Old 03-04-2019, 01:29 PM #16
cctt cctt is offline
cctt is on a distinguished road
Originally Posted by Misterfive View Post
Thank you for this tip. It worked out perfectly without any added wiring.
One piece of advise is it seems its polarity specific so be sure to plug the add a circuit in the exact orientation as the picture, also put the fuse in the same socket closest to the wire. I did it the wrong way and it kept my radio on instead of the 12v sockets. Hope this helps anyone that runs into this issue
i tried to do this over the weekend however my radio and 12 volt socket is on. I thought I had the polarity incorrect so I flipped it in all sort of combination but only was able to get the radio and 12 volt on or else it was off. I just want the 12 volt socket under the radio on. Am I doing it wrong
cctt is offline   Reply With QuoteReply With Quote
Old 03-04-2019, 01:40 PM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Almost sounds like you are back feeding the circuit and causing the radio to power up… What are you trying to wire and to where?
Also your comments about polarity and “flipped it in all sort of combination” are pretty concerning… check polarity, use a meter, make sure it’s right… Don’t do what you did because its recipe for problems, generally speaking.
Old 03-04-2019, 02:02 PM #18
i got 2 "add a circuit" and splice it together. I took out the 15 amp in the top right spot, put it in one of the add a circuit. plug it back in. The 2nd end of the add a circuit I place it in the empty slot (4th down on the left). When I put it in initially nothing turn on so I reversed it and it came on but both radio and 12 volt socket.
I'll re-check my work later and use a meter to check. thanks.
Old 03-04-2019, 02:18 PM #19
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
if an add a fuse is in backwards the tap isn't fuse protected, are you sure your fuse wasn't blown and that's why you only got power one way but not the other?
jhguth is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 12:58 AM #20
Misterfive Misterfive is offline
Misterfive is on a distinguished road
I just plugged it in exactly like the picture. I want to warn that it killed my battery. I have an 8inch tablet plugged in powered with a camera app on always and it killed my battery.
Misterfive is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 01:22 PM #21
NotPedro NotPedro is offline
NotPedro is on a distinguished road
Originally Posted by Maadcaap View Post
What an awesome tip; thank you! Exactly the kind of solution I was looking for.
Thanks for this. I had the radio-turning-on issue and following this helped me.
NotPedro is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 06:45 PM #22
watox watox is offline
watox is on a distinguished road
Thanks!
Did this today. Worked great. Followed all the instructions and warnings. Super easy. 12v outlets are hot. Radio stayed off. MUCH cleaner than running new wires (needed the rear outlets to be hot). And the little fuse box under the dash (above the parking brake pedal) is out of the way so leaving the cover off is no issue at all.
Very very helpful. Thanks all.
watox is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 11:20 AM #23
Ripper238's Avatar
Ripper238's Avatar
I'm looking to do this in my 2019 as well. But is this the best and safest way?
Besides doing a separate hard wire is there any other way of doing this?
Sent from my SM-N960U using Tapatalk
Old 05-22-2020, 12:24 PM #24
Ripper238's Avatar
Ripper238's Avatar
I decided to run a separate switched power to a duel cigarette socket. I missed doing old school wiring
Old 05-22-2020, 11:02 PM #25
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
I asked the same question some months ago, but have yet to get a reply.
I used to have a 2002 Tacoma TRD and there was a trick I found online that involved simply a short jumper wire between two fuses in the box under the hood to make the outlets live. In the 17 years I owned the truck never had an issue. I wondered if something like that could be done on the 4Runner.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 11:43 AM #26
Maadcaap's Avatar
Maadcaap Maadcaap is offline
Maadcaap is on a distinguished road
Maadcaap's Avatar
Safest way is direct to battery with the proper fuse
I tried the same mod on my 2019 tundra.. the radio would not turn off.. i ended up jumping the relay in the fusebox under the hood..
Maadcaap is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 11:12 PM #27
DAW89446's Avatar
Real Name: Dave
DAW89446's Avatar
Real Name: Dave
I assume the 2018 4Runner is considerably more complicated than my old Tacoma, so figured live ports must be reversed engineered from what Toyota did to put them on the accessory loop. It was such a simple job on my Tacoma. For 17 years I always had live ports, constantly running a CB radio and a 200 channel scanner. Sometimes the truck would sit for two or more days with them running and I never experienced a dead battery until they were ready to die (I had recently installed the third battery in the truck when I gave it to a family member when I bought my 4Runner last year).
Dave
2018 4Runner SR5
Old 03-04-2021, 11:29 PM #28
Blake_Runner Blake_Runner is offline
Blake_Runner is on a distinguished road
I'm trying to do this on my 2012, but I think my fuse box layout is different than the 14+. Does anyone know what fuses I should jump between? Thanks!
Blake_Runner is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 06:26 AM #29
TravelingTaco TravelingTaco is offline
TravelingTaco is on a distinguished road
Originally Posted by ajsimeon View Post
Is keeping an iPad mini hooked up to an always on 12v usb gonna drain the battery enough that it won't start?
This is my concern as well. I do always keep a charged jump pack in my vehicles though. I'd hate to be stranded with a dead battery.
TravelingTaco is offline   Reply With QuoteReply With Quote
Old 05-16-2021, 09:07 PM #30
Pilotmatt's Avatar
Pilotmatt Pilotmatt is offline
Pilotmatt is on a distinguished road
Pilotmatt's Avatar
I did this on a 2017 and the radio is also turning on. It was great for the drive in but in general I need to figure out how to just get the rear accessory 12v to be constant. Anyone figure out why this is happening?
2017 SR5 4WD Premium
2003 SR5 4WD V8 (2010-2017)
Pilotmatt is offline   Reply With QuoteReply With Quote
Make power windows always work? calimobber 3rd gen T4Rs 1 04-12-2015 12:24 PM
Power Hungry! Does anyone make a header for the 4.7 VVT? montana_jeepn 4th Gen T4Rs 16 08-29-2014 01:00 PM
Can I make my power socket constant? nortex 4th Gen T4Rs 7 06-14-2013 06:39 PM
how to make new electric system for power window in hatch of a 90' 4runner hjalti_gto Classic T4Rs 3 01-05-2011 11:22 AM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
