View Poll Results: What suspension did you chose for your lifted KDSS rig?
Icon
31 |
12.76% |
Billstein
78 |
32.10% |
Fox
18 |
7.41% |
King
35 |
14.40% |
Radflo
4 |
1.65% |
Toytec
29 |
11.93% |
OME
20 |
8.23% |
Other--what is it?
28 |
11.52% |
Other--what is it?
28 |
11.52% |
11-26-2017, 03:11 AM
#16
Real Name: Nick
Real Name: Nick
Fox 2.5 extended travel coilovers, remote resi in front and rear also with DSC adjusters.
2016 Trail Premium Mag Gray w/KDSS, TRD Pro Wheels wrapped with Cooper STT Pro 285/70R17, Fox Shocks 2.5" remote resi with DCS adjuster F/R, SPC UCA's, Pelfreybilt bumper, 15% Ceramic Window Tint, Shrockworks sliders, TRD Pro Intake, Baja Designs sitting on Rago Ditch Brackets and Ecotechne Rack, Rago MSPs in Cargo area, Baja Designs LEDs
11-26-2017, 09:14 AM
#17
Icon stage 7 with SCS SR8 wheels and 285/70/17 BFG KO2 tires. Coilovers set @ 3.5”
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
11-26-2017, 09:16 AM
#18
Other side
IG: @Expo_T4R
11-26-2017, 11:39 AM
#19
2016 TE with KDSS. Small 2.5” / 1” lift via Bilstein 6112/5160 and Wheeler T13 rear springs.
Works for me...easier than anticipated to install.
2023 SR5 Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
11-26-2017, 11:47 AM
#20
Real Name: Brett
Real Name: Brett
6112's
11-27-2017, 03:21 AM
#21
Megaweapon -- Kings w/mild lift and upgraded springs:
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
02-26-2018, 12:42 PM
#22
Originally Posted by 4Running303
2015 TE, KDSS
King Coilovers with 600lb coils, King Extended Travel Shocks, Dobinson's 677V Progressive rate coils, Dirt King UCA's w/ heim inners, Rokmen rear trailing and upper arms, Rokmen adjustable panhard. Nitto Ridge Grapplers 305/70-17 on SCS Ray10's with 1" BORA spacers.
I feel like I just rewrote my signature!
Most of the rest is in there. Oh and I would guess I'm at 3" in the front and rear. No lean last time I checked!
Thats a rig. Nice job on your selections.
02-26-2018, 04:07 PM
#23
Real Name: Drew
Real Name: Drew
Here's mine...
2015 TE-P, KDSS, MGM, Demello Sliders, ICON Stage 7, Nitto Trail Grapplers 285/75R17 (34's), Pelfrey Aluminum Front Bumper, Warn Zeon 10S Winch, Baja Designs Lights, Pelfrey Battery Holder, Prinsu Roof Rack, Body Mount Chop, Black out tint, Roto-Pax, blah blah blah so far...
02-26-2018, 04:36 PM
#24
Real Name: Shawn
Real Name: Shawn
Mine...
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
02-26-2018, 04:41 PM
#25
Real Name: Krister
Real Name: Krister
2014 Trail Edition
Front: - Icon Tubular UCA's
- Icon 2.5 Remote Resi Extended Travel Shocks
- Icon 700# Springs
- Total Chaos Spindle Gusset
- BMC
- KDSS Sway Bar Removed!
Rear: - Metal Tech Upper & Lower Links
- Icon 2.5 Remote Resi Shocks
- Dobinsons C59-701V
SCS Stealth 6 Wheels
Toyo Open Country M/T's 285/75R17 (34.1")
So, why the removed sway bars? The KDSS system does not work well with a lot of wheel travel and lift. The lift burns up the down travel of the piston as it is designed for stock configuration. Also, the fixed side of the sway bar also limits down as well as up travel. For me and the type of wheeling I do, the removal of the sway bar has in fact made a difference. I noticed it on this one trail, I had ran both with and then without, and with the sway bars limiting travel, the truck did not feel stable. When I ran without, the truck felt more planted and went through the section much easier.
These are without.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
02-26-2018, 06:05 PM
#26
Originally Posted by rochmpr
2014 Trail Edition
- Icon 700# Springs
- BMC
These are without.
Attachment 287210
Attachment 287211
Awesome man!!! Ive been thinking about removing mine as well! Is it difficult? O you get an indicator light on the dash? I think if I do remove it, im going to go LT in the front
IG: @Expo_T4R
02-26-2018, 06:37 PM
#27
Real Name: Krister
Real Name: Krister
I have only removed the sway bars, the system is still intact but I have strapped the piston up in the compressed position. So, with this approach, the computer still thinks everything is there and no dash light. One day, I may remove the system completely, but I have other projects with a higher priority.
02-26-2018, 09:18 PM
#28
Kdss experts... when installing a lift I have read to strap the piston in the kdss system. What about disconnecting the battery? Would this lack of power to the system keep the kdss ram from operating?
02-26-2018, 09:31 PM
#29
its still pressurized, so it'll still want to expand. someone tell me i'm wrong though
02-26-2018, 09:36 PM
#30
Real Name: Dennis H.
2015 TE, KDSS
That front bumper though! 🖒🖒🖒
Sent from my SM-G930V using Tapatalk
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
