View Poll Results: What suspension did you chose for your lifted KDSS rig?
Icon
31 |
12.76% |
Billstein
78 |
32.10% |
Fox
18 |
7.41% |
King
35 |
14.40% |
Radflo
4 |
1.65% |
Toytec
29 |
11.93% |
OME
20 |
8.23% |
Other--what is it?
28 |
11.52% |
Other--what is it?
28 |
11.52% |
02-26-2018, 10:05 PM
#31
Originally Posted by honda250xtitan
its still pressurized, so it'll still want to expand. someone tell me i'm wrong though
Idk. I hope that others have thought of this but I haven't read anywhere that states one way or not. Thought it was worth asking.
02-27-2018, 12:57 AM
#32
2011 Trail with KDSS
Toytec Boss Front (700#) and Rear (Icon Overland 3")
Light Racing UCA's
CBI Rear Bumper with Dual Swing Away
CBI Front Bumper
Warn M8000-S; Factor 55 fairlead; Factor 55 Flatlink
CBI Full Skids
Shrockworks sliders
Rubber:
- Summer: Cooper Discoverer ST Maxx LT285/70R17 E
- Winter: Nokian Hakkapeliitta LT2 LT285/70R17
ARB Drawers
05-15-2018, 05:36 PM
#33
Originally Posted by rochmpr
2014 Trail Edition
Front: - Icon Tubular UCA's
- Icon 2.5 Remote Resi Extended Travel Shocks
- Icon 700# Springs
- Total Chaos Spindle Gusset
- BMC
- KDSS Sway Bar Removed!
Rear: - Metal Tech Upper & Lower Links
- Icon 2.5 Remote Resi Shocks
- Dobinsons C59-701V
SCS Stealth 6 Wheels
Toyo Open Country M/T's 285/75R17 (34.1")
So, why the removed sway bars? The KDSS system does not work well with a lot of wheel travel and lift. The lift burns up the down travel of the piston as it is designed for stock configuration. Also, the fixed side of the sway bar also limits down as well as up travel. For me and the type of wheeling I do, the removal of the sway bar has in fact made a difference. I noticed it on this one trail, I had ran both with and then without, and with the sway bars limiting travel, the truck did not feel stable. When I ran without, the truck felt more planted and went through the section much easier.
So this is part of the answer I have been looking for about lifting a KDSS 4R. When I went into local shops they said if I lift then I will loose KDSS, but I didn't understand. Now I understand.
The other part of my question is how does it feel when you are doing normal street driving? Does removing the sway bar do anything to the street driving?
05-15-2018, 05:44 PM
#34
Originally Posted by JustLearning
Kdss experts... when installing a lift I have read to strap the piston in the kdss system. What about disconnecting the battery? Would this lack of power to the system keep the kdss ram from operating?
@ honda250xtitan
is right. The system uses a pair of accumulators that will have about 500psi in them. Meaning anywhere from 500 to as low as maybe 100lbs of force depending on position of the cylinder will always be pushing on it to extend.
I actually don't strap mine up anymore. I just use a jack under it to compress it back when I want to put the sway bar back on after working on it.
05-15-2018, 08:19 PM
#35
Real Name: Justin
Real Name: Justin
9509
This not a true statement. There's plenty of lifted rigs with kdss. Mine's on 5.5" and there's a runner in Colorado with a 6" bracket w/ kdss still operational.
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
05-15-2018, 08:30 PM
#36
2014 trail edition with KDSS - OME BP-51s front/rear, 285 ridge grapplers
05-15-2018, 09:03 PM
#37
Originally Posted by TheWraith
9509
Thanks. I think I'll be doing this in the garage then for a lot less.
05-15-2018, 09:15 PM
#38
Originally Posted by Jetboy
@ honda250xtitan
i looked at the ratchet strap and was like wait people actually use this? floor jack and a punch to align the bolt holes and you're golden. The rear i think i used a long clamp to help line it up though. idk. one day i did it one way, the other day another way. it was kinda a biotch, the track bar was hitting the bolt head on the sway bar after we threw the 1.5 lift springs in -_- lol
05-15-2018, 10:13 PM
#39
Real Name: Conner
Real Name: Conner
Bit of a newbie here to the 5th gens and the KDSS system. Picked up a 2010 Trail this weekend with KDSS. The guy I bought it from knew nothing about the lift (It was his son's truck). After checking it all out, it looks to have toytec front coils on billstein shocks, and toytec rear coils on toytec boss rear shocks. Is this lift compromising the use of the KDSS? I have tried to sort this out in the above comments but am still pretty confused about it. Any clarity would be beneficial! Thanks in advance.
Here's my runner:
2010 4Runner Trail w/ KDSS -- 3" Toytec Lift - 285/65r18 Trail Grapplers - Fuel Hostage Rims - Gobi Ladder - BatesWeldFab Custom Rack - Magnaflow Exhaust - 22" Hidden Light Bar - 44" SlimsDepot Combo Light Bar - Custom Rock Sliders - LFD Offroad Skids - CB Radio w/ Firestik
2009 GMC Sierra z71 4x4 -- Lifted on 35's - Sold (May 2018) // 2000 4Runner Limited -- Lifted - Armored - Sold (May 2014)
Instagram: @DoubleHaul4x4 Old 4Runner Build Thread: Duluth4Runner's Build Thread
05-15-2018, 11:20 PM
#40
how is everyone's KDSS lean after the lift? Did one side need a small spacer to fix it?
The Water Bear - Instagram (photos of mods & progress)
2015 Attitude Black 4runner Trail Premium w/ KDSS. 2.5f/1.5r Spacer Leveling Kit. 285/70/17 Firestone Destination AT Load rating P
05-15-2018, 11:24 PM
#41
Mine is a 1/4" higher on the drivers side so I like to think its level when I'm in it. I did the KDSS equalization and that seemed to help.
'11 TE w/KDSS - Front Bilstein 6112 @4th clip ~2" - Rear 5100 and Bilstein B12 1.5" springs - JBA OffRoad UCA's
SOLD '15 TEP w/KDSS - Nitto Ridge Grappler 285/70/17 - Front Bilstein 6112 @3rd clip ~2" - Rear 5160 and Daystar 1.5" spacer - Total Chaos cam tab gussets - JBA OffRoad UCA's - RR Super Sliders
05-16-2018, 02:12 AM
#42
kings........
I have a KDSS lean but it doesnt bother me at all, nobody will notice it except you. It's like the pimple on your forehead......if you point it out, then the whole world will be staring at it.
05-16-2018, 04:56 AM
#43
No real noticeable lean. Did throw a 10mm OME spacer in on the passenger rear during the install, have not done the KDSS equalization 🤷*♂️
05-16-2018, 05:59 AM
#44
'17 ORP KDSS
Toytec Boss 3" lift
SPC UCA
SCS Ray 10
BFG AT KO2 285/70/17
Spidertrax Spacers
12-23-2018, 09:04 PM
#45
I heard putting in 4 low will disengage kdss and help with lift installation.
Someone with better kdss experience would have to confirm.
