10-05-2017, 12:57 PM
RCI transfer case skid contacts exhaust :(
Noticed a different sound when driving, looked under, saw it.
Going to have to get the exhaust moved.
10-05-2017, 01:05 PM
Super common problem with a 50 cent fix. Put a hose clamp over the rubber isolator and tighten it enough to stop the rubbing. Include a zip tie in case it ever slips off. No need to tighten much.
Moving the exhaust will cost way more. I eventually did that because I wanted to raise the t-case skid up an inch...
10-05-2017, 01:28 PM
Thanks!
10-05-2017, 03:52 PM
Might also wrap that section of pipe in some heat wrap? It would cut down on the clanking in case the hose clamp comes lose or isnt tight enough.
I saw this issue as well last night installing my skids. I ended up waiting to install the transfer skid to think through a solution.
10-05-2017, 04:56 PM
Real Name: Ben
Real Name: Ben
I've been planning to do the hose clamp fix for quite a while. I guess it must not bother me as much as I pretend because I've had a vibration for about 4 years and still haven't done it. I have replaced that skid a couple times when I've bashed it up mercilessly.
Edit: decided enough is enough and ran out (working from home), threw a worm driven clamp on there that I had (nice stainless with rounded edges so I don't cut into the isolator). Cranked it down... moved the exhaust up off skid. Now I need to drive... thanks as always
@ wfo9
for the reminder!
2013 LE, All Pro +2 LT Front, CVJ axles, King shocks, Califab rear links, Hutchinson beadlocks, Nitto Trail Grappler 35x12.5x17, 4x4 Labs rear bumper and front bumper and sliders, tints, Bajarack, RCI skids, 4.56 gears and ARB lockers/Compressor, Rigid Lights, Rydeen 360 camera system, KK6JZH...Keeping it mild Build & Pics
10-05-2017, 06:09 PM
Man
@ wfo9
you are really delivering these days. I had this problem as well and ended up putting spacers on the skid plate bolts to drop them down just enough. Will try this trick next!
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
10-05-2017, 06:55 PM
Good to know as I am thinking about these skids. This forum is an incredible wealth of knowledge and information.
10-05-2017, 07:54 PM
Wrapped mine in exhaust wrap from O'Reillys before I installed mine. No more noise of clanking but I can feel it vibrate (only when in reverse for some reason). Will also be doing the hose clamp mod at some point to alleviate this.
2016 SR5P 4x4 Nautical Blue Nitto Ridge Grappler 285/75R17 ~ Stealth Custom Series SR8 ~ King Racing 2.5's ~ RCI Skids ~ Pelfreybilt Hidden Winch Mount Use "T4RZAN" at Rago Fabrication for 10% off Keep up with my adventures on Instagram: @_jacksonjenkins
10-05-2017, 08:40 PM
Could you give the frame hook for the isolater a whack and maybe pull the exhaust up while still keeping it vibe free?
10-05-2017, 08:50 PM
Real Name: Chris
Real Name: Chris
Mine's been on for over 6 years. You want to hear skid and exhaust piping contact?! lol
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
10-05-2017, 10:39 PM
I biased the cross-member downward when installing that skid and wrapped the exhaust in exhaust wrap--no noise.
10-05-2017, 11:17 PM
This is a handy piece of information, I order a skid plate kit on the RCI group buy and when they come in I'm sure I would've been 🤦🏻*♂️
So thanks in advance!!
11-14-2018, 09:16 PM
Any references on how that is done.
11-14-2018, 10:25 PM
I have wrapped many exhausts on previously owned cars and motorcycles. Just know that exhaust wrap holds in moisture and leads to extremely premature rusting of the pipe underneath the wrap. I learned the hard way on my old Subaru that I wrapped the downpipe after the turbo on, thing was basically rotting underneath. You can google "exhaust wrap rust underneath" and see plenty of picture examples.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
11-14-2018, 11:08 PM
Thank you for the heads up. It definitely makes sense.
