10-18-2017, 10:26 AM
#46
Originally Posted by matoolie
I did a little more research here and it appears the 5th gens do not have TPMS in the spare tires, but the #5 TPMS is in the ECU. Would be good to have for those of use who replace wheels/tires with 5 new ones where all 5 wheels have TPMS and would like to monitor pressure in the spare.
However......our sensors also transmit tire temps (see screenshot below). If you are updating the software for pressure, can temperature also be investigated or added? Just a thought.
Shipped out my ScanGauge II today for update.
Ill be testing the temp code today and will let you know!
2016 Trail Premium | F: King 2.5 RR Ext | Rear: Icon 2.0 w/ Dobinson Coils | JBA UCA's | FN F(X)Pro Wheels Matte Black | Nitto Ridge Grappler 285/70/17 | Coastal Offroad Front & Rear Bumper | RCI Aluminum Skids | RSG Angled Sliders | Xenon HID | S-Tech Custom 6 Switch Housing
10-19-2017, 11:54 PM
#47
Tested my re-imaged Scanguage II today. I had put in the mail last Thursday using regular snail non-priority mail. Got it back yesterday (Wednesday) in a USPS Priority box and very will protected. It was probably better protected than in what I sent them.
All settings were reset back to factory, so be prepared to lose your pre-existing data and renter the settings for your particular vehicle upon first booting up.
New firmware comes with two possible sets of xguages (TP1 through TP5 and TM1 through TM5). There was a note asking to email back with which set reports a reading.
@ ScanGauge
the set that worked on my 2013 4Runner LE was TM. The TP set didn't read anything. As mentioned in post above, TM5 for the spare doesn't report back a reading because my spare doesn't have a TPMS gauge.
It takes up to 20~30 seconds for all 4 gauges to register with the first one registering in only a few seconds. They read a negative number for a while and then start to show the correct reading. The pressure readings increase as the tires warm up as expected. They showed about 2 psi less than my hand held mechanical tire pressure gauge. Not sure which one is right but I think my hand held gauge is a cheap-o so my bet is on the Scanguage.
The Scanguage says one of my tires was a couple pounds less than the rest which was exactly the kind of information I wanted to know. Very happy with the quick turnaround and extra functionality. Thanks again!
PS -
@ ScanGauge
which number represents which tire? I guess I could go out and test with my mechanical gauge but its dark outside.
I am guessing:
TM1 - Driver Front
TM2 - Passenger Front
TM3 - Driver Rear
TM4 - Passenger Rear
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
10-20-2017, 06:11 PM
#48
Cool! Thanks!
Once we get our updated units back, will the pressure XGauges already be programmed in as part of new software? Or will we need to get codes from you and enter them ourselves? You guys will be getting my unit tomorrow, Michael from Virginia.
The XGauges for tire pressure will be pre-programmed in, so you should be able to just plug and play.
@ ScanGauge
PS -
@ ScanGauge
I am guessing:
TM1 - Driver Front
TM3 - Driver Rear
Good to hear it's all working - thanks for the feedback! With regard to the tire locations we're not entirely sure. The best way to find out if you can is to let some air out of a tire, see which one drops, then fill it back up and repeat with the next tire.
10-22-2017, 10:54 AM
#49
Got my unit back yesterday and new tire pressure codes are working. The TM codes work on my truck. Thank you James for the updates and programming work!
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
10-22-2017, 12:52 PM
#50
Which number represents which tire? I guess I could go out and test with my mechanical gauge but its dark outside.
I am guessing:
TM1 - Driver Front
TM3 - Driver Rear
Silly me! While testing which TM number corresponds to which tire I just realized it’s going to be different for everyone. The ECU and the Scanguage have no idea of your tire rotation and positioning. This means that you will have to retest or remember the rotation order each time you rotate your wheels.
10-22-2017, 01:58 PM
#51
Real Name: Dave
Real Name: Dave
I think I’ll just paint the number on the inside of the tire after determining which is what.
On the screen I’m going to want the results positioned to match the tire’s position on the truck. FDriver = upper left. RPassenger = bottom right. Etc..
Them Be Me Mods - 2011 Black Limited / Trail Mutt
10-24-2017, 03:49 AM
#52
So which devices do we buy for a 2016?
10-24-2017, 09:18 AM
#53
Hi Everyone,
I'm James DeLong, and I'm the engineer that worked on the Toyota TPMS XGauges.
I believe the Tire Pressure XGauges we've come up with will work on Tacoma's from 2006 - 2015. If your Tacoma is within that range, feel free to send it in and we'll update it.
