Originally Posted by cctt
i tried to do this over the weekend however my radio and 12 volt socket is on. I thought I had the polarity incorrect so I flipped it in all sort of combination but only was able to get the radio and 12 volt on or else it was off. I just want the 12 volt socket under the radio on. Am I doing it wrong
Almost sounds like you are back feeding the circuit and causing the radio to power up… What are you trying to wire and to where?
Also your comments about polarity and “flipped it in all sort of combination” are pretty concerning… check polarity, use a meter, make sure it’s right… Don’t do what you did because its recipe for problems, generally speaking.
