11-17-2020, 11:01 AM
#16
2016 TEP w/ KDSS... Nokian Rotiiva LT285/70R17 fits in spare cave no problem.
11-17-2020, 11:10 AM
#17
2017 ORP 285/70/17 Discount Tire Pathfinder no issues.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
11-17-2020, 05:58 PM
#18
Same but a 2021 ORP.
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
11-18-2020, 09:26 PM
#19
Took a look underneath my truck today. There is room in front but the tire presses against the hitch. I may air it down a bit. Guessing if my tire was a matching General Grabber or a mud terrain it may not work.
On a side note, no trimming was required in front. I have a 2.5" lift and the clearance was good.
11-18-2020, 09:34 PM
#20
I fit a Falken MT01 in the back without airing it down. Bit tight near the sway bar but it fits!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
11-18-2020, 09:40 PM
#21
Banned
Real Name: Tobias Fünke
Banned
Mine fits in there no problem but I lost one of my
@ Antman
cupholders :/
11-19-2020, 02:52 PM
#22
Your first picture is timely as I'm aiming to get under the truck today and put up/in the new KO2 33" - great reference. Thanks!
Already Gone.
11-19-2020, 08:57 PM
#23
Update for those who need to know:
2019 w/KDSS - 285/70/17 KO2 on Method 703 fits in the spare well without need for modifications. It's close on the KDSS, about 1/2", but no issue if you set the back and tighten it up/upward properly.
Already Gone.
01-19-2021, 06:38 PM
#24
Real Name: Kelly
Real Name: Kelly
Just got back from the tire shop and i have a Falken WP 285 up there and it fits.
The shop kept telling me it was not gonna fit but I told them do it anyways, and of course it fits. And they had it at 42psi. It does touch the tow hitch on the back side so I will lower pressure down to maybe ~30 and readjust to see if I can get it to clear.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
01-20-2021, 01:01 AM
#25
Real Name: BLACK TRD PRO
Congrats on the AT3W WP’s. Pics? Did you go E, C or SL? Thinking you got E load if they aired it up to 42psi. I had no problems with my 285 in the spare area, but, I do not have KDSS.
01-21-2021, 02:46 AM
#26
all of this is good timing for me, great thread!
question for everyone, when you replaced the stock spare with your aftermarket spares, how many of you also replace the stock spare wheel?
My wife smashed a curb and so one of the new (3 weeks old) black wheels has a deep gash on it. I got quite angry, so she immediately ordered a replacement and said we could use the ****ed up wheel for the spare.
Wondering if I should take this opportunity to finally get an aftermarket spare tire to put on the "new" spare wheel or if I should just get the wheel repaired and only get the aftermarket tire, stick it on the stock spare wheel and cancel the new wheel order to save some money.
Wanted to know what you guys do. new wheel with new spare tire or just stick to stock wheel with new spare tire?
cheers!
01-21-2021, 03:37 AM
#27
Currently running a 285/70/17 falken wildpeak at3w in the stock spare location mounted on a 17x8.5 0 offset wheel. Tight fit, but it fits.
01-21-2021, 03:59 AM
#28
cheers!
really up to you..no wrong way to do it, as long as your spare tire size matches your other 4 tires, you can choose whatever rim you want under there.
I'm a cheap bastard so I stuck with my spare tire rim and mounted 285's on it and call it a day. To me its a insurance policy and I treat it as such.
If you buy a matching rim, you can use your spare tire in your tire rotation schedule if thats your thing.
01-21-2021, 04:19 AM
#29
Thanks for the input!
I was thinking about the tire rotation myself, only thing is, I'd be rotating the damaged spare rim into the mix, which means the damaged rim would be visible, which is why she ordered a replacement to begin with.
Gah! I'm cheap too, which is why I'm leaning towards just getting it repaired and just slap a new spare tire on the stock spare wheel. It's just that I'll know in my heart the wheel has been damaged and that makes my OCD go f'ing mad, but again, I'm cheap....
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
