View Poll Results: What suspension did you chose for your lifted KDSS rig?
Icon
31 |
12.76% |
Billstein
78 |
32.10% |
Fox
18 |
7.41% |
King
35 |
14.40% |
Radflo
4 |
1.65% |
Toytec
29 |
11.93% |
OME
20 |
8.23% |
Other--what is it?
28 |
11.52% |
Other--what is it?
28 |
11.52% |
12-23-2018, 09:33 PM
#46
Originally Posted by Monroe
I heard putting in 4 low will disengage kdss and help with lift installation.
Someone with better kdss experience would have to confirm.
KDSS is completely independent of everything else other than the speed you are driving. Below 12 mph, more articulation, above less. So no, putting it in 4 low will have no effect on a lift installation. Best thing to do is have a shop do it that has experience with KDSS.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
12-23-2018, 10:34 PM
#47
Banned
Banned
2.5” Bilsteins 5100 with Wheelers T1-T13 springs, JBA UCA and 1/4” spacer up front driver side for lean. Adding 285 Wildpeaks tomorrow, removed front mud flaps and fender liner mod (zero rubbing on 275 KO2s).
12-24-2018, 01:27 AM
#48
Real Name: Nick
Real Name: Nick
'18 TRD ORP
Kings w/adjusters, 650 springs in front, Dobinson C59-723 springs out back,
Total Chaos UCAs, Cooper ST Maxx LT255/80/17 tires. Truck is lifted 2.5" in front and 1.5" in the rear.
12-24-2018, 02:07 AM
#49
Real Name: Chris
Real Name: Chris
King extended travel w/ adjusters, 2" Icon rear springs, 650lb coilover springs, a little over an inch of preload threads showing with slightly more on the passenger side, Icon delta joint UCA's, 285 tires.
Front rides a bit high especially when the truck is loaded up, but I have a lo-pro bumper waiting to go on and then I'll readjust as needed.
2018 TRD ORP w/ KDSS: King extended travel coilovers & shocks w/ adjusters - Icon tubular Delta Joint UCAs - Icon 2" rear springs - 17x9 -38 offset Stealth Custom Series stealth blue F5 wheels - 305/70R17 Nitto Ridge Grappler tires - C4 Fab Lo-Pro bumper - Baja Designs 30" S8 - Baja Designs Squadron Sport fogs - TRD Pro grille and rear bumper valance - Full custom audio system w/ CarPlay - URD MAF calibrator - Sprint Booster - RCI skid plate - Shrockworks angled sliders - Front Runner roof rack and Maxtrax mount - Xenon Depot Xtreme HID Philips 4300K low beams - ARB on-board air compressor w/ Rago Fab mount - Wifey 4-corner air system - Warn VR10-S winch w/ Factor 55 fairlead and Ultrahook - Odyssey 34R-PC1500T battery - Voltage booster - T4RPAM with Yaesu FTM-400XDR radio and Android tablet running Backcountry Navigator and APRSdroid
12-24-2018, 02:15 AM
#50
Banned
Banned
You definitely have some negative rake going on, but it’s not that bad looking. I think once you add some weight like you said, you will be good to go!
12-24-2018, 10:44 AM
#51
2018 W/KDSS ADS coil overs and rear shocks , Total Chaos UCA, 285/70/17 Nitto Ridge Grapplers.
2018 TRD ORP W/KDSS & Sunroof - ADS C/O's and rear RR, TC UCA's, Icon 2' springs, SSO bumper, Smitty X20, Nitto RG, FX PRO wheels, AVID sliders, RCI Alum skids, Bussmann RTMR, Canvas backs, Accessorides remote start, Rago Molle’s, HID low's, LED high's, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack, ARB diff breather, Indel B TB51, Ellis shift knobs, Plastics Guy bump stops, ARB twin comp., Pedal Comm, X2 Power G27
12-24-2018, 12:35 PM
#52
Banned
Banned
I see several people with negative rake on lifted rigs...is this by design?
12-24-2018, 12:39 PM
#53
2016 Trail with KDSS. Extended travel Radflo 2.5 shocks front and rear. 600 lbs coils up front and SAW coils in the rear. Dirt King UCAs. 285/70/17 BFG KO2. 2.5 inch front and 2 inch rear lift
12-24-2018, 12:42 PM
#54
Banned
Banned
Looks killer...i think you sit perfect, if darn near level
12-24-2018, 04:16 PM
#55
Thank you. It’s definitely a process to try and get it “just right.”
12-24-2018, 05:57 PM
#56
Bilstein 5100/OME Springs
Method 310 Con 6 with 285/70/17 KO2’s
Stock UCA’s but the alignment shop was able to get it pretty close.
12-24-2018, 09:46 PM
#57
Originally Posted by slprciv
'18 TRD ORP
I have Kings on order with 550 front -- I have aluminum skids, steel sliders. How do the 650 springs up front ride?
2018 ORP Magnetic Gray, RCI sliders and skids
12-24-2018, 11:42 PM
#58
Real Name: Nick
Real Name: Nick
It's firm but not stiff. I have adjusters so that helps fine tune the dampening. Also I have full steel skids, steel sliders, and soon front lo pro steel bumper with winch. It's the only reason I went with 650.... if not I would've just went with 600 or stock 550 springs instead.
12-24-2018, 11:47 PM
#59
Real Name: Nick
Real Name: Nick
I mainly have 1" of rake just for gear and camping stuff out back when I off road. Also for future full roof rack on top too.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
