Originally Posted by RagoFabrication
It's definitely not a solution for everyone but some want to keep the factory look but still be able to haul all their gear for their next adventure.
Here is a pic of the install from our tester. The two supports easily holds one of the largest CVT RTT (about 160 pounds). Our customer weighs about 275 and also has got inside without any issues.
We have an RTT on order and expect it here next week. The design itself will remain the same but depending on our additional weight testing, we will be adding additional gussets for strength.
I’m a bit confused by this picture - does the tent have to be attached to the cross bars before Install? If the cross bars slide in the same as factory, that’d be incredibly hard to slide the cross bars in through the rear with a 150lb tent attached.
Also, the way the channels go down near the body of the vehicle, it looks like you couldn’t reach under while they’re installed to bolt things to it. Again - having to pull them completely off to mount anything.
Lastly - did you guys adjust the clearance from the previous picture in Engineers thread? One of those pictures seemed to show maybe 1/16” clearance between the cross bars and roof.
