ford Ranger
(none) is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 03:15 PM #6
ECUDrummer's Avatar
Real Name: Andrew
ECUDrummer's Avatar
Real Name: Andrew
My bad, completely forgot about the crossmember.
2013 Trail MGM
Old 08-21-2017, 03:44 PM #7
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
simplest approach is to throw on a 2014 + cover. It results in better clearance and has 0 downsides besides still being vulnerable to damage.
Any steel bumper is going to totally screw with the weight distribution and you will need to modify the suspension to accommodate it. The lightest rear bumper out there will be the aluminum heftyfabworks... but be prepared to pay big $$s and wait a long time for it.
Another option is to cut your existing cover and get some tubes bent by a decent fab shop to form something that still looks good and provides the needed protection. Do a google search for "5th gen 4runner minimalist rear bumper" for some ideas... You will see mine. I have wheeled my 5th gen in very difficult terrain and smashed it many times with 0 damage. In fact a guy I go with often has the 4x4 labs. He has slightly better straight on departure, but in practice he hits just as much as I do and we both come out fine. The rear hitch protects the center section just fine for straight on stuff. It's the corners that are the main issue (as you have seen).
The limiteds and 2010-2013 non-trails had really bad clearance in the rear corners. The others are tolerable...
wfo9 is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 05:31 PM #8
LimitBreaker's Avatar
LimitBreaker LimitBreaker is offline
LimitBreaker is on a distinguished road
Randomly, I will be replacing my blizzard white 5th gen rear bumper soon and will need to get rid of the stock bumper... but I'm in the Pacific Northwest which I think might be far from you.
LimitBreaker is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 06:23 PM #9
SenorColdOnes's Avatar
SenorColdOnes SenorColdOnes is offline
Real Name: Brent
SenorColdOnes is on a distinguished road
Real Name: Brent
We have an almost identical (damaged) bumper!
I've always wondered if removing the bumper and applying a heat gun treatment to it would push out the small dent. Anyone done this and found it did the trick? I don't want to damage the clearcoat. Anyway, this might be the impetus I need to fix my own damn bumper!
2015 Mag Grey 4Stunner // just getting started
SenorColdOnes is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 07:01 PM #10
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
I did the same thing to my 2016 Trail in June. I removed the bumper and popped the dented corner out under foot pressure. The bumper side clips didn't break, but the valance ones did. I had to affix the valance with an external screw, which is kind of kludgey, but it works. The correct solution requires replacing the valance, but I figure this won't be the last time I bang it up off road, so I'm leaving it for now. Good enough.
Looking for input on rear bumpers due to damage-170614_bb_006-jpg  Looking for input on rear bumpers due to damage-170614_bb_007-jpg
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 08:02 PM #11
flea1983 flea1983 is offline
flea1983 is on a distinguished road
I did the same, used a heat gun and a wooden block to push the dent out, didn't have to take it off. Unfortunately my clips are broken also. I've found a trail bumper cover online for about 200 unpainted, does anyone know if it will match up with a limited?
Edit: I used the low setting on the heat gun and didn't leave it in one place too long, tried to slowly bring it up to temp so I didn't melt it.
flea1983 is offline   Reply With QuoteReply With Quote
Old 08-22-2017, 12:54 PM #12
TE! TE! is offline
TE! is on a distinguished road
TE! TE! is offline
Love my aluminum Hefty fabs front and rear. Had no use or purpose for a tire carrier or swingarms... due to the amount of times I open my rear hatch and parking/ garage clearance issues where I live.
I can still fit a full size 285 duratrac underneath and it also came with a high clearance hitch. To get both front and rear bumpers took about 10 weeks. Well worth the wait and quality is top notch!!
[IMG][/IMG]
SOLD- 2016 TEP Super White, TC +2 LT w/ Kings, TC UCA's, Hefty Alu front & rear bumpers, Rigid SR30, Warn Platinum 10-S, FRO 3/4 extended, RCI Alu skids, SCS F5's, RRO Supersliders, Duratracs, OEM Audio Plus Reference 450Q, Trekboxx Alpha Storage.
SOLD -2011 TE, OME suspension, TC UCA's, 4x4 Labs front bumper, VR10,000s winch, Rigid lights, Level 8 MK6, 285/70/17 Duratracs, OPOR sliders, 2014 headlight conversion.
TE! is offline   Reply With QuoteReply With Quote
Old 08-22-2017, 07:03 PM #13
CoolMax's Avatar
CoolMax CoolMax is offline
CoolMax will become famous soon enough
CoolMax's Avatar
How does an aftermarket bumper solve the issue with the clips?
2013 Classic Silver Metallic Trail Edition w/ KDSS
CoolMax is offline   Reply With QuoteReply With Quote
RTE Fabrication building new bumpers for 5th Gen - they're asking for input Land_Shark 5th gen T4Rs 29 12-22-2014 05:53 PM
Rear body damage on 2nd gen 95. walrusmt Classic T4Rs 30 08-22-2014 09:00 AM
Rear Bumper Damage pb&j 3rd gen T4Rs 13 08-10-2014 04:50 PM
Got Rear Ended. Possible Damage?? Jyn 4th Gen T4Rs 8 08-22-2013 12:14 PM
Rear Ended, Hitch Receiver Damage --> Frame Damage? osuchasenuts 3rd gen T4Rs 5 12-01-2010 08:16 PM
