I always scoffed at people with dash cams in their cars. After four close calls in two weeks I may have changed my mind on them.
I think I've settled on the Rexing V1 Car Dash Cam form Amazon. For $100 on Amazon Prime it looks like a solid cam. There are also option with a GPS logger, but I'm not sure if I want that data recorded or not. There is also an option for a rear facing cam, but I'm not sure if that would work unless I got an external cam.
I think the Rexing V1 should fit in front of the rear view mirror and hide it from internal view.
I would like to power the Rexing V1 from the overhead console or other switched location and not from the 12v outlet. I'm thinking there may be a wire I could tap in the overhead console. Another option may be to use an add-a-circuit on the power outlet fuse (under the dash)
I would like to hear any experiences with the Rexing V1 and how the setup went.
Install Video
Dash Cam install - Rexing V1- 2015 Toyota 4runner
https://www.youtube.com/watch?v=nqohxc9ZCsI
Rexing V1
https://www.amazon.com/V1-Dashboard-.../dp/B00X528FNE
Products | Rexing Dash Cam
Rexing Hard Wire Kit Mini-USB Port
https://www.amazon.com/Rexing-Hard-W.../dp/B01LXC2329