I think there's a decent chance what we've come up with will work on most Toyota's with TPMS. If anyone has a non-4Runner Toyota/Lexus/Scion with TPMS feel free to contact us at [email protected] to ask about updating their unit for free to test out what we have. Would love to test this out on as many Toyota/Lexus/Scion vehicles as possible so we can be sure it works well.
James,
Any chance you'll open the cutoff for a 2007 4Runner 😁? Was there a CANBUS change from 2007 to 2008? I had thought 2006-2009 4Rs had the same setup. Thanks!
2007 Limited V8 FT-4WD
4x4Labs front and rear bumpers, 4.56 Gears with Harrop E-Locker Front & Rear, Icon CVDC w/ 700lbs spring Ext C/Os & Icon MetalTech Long Travel rear CVDC with HD springs, SCS Ray10s with GY MTRs 305/70R17, Prinsu Rack, Rago MSP and ditch light brackets, Wheeler's Super bumpstops
2007 Toyota 4Runner Limited V8 160,000miles
http://www.toyota-4runner.org/4th-ge...-thread-2.html
10-24-2017, 07:05 PM
#54
The ScanGauge 2 is what you'll want. I believe the current TPMS based XGauges will work on the 2016 4Runner.
The firmware that supports these TPMS based XGauge's hasn't been fully released yet though, so to get the correct firmware you'll want to order directly from us at ScanGauge.com.
Originally Posted by empty403
James,
I've been looking it over, and I believe I can expand the date range. I believe the TPMS XGauges we have should work on any 4Runner equipped with a TPMS system from 2004 to 2017. If anyone has a 4Runner in that date range and would like to get their ScanGauge updated for free to test out the new TPMS XGauges feel free to send it in! Just include a note indicating that you need the update to test out the Toyota TPMS XGauges.
For anyone who doesn't have a ScanGauge, but would like to have one for the TPMS data (or any of the other data it provides) you can use the coupon code 'T4R' during checkout at ScanGauge.com for a $30 discount. We'll also input all the XGauges we have for Tire Pressure/Temperature before shipping it out.
10-24-2017, 09:37 PM
#55
Thanks James!! I was about to buy a new 4R
11-03-2017, 11:47 AM
#56
THANK YOU James!
2012 Tacoma, upgrade works like a charm!
Shipped Saturday 2 day USPS, returned Wednesday, Super fast return.
Kudos again to all involved at Scan Gauge...Outstanding!
1987, SR5, 22re, auto
170k miles & counting
New paint, stripes
OME 2" w/UBJ lift
33x10.5x15 & US Wheels 94-5860 15x8
11-03-2017, 12:32 PM
#57
@ ScanGauge
(or anyone on this forum) is there a function on the Scangauge II to have "presets" to quickly rotate through saved groups of 4 guages?
Now I have my tires set to the order of tire rotation (left top gauge is driver front, left bottom gauge is driver rear, etc) it would be nice to save all 4 settings saved as a preset screen. I would love to have the ability to have other user defined presets for groups of 4 gauges for things like gas mileage, performance, temps, etc.
As-is now, I have to cycle through all buttons each time I want to see the gauges I want to see at once. It wasn't such a problem before, but now that I have the tire gauges and want them to display in a certain order, its a PITA to cycle through the buttons when I want to switch to other gauges and back again.
Is this something that you could program into the next firmware release?
11-03-2017, 01:24 PM
#58
Real Name: Phil
Real Name: Phil
Hey James, I just placed my order directly with ScanGuage and threw a note in the order notes section, thanks for the discount! Can you have this programming is done prior to shipment?
Thank you, Phil Brooks
2016 TEP w/KDSS - Total Chaos Expedition +2 Long Travel, Accutune Fox DSC 2.5" LT Coilovers & Accutune Fox 2.5" modified Tundra rears, ARB Summit Bumber, Nguyen Works Rear Bumper, DR_KDSS errything (switch, clamps, front brackets, BOTCK), RCI Armor, BajaRack, Baja Designs, Sumosprings bumpstops, 17"x9" +0 Enkei RPT1's, Yokohama Geolandar G0003 285/75/17 (34.1"), 4.56 Nitro gears, +random bolt-ons
11-03-2017, 08:52 PM
#59
@Scanguage This has probably been answered somewhere but, can you get transmission temp with the scanguage2? 2016 4Runner.
2016 4Runner, TEP, white. TRD black rims. ARB compressor (engine bay). Anytime backup cam mod. Gobi Stealth - No rise. ARB awning w/gen 2 room.
11-04-2017, 10:07 PM
#60
Here is the XGUAGE code to program it in, but I think it may already be there as TFT.
