Old 03-17-2021, 01:00 PM #76
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Here's my .02
Let's start at the beginning. Packaging arrived much like one would expect from the "no ducks given" service sector.
Hood protector/ Bug deflector recommendations-20210316_195752_resized-jpg  Hood protector/ Bug deflector recommendations-20210316_195824_resized-jpg
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 01:02 PM #77
Charlievee's Avatar
Charlievee's Avatar
Hood spacing was 3/16" ( battery died in the calipers, excuse the primitive measuring devices).
Hood protector/ Bug deflector recommendations-20210317_110040_resized-jpg  Hood protector/ Bug deflector recommendations-20210317_114257_resized-jpg
Old 03-17-2021, 01:06 PM #78
Charlievee's Avatar
Charlievee's Avatar
Install is Barney enough, noticed contact with the paint at the bottom of the leading edge and added the supplied bumpers to the under side of the hood (just the two over the headlights. Center section doesn't have the clearance).
Hood protector/ Bug deflector recommendations-20210317_111157_resized-jpg  Hood protector/ Bug deflector recommendations-20210317_112338_resized-jpg
Old 03-17-2021, 01:12 PM #79
Charlievee's Avatar
Charlievee's Avatar
Next point of contact was the bug shield hitting the upper valence of the grill. I was able to adjust it so it barely cleared, but with the slight "wave" in both the valence and bug shield, contact is still likely. So, i added some clear Vinyl wrap to the back edge. Will most likly do the same with the leading edge of the hood, in the future. We'll see how it works out. All in all about 20 minutes of "hard" labor. No issues with the hood closing, i run the bump stops kind of high to help with rattles and such, so dropping it to close is normal for me. Hope this helps someone.
Hood protector/ Bug deflector recommendations-20210317_114103_resized-jpg
Old 03-17-2021, 03:52 PM #80
dandiBran dandiBran is offline
dandiBran is on a distinguished road
has anyone with the deflectors had issues with frequent cracks/chips in the windshield? in comparison to before installing it? i've went through 2 windshields in a month this winter in PA-both caused by road salt. already have concerns with paint chips on the hood and now the windshield. after reading this thread, i'm wondering if a deflector would help. thoughts?
dandiBran is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 04:02 PM #81
Charlievee's Avatar
Charlievee's Avatar
I just put mine on, but doubt anything large enough to crack the windscreen would be affected by the change in the slip stream.
Old 03-17-2021, 04:22 PM #82
VENTURE21 VENTURE21 is offline
VENTURE21 is on a distinguished road
Can you post a side shot of the hood and fender with the hood closed? I like to see how far up the hood is from the fender. Mine may have had a mold issue. Mine was tight all the way across the grill. Thanks for the informative post.
21 Silver Venture
18 Cement Tundra
04 TJ Rubicon
VENTURE21 is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 04:34 PM #83
Charlievee's Avatar
Charlievee's Avatar
It looks off in the pic, do to the angle and in truth the hood may be a "c hair" taller (feels it when i ran my hand over it). If it was noticeable, i would of added a fender shim.
Old 03-17-2021, 04:42 PM #84
Charlievee's Avatar
Charlievee's Avatar
Not sure if these are better. It's not perfect, but i don't think the body lines are any worse then factory tolerances on these station wagons.
Hood protector/ Bug deflector recommendations-20210317_153545_resized-jpg
Old 03-17-2021, 04:51 PM #85
Mr Rutherford's Avatar
Mr Rutherford Mr Rutherford is offline
Real Name: Sir Reginald Featherbottom Rutherford III
Mr Rutherford is on a distinguished road
Amazon.com: Auto Ventshade 23071 Bugflector Dark Smoke Hood Shield for 2010-2019 Toyota 4Runner: Automotive
This is one I got and I love the way it looks, its not flush with the hood but its not tall either.
Mr Rutherford is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 05:05 PM #86
numbay numbay is offline
numbay will become famous soon enough
Thats the one I bought too!
numbay is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 06:05 PM #87
Looking right above headlight I can see it's up a tad.. Looks far better than expected. You would have seen the edge of the hood how mine fit. I now know that it can fit. Thanks
21 Silver Venture
18 Cement Tundra
04 TJ Rubicon
Old 05-12-2024, 09:14 PM #88
CSM-101's Avatar
CSM-101 CSM-101 is offline
CSM-101 is on a distinguished road
CSM-101's Avatar
Hello Everyone,
My 4Runner got into an accident, some front end damage and I have been trying to get the OEM Toyota hood deflector (PN: PT427-89100) to replace the one I had on my 4Runner, does anyone know if someplace has it in stock? I have search all over the internet and there seems that no one has it in stock. Is Toyota not making them anymore? It would be grateful if someone can provide any help in this.
CSM-101 is offline   Reply With QuoteReply With Quote
FS: 2003-2005 4Runner Hood Protector / Bug Deflector - San Diego, CA. grantprior13 For Sale: T4R Items 2 03-01-2017 11:17 AM
Hood protector. progress4m 4th Gen T4Rs 0 11-20-2008 10:15 AM
hood not latching after hood protector installed kronah 3rd gen T4Rs 4 08-11-2006 02:35 PM
WTB: Bug deflector/hood protector jev2022 Want to Buy/Trade 0 06-14-2006 02:37 PM
