Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 08-27-2020, 12:58 AM #31
aviators's Avatar
aviators aviators is offline
aviators is on a distinguished road
aviators's Avatar
Tires with Rough Country Kit
Originally Posted by sawman1 View Post
Finally installed the 2" front, 1" rear spacer lift & had aligned. Love the height and look now, perfect for me.
What size tires are you running with the Rough Country Kit? Thanks.
2011 Limited w/ Nav and 3rd row | FJ wheels with P265/70-17 Cooper A/T3s | OPOR sliders | front tint | stubby antenna
aviators is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 10:38 AM #32
sawman1's Avatar
sawman1 sawman1 is offline
sawman1 is on a distinguished road
sawman1's Avatar
I am running 275/70/17 BFG KO2's on Black Rhino Sierra wheels, 17"x 9"
sawman1 is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 11:05 AM #33
Tonka23 Tonka23 is offline
Tonka23 is on a distinguished road
anyone running this with the stock 20 wheels?
Tonka23 is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 11:39 AM #34
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
I’m running 1.75”/1” with stock 20’s if that helps?
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 09:46 AM #35
Stock tire size?? Just wondering since im going through the classic cant pull the trigger on spacers because I get in my head about the ride vs. just ponyin up the extra 750-1k for a proper kit....
and yes it will be a pavement princess for the mrs so might just be overthinking it...
Old 09-19-2020, 01:27 AM #36
tundradan tundradan is offline
tundradan is on a distinguished road
Curious what the benefits of a lift is other than cosmetic? It doesn't give you any greater ground clearance unless you get bigger tires and then you may only get an inch or so.
The reason I ask is that it seems that it will effect drivability due to raising the center of gravity and also aerodynamics. Is there any truth to this, or am I just making stuff up again?
tundradan is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 06:23 PM #37
J-Roc's Avatar
Real Name: J
J-Roc's Avatar
Real Name: J
275/55/20 is what I’m running. Put those on before the lift...
Now, of course, I want to go bigger.
Old 09-23-2020, 09:03 AM #38
No issues with rubbing at stock height???
Old 09-27-2020, 08:28 PM #39
J-Roc's Avatar
Real Name: J
J-Roc's Avatar
Real Name: J
5th Gen Limited w/XREAS - Level?
No issues at all with rubbing.
Old 11-02-2020, 03:44 PM #40
DLite93 DLite93 is offline
DLite93 is on a distinguished road
Originally Posted by nolugs View Post
Just did mine last month. 2.5/1.5 Daystar, Nitto Terra Grappler 275/55/20 on Fuel Hardline wheels. Drives pretty close to stock. Little bit of rubbing on plastic inner fender liner at the left front at full right lock when reversing. Have not gone under to see what I can do about it yet. I'm enjoying how it looks.
http://www.toyota-4runner.org/member...6-dsc-1005.jpg
New here, and bringing this up again. As I have scoured the internet for how to video's on a level/ lift install be it Toytec, Revtek, Daystar, or Cornfed on a 5th generation 4runner with Xreas I continue to come up empty handed. For those of you who have completed a lift or level on an XREAS equipped 4Runner... are you guys compressing the coil inside the wheel well? I have downloaded the instructions for a Revtek 2.5 front/ 1.5 rear... but a visual aid sure would be helpful. Anyone know of a how to video out there?
DLite93 is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 06:14 PM #41
DonnieD DonnieD is offline
Real Name: Donnie Dunn
DonnieD is on a distinguished road
Revtek Spacer Lift 2019 Limited
I just added the Revtek 3" front 2" Rear spacer lift to my 2019 Nightshade Limited and I am digging it, well once I was used to the slightly different handling.
Imgur: The magic of the Internet
DonnieD is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 12:17 PM #42
sawman1's Avatar
sawman1's Avatar
This is what I used to install mine:
https://s3.amazonaws.com/roughcountr...l/92176700.pdf
Old 11-11-2020, 10:18 PM #43
seLect seLect is offline
seLect is on a distinguished road
Originally Posted by Gecko View Post
Is there some reason why the 4Runner suspension is set up like it is, with the downward facing dog front end?
Think it has to do with weight distribution of the engine layout...could be wrong, though.
2018 4Runner Blizzard Pearl
seLect is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 10:56 PM #44
ken4r17 ken4r17 is offline
ken4r17 is on a distinguished road
can you post pic? and did you upgrade tires?
ken4r17 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 06:03 PM #45
sawman1's Avatar
sawman1's Avatar
Me too! Well, almost. I can't leave well enough alone. I removed the 2" front spacer and installed the Revtek 3" front preload spacer. I left the 1" rear in the back. It sits level. Pics attached (4R is parked just slightly uphill).
5th Gen Limited w/XREAS - Level?-img_2643-1-jpg  5th Gen Limited w/XREAS - Level?-img_2644-jpg
leveling kit , lift , limited , mods , xreas
Spacer Lift or Level, 2005 Sport 4WD with XREAS mschwep-05sport 4th Gen T4Rs 13 01-23-2015 12:22 PM
Daystar 2.5/1.5 Level Kit with XREAS igarrpan 4th Gen T4Rs 6 11-28-2013 01:27 PM
Level with XREAS-POSSIBLE? kai920 4th Gen T4Rs 14 02-18-2011 11:46 AM
Not level in rear - XREAS wolfgang Problems & Warranty Issues 2 10-17-2010 10:02 PM
Truxxx 3" level kit for Xreas tenguns 4th Gen T4Rs 1 05-01-2009 08:55 PM
