Thread Tools Rating: Thread Rating: 6 votes, 2.67 average. Display Modes
Old 07-12-2019, 12:56 AM #301
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Originally Posted by Sea_ledford View Post
I'm looking at options for a hybrid style bumper, mainly this one, SSO and LFD, primarily so I can add a winch.
I am completely ignorant on winch use at this point, but I'm pretty familiar with reel use from cave diving. Do you not have to respool the line on a winch after you use to to make sure it isn't all bunched up on one side? How do you do that if you cant see the spool?
THe LFD bumper has a huge opening so you can see it, but then the line is exposed to UV all the time. Not sure which is the worse of two evils...
Winch line at factory is spooled with no load. Respool with some tension recommended to allow the winch line to have a better hold on the drum.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 08:36 AM #302
Sea_ledford Sea_ledford is offline
Sea_ledford is on a distinguished road
Right, but what about after a recovery? If you attachment point isn't directly in front of the winch, wouldn't the line pile up on the side of the spool?
Sea_ledford is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 10:29 AM #303
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
You can see the line inside pretty easy through the grille and the fairlead. Getting the spool tangled up is a much bigger issue with wire rope. I've never had an issue with synthetic. The fairlead is narrow enough that it'll still spoil fine regardless of the pull angle.
Ideally it's evenly distributed, but it's really not meaningful because you'll be pulling most of the line off the spool for most which pulls. So if 30 feet is all off to one side, you'll be pulling it back off the spool before the next use anyway.
Ultimately it's just not a problem that really ever happens on the smaller spool winches that fit in these. I have had issues at times on my 8274, but it holds twice as much line on a much larger spool and pulls a lot faster. In that case I do re spool occasionally after a trip to reset it.
Old 07-12-2019, 11:30 AM #304
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Haven't had a chance to use the winch =D
New Warn Semi-Hidden Winch Kit bumpers-31f1bdcf-7a46-4f1d-bd90-56cc1a399d55-jpg
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 12:02 PM #305
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
Pretty much agree, steel rope is a different animal, but with synthetic rope after I finish a pull I usually take the time to reset it. IF it looks bunched up on a single side. All you have to do is keep minimal resistance on the rope and guide it back in in a controlled side to side manner.
r1verf3nix is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 08:26 PM #306
Faust301's Avatar
Faust301 Faust301 is offline
Real Name: Chris
Faust301 is on a distinguished road
Faust301's Avatar
Real Name: Chris
Originally Posted by Drobs View Post
Faust,
Is this the bracket you're using?
2014-2020 Toyota 4Runner 32" Light Bar Hidden Bumper Combo - Cali Raised LED
I note it has 2 light bar positions are you using the upper or lower position?
Any reason to not get their house brand 32inch light bar?
Yes, thats the one, I used the lower holes...I prefer the light bar I used because of its reviews, and light output for a single row bar.
Check me out on IG @Faust301 2014 SR5 premium. Dobinsons Front/Rear springs with IMS Struts/shocks, Method Race 310 Con6 17x8.5 with Yokohama Geolandar M/T g003 LT285/70R17, Spidertrax 1.25 spacers, ARB diff breather, CBI Adventure front bumper, ExpeditionOne Rear bumper, SouthernStyle Offroad sliders, Spod Source SE, RCI skids, Warn VR 10 S. Rigid lighting, Rago mounts. ExtremeLED light bar, ARB twin compressor on Bandi* mount. TJM snorkel, CVT awning, Custom Raptor lined ToughStuff Alpha RTT, Prinsu Full length roof rack, Dobinson drawer, slide and 50 wt fridge, Odyssey battery, ICOM GMRS radio, Lensun/Renogy Solar panels/Victron Controllers and much much more....
Faust301 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 01:43 AM #307
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
I'll bump this back up, I installed the bumper and a Smittybilt X2O Gen 2 12k winch last night... I'm not mechanically inclined, was working on the ground, and also had to remove the Apex Overland Front Recovery Points (and install a sway bar spacer) and the total time was probably in the neighborhood of 5ish hours (including setting up the winch) with another pair of hands helping me.
My bumper was another of the Amazon purchases, with a few Amazon gift cards accumulated, it made wonderful fiscal sense. That being said, mine had a few paint chips and there is a slight dent in the top tube on the driver's side, neither of these are worth sending it back over.
Things of note (other people have said this, but in case someone stumbles upon this reply)...
-- The Warn bumper is NOT compatible with the Apex Overland Front Recovery Points, not even close
-- I did have to space the sway bar down or else the Warn frame extension brackets would have hit it
-- I did not use the small flat bumper brackets, I saw no point in doing this. The driver's side was fine with the single 10mm into the fender liner (through the bottom of the bumper); and the passenger's side was fine with the 10mm and the Warn-supplied bolt w/ fender washer & nut
-- If you use a Smittybilt X2O winch, mount the control box on the center or slid towards the driver's side. Both of these allow very easy access to reach in through the front bumper holes and reach the wireless switch, the wired plug in, as well as the clutch release
-- Easiest way to bolt the winch in, support the bumper on two chairs and lay under it
-- For bumper trimming, just inside the silver trim (TRD Off Road/Trail) seems to be a very good starting point. We did minor sanding after that phase and then hit the trimmed bumper edge with some door edge guard.
