Originally Posted by gundrted+t4r
If you are looking to get larger tires 18s will be expensive and size limited. 17s will give you most options and at the best prices. ...
He's right. Go with 17" rims.
I will be selling my 2015 Trail Edition, 17x7.5" wheels and stock tires by the first of the year. I'm getting 17x8.5 ICON wheels so I can mount 285/70/17 wider and taller tires. The tire manufacturers recommend an 8" to 9" rim for that size. The SCS Stealth 6 17x8.5" wheels also looks good to me and they are very lightweight, which is good for reducing the unsprung weight, preserving power and braking.
I'm in So Cal and you're in Florida, so buying my wheels and tires may not be a good option for you. Shipping cost would be prohibitive.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
