11-15-2018, 12:10 AM
#16
If anyone can a pic of the hose clamp fix would be great. It's been minor, but now that it's colder it's louder.
2015 SR5 Barcelona Red, Icon Lift, Icon Delta Joint UCA's, Falken Wild Peak AT3W's LT285/75R17, Warn Semi-Hidden Winch Bumper, Smittybilt Gen2 X20 10K Synthetic Winch, RCI Aluminum Skids, Shrockworks Dimpled Tread Sliders, Boss 4R Strongbox, OCD Rear Sway Bar Links, Rad Rubber Liners, ARB Rear Diff Breather, Airaid MXP Cold Air Intake, Airaid Superaid Throttle Body Spacer, Blackout Badge Kit, AVS Bugflector II, & WeatherTech Floor Liners.
11-15-2018, 12:35 AM
#17
no pic, but you literally take a hose clamp and you put it around the entire rubber hanger, and as you tighten the clamp down, it raises the rubber hanger, and exhaust pipe.
It literally takes 5 minutes to fix and about 3 dollars.
Sorry, no pics, but once you look under your car, it will make sense.
11-15-2018, 01:07 AM
#18
Found this when googling.
Originally Posted by Jdavera
Worked nice !!
Looks like folks are using this clamp
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
11-15-2018, 01:20 AM
#19
Happily stumbled upon this as I have a rattle that has surfaced recently. Loudest at idle or stopped in gear. Going to check it right now!
I drive a TruckUV
'11 T.E. KDSS SS 3/2" lift, cooper at/3s, sleekster sliders, baja racks utility rack & ladder, new piece of bumper plastic
11-15-2018, 03:13 PM
#20
Perfect Thanks
11-15-2018, 03:52 PM
#21
Yea, same here. Doesn't rattle every time, but when it does it is at idle with a colder temperature. Thanks for the clamp pics!
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
11-15-2018, 06:16 PM
#22
Real Name: Kevin
Real Name: Kevin
I guess I'll find out soon if it is an issue, mine is supposed to be delivered today. Although my exhaust has been "clearanced" a little so maybe it won't be a problem.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
11-15-2018, 09:40 PM
#23
Please let us know when you have it installed.
I just bought a full skid plate package with the group buy and verified through some connections that a recent install with a 5th gen doesn't rattle or rub.
I'm sure I'll find out soon enough when I go to install, and knowing all the parts I might need to have on hand before starting the install.
Glad there are solutions for everyone though, that's a good thing to know it can be fixed.
11-16-2018, 01:45 AM
#24
I have heard about a option to reroute exhaust and gain a bit of clearance. Anybody has a reference I could show to a local muffler shop?
11-16-2018, 10:44 AM
#25
Did they fix this with their new versions?
I don’t think I’ve noticed any sounds on
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
11-16-2018, 10:51 PM
#26
I was talking about an option that another skid plate maker quotes that this pipe can be moved up, and skid plate moved up a whole inch.
11-19-2018, 01:12 PM
#27
Real Name: Kevin
Real Name: Kevin
RCI transfer case skid contacts exhaust 😞
Mine ended up with about 1/4" or so clearance. I went out wheeling after install and never heard any noise from it.
On a side note, the rubber mount on mine doesn't appear as stretched out at the one in the pics on how to fix it with a hose clamp.
01-08-2019, 09:50 PM
#28
Originally Posted by wfo9
Super common problem with a 50 cent fix. Put a hose clamp over the rubber isolator and tighten it enough to stop the rubbing. Include a zip tie in case it ever slips off. No need to tighten much.
Moving the exhaust will cost way more. I eventually did that because I wanted to raise the t-case skid up an inch...
That's what I did as per your post and it has worked great.
So I can add yet another confirmation that this works very well. I have used that skid plate many times already, as BO angle is the rig's weakest spot, and there is still no noise with the clamp in place.
01-08-2019, 10:02 PM
#29
It’s funny, I didn’t notice any sounds initially, but after getting stuck in the mud pretty badly now I notice lots of rattle. It must have pushed the skid plate up a bit or something. Either way, I’ll try one of these fixes....
02-17-2020, 06:40 PM
#30
Just a heads up that RCI now ships their 5th Gen T4R transfer case skidplates with small spacers that are big enough to avoid this very problem.
I don't mind at all that I'll have 1/8"-1/4" less ground clearance in this area if it means not having to do any additional mods to prevent potential exhaust rattle.
Happy offroading.