Oh, and now a photo (sorry, it was nearly 1am, taking pics was not high on the list of priorities at the time)
As a side note my plan is to upgrade to Dobinson's 314 springs (with my 574 struts); I already have the in the garage, but we leave for a 5500 mile trip in a few days and I don't see the install happening before the trip...
New Warn Semi-Hidden Winch Kit bumpers-img_20190807_003932726-jpg
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 07:18 PM #308
TPatrick TPatrick is offline
TPatrick is on a distinguished road
Bumper Weight - OME Springs
That bumper is just under 90 pounds and a Warn (not SB)10K winch weighs 80.3 pounds. The OME 2885 HD coil accommodates up to 180lbs over stock. The bumper looks great! What brand of light-bar did you use? Thanks,
Originally Posted by Greensleeves View Post
I had my Warn bumper and SmittyBilt winch installed yesterday... yes i HAD it installed.... don't hate on my for not doing it myself
I like the look, and the two fit great together, no issues..
The 4Runner does ride a bit nose heavy, which is to be expected, i think combined weight is 100lbs (ish) But I have an OME medium suspension that will compensate.
I had a light bar already in my grill and the bar does not interfere.
So far I really like it!
Attachment 288474
Attachment 288475
TPatrick is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 01:39 PM #309
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
TPatrick check out the Cali Raised hidden Light Bar.
2014-2020 Toyota 4Runner 32" Hidden Grille LED Light Bar Combo– Cali Raised LED
Here's mine :
New Warn Semi-Hidden Winch Kit bumpers-shrockworks-sliders-2-jpg
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 07:00 PM #310
sac602's Avatar
sac602 sac602 is offline
sac602 is on a distinguished road
sac602's Avatar
Anyone have a pic of the cut plastic bumper cover prior to install?
Also, I have a ToyTec sway bar relocation kit if anyone needs it. $20 shipped. toytec 4runner sway bar relocation kit | eBay just make offer for $20 and I will take it.
2014 LE-Attitude Black with front end conversion. Warn 100022 bumper/ smittybilt x20 winch. Toytec Ultimate lift / Camburg UCAs. Fn Fx(pro) rims (www.importequipment.com center cap decals), 285/70 r17 Ko2. ZenonDepot H11 HID Kit | Xtreme HID
[Philips Bulb 4300K] / Morimoto XB Led fogs, DiyBriGuy.com Front/rear camera override. Removed 3rd row seats for fridge / drawers. Odyssey Batterie 34R-PC1500T - needs Odyssey Group 34 Battery Spacer. C4 Ladder, Prinsu rack
sac602 is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 07:47 PM #311
sac602's Avatar
sac602's Avatar
So I installed mine today. I was unsure of the trimming, so I figured I would post my cutting.
I followed the side groove all the way up, then 1 & 1/4 inch down from the bend all the way across the front. The little bumper cover flap (the 1 1/4 bit) edge sat up a bit so I put two small bolts in that just tighten with a fender washer on the inside. This provides enough "pull" to make the bumper cover sit flush on the top of the warn bumper.
Definately needed the sway bar drop to avoid contact. I did have to oval one bolt hole, but no biggie.
Hope this helps someone.
Sent from my SM-G986U using Tapatalk
Old 09-22-2020, 11:31 PM #312
Colinmini Colinmini is offline
Colinmini is on a distinguished road
I bought a Warn 100022 hybrid bumper/winch mount, but hardware and parts are missing. I am wondering if someone could measure the center to center hole distance for the 2 parts label “A5”? (These go from the Warn to support the outer oem plastic bumper)
New Warn Semi-Hidden Winch Kit bumpers-f11fecce-f2a6-442b-bbc7-6b47d815fb24-jpg
Colinmini is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 05:18 PM #313
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Anyone have any issues putting this Warn Hidden winch mount on a 2019 with KDSS?
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 04:51 PM #314
Sky Sky is offline
Sky Sky is offline
Well my Warn Hidden winch mount showed up with damage-
the scary part is the cardboard has barely got a mark on it but look at this dent in the bullbar>
Makes me think that bullbar is some very thin steel.
Have an email in to the seller asking for a replacement or an adjustment.
New Warn Semi-Hidden Winch Kit bumpers-warn-dented-bullbar-jpg
2011 FJ Cruiser TRD
Old 10-03-2020, 02:42 PM #315
kelkins kelkins is offline
kelkins will become famous soon enough
Happened to me as well, but not on the bull bar. My seller knocked off 100 dollars. I would ask 200 for a dent like that though.
kelkins is offline   Reply With QuoteReply With Quote
PelfreyBilt hidden winch mount and Warn M8000-s elguidoam 5th gen T4Rs 23 03-27-2019 05:12 PM
Warn Platinum 10-S Winch Install on Hidden Mount Problem 4R Play 5th gen T4Rs 8 08-24-2016 07:41 PM
Budbuilt Hidden Winch Mount Warn 9.5 cti Intall Help bernardmwrangle 5th gen T4Rs 4 04-01-2013 08:17 PM
what are some good plate front bumpers for a Warn M8000 winch? 10JQKA 3rd gen T4Rs 4 09-15-2012 09:34 AM
