Old 11-26-2017, 04:11 PM #1
hazards280 hazards280 is offline
hazards280 is on a distinguished road
ICON Delta Joint Users - Chime In Here
Folks, we don't have a good solid thread for reviews on ICON's Delta Joint Tubular/Billet UCA's. I'm looking at buying a set since I need the perks of a traditional ball joint due to the salt we receive in the winter months here in Michigan.
I was about to pull the trigger on a set of Camburgs; however, I've read quite a few cases where guys were unable to get their caster in the +4 range with them. I don't want to spend $500 and not get what I'm looking for so, I'll just spring for the ICON's if they truly deliver results.
So what's your guys's take -
  1. How is the build quality?
  2. Do you have any squeaks or rattles?
  3. Any concerns thus far?
2015 4Runner TRD Pro - Inferno
2022 Wrangler 392 - Sarge Green
1964 Shelby Cobra 289 FIA
hazards280 is offline   Reply With QuoteReply With Quote
Old 11-26-2017, 04:45 PM #2
Hamburgerpimp's Avatar
Hamburgerpimp Hamburgerpimp is offline
Hamburgerpimp will become famous soon enough
I've been running the Icon DJ UCA's for about 6 months now. I put them on right before a trip to Canyonlands and honestly could not be happier. I have them paired with 6112's on 4th clip. I was easily able to get caster above 4 degrees.
I have no squeaks or rattles, build quality seems outstanding, but as you know they do not come cheap. You can probably find some Black Friday deals though.
A couple tips, don't bother with the grease needle fitting on the ball joint, just thread in the Zerk it comes with and use conventional grease gun fitting.
Only use this grease on Bushings,
https://www.amazon.com/Super-Lube-41...rds=super+lube
Yes this means you will have two grease guns to service UCA's, one for bushings, one for ball joint.
I found this out the hard way as the instructions do not specify which grease to use and comes with no grease.
Do not Grease the bushing Zerk fittings with the control arm bolts tight, this will blow out the bushings.
Hope this helps..
2014 4runner Trail, KDSS, 6112's w/King 650# springs, 5100, 295/70/17 DuraTrac, 4.88 Nitro Gears, Harrop Front E-locker, ToyTec 2.0 rear springs, Metal Tech Sliders, Full RCI STEEL skids, Prinsu Rack, C4 Fab Fuel Tank Skid, C4 Lo Pro bumper with High clearance, X20 winch, ARB Twin Compressor, Northstar 27F, Precision LED conversion, NoCo onboard charger, Icon Delta Joint UCA's, Dobinson's Rear Drawers.
1989 4Runner: All Stock
Hamburgerpimp is offline   Reply With QuoteReply With Quote
Old 07-20-2018, 01:04 AM #3
Dane Hauler Dane Hauler is offline
Dane Hauler is on a distinguished road
Is there anyone in the Denver area who has upgraded their uniball with Delta joints and would rent me their tools? The price is steep enough that bind the tool on top of the Delta joints would pay for a pair of jba UCAs!
Dane Hauler is offline   Reply With QuoteReply With Quote
Old 07-20-2018, 11:42 AM #4
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
ICON UCA with Delta Joint
I don't recall using any special tools to install the ICON tubular UCA with the Delta Joint. Watch a few videos on how the stock UCA comes loose with a few taps of a hammer.
I'm happy with the ICON UCA with the Delta Joint. I have no complaints or problems in the 6 months since I installed them.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 07-20-2018, 11:50 AM #5
12Bravo4R's Avatar
12Bravo4R 12Bravo4R is offline
12Bravo4R is on a distinguished road
12Bravo4R's Avatar
I think he's just looking to upgrade his ball joint from uni to Delta...which I don't think is an option...?
Either way, I've got about 20K mi on my DJ's and no issues/complaints to report.
2016 TP - Toytech - ICON - FN Wheels - MT Deegan 38 - Borla - TRD CAI - RSG - RCI
12Bravo4R is offline   Reply With QuoteReply With Quote
Old 07-20-2018, 01:43 PM #6
MagneticTRD MagneticTRD is offline
MagneticTRD is on a distinguished road
Icon sells a kit to remove the old uniballs and install the new delta joints.
I had icon uniball uppers on my fj and used them longer than I should have. They needed a rebuild about 20-30k miles before I finally switched to delta joint arms. No problems in the 6 or so months I had them on before I traded it in. Like stated above, just use the standard grease fittings. I tried the low profile style and never could get them to work. I plan on getting them again when I lift my 4Runner.
MagneticTRD is offline   Reply With QuoteReply With Quote
Old 07-21-2018, 05:34 PM #7
gringo8251's Avatar
gringo8251 gringo8251 is offline
Real Name: Zach
gringo8251 is on a distinguished road
gringo8251's Avatar
Real Name: Zach
I am using the Delta UCAs on an ORP w/ KDSS, 3" lift, and 33s on stock Trail wheels. I installed myself and plan to service them after any trips/scheduled maintenance intervals. I'm fortunate the roads here are salted only 1-2x a year. Only have a couple thousand miles on them so far but I'll report back on any issues. Icon has videos on YouTube if you're wondering about their install or maintenance recommendations.
gringo8251 is offline   Reply With QuoteReply With Quote
Old 09-14-2018, 01:05 AM #8
assassin assassin is offline
Real Name: M
assassin is on a distinguished road
Real Name: M
Do you use the same grease for the delta joint?
Hope this helps..
assassin is offline   Reply With QuoteReply With Quote
Old 09-14-2018, 09:04 AM #9
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
They Icon uniball UCA can be swapped out to a Delta Joint. Icon sells a press tool (~$40) to press in the new Delta joints. I pulled out mine UCA's about 10 months ago and dropped them off at a local shop and they pressed out the old uniball and installed the Delta joint. No more squeaking, no more build-up on the top of the joint. Was able to get to 4° of caster. Cam tabs are maxed out, otherwise probably could have gotten more.
As far as I am concerned, it was a good upgrade.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 09-23-2018, 11:49 AM #10
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
Hope this helps..
Hamburgerpimp, just to clarify you mean you need to place the zerk fitting on the top of the Delta Joint (see photo below) and place grease into the delta joint itself?
r1verf3nix is offline   Reply With QuoteReply With Quote
Old 09-28-2018, 08:05 PM #11
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
I don’t think that’s what he meant. The DJ comes with a needle style zerk fitting on the top of the ball joint housing (as well as two “standard” style 90 degree zerk fittings, one on each bushing housing).
What I interpreted it as him recommending was removing the needle style zerk fitting and replacing it with a “standard” fitting. The fitting for the ball joint zerk is a 6mm and can be found at most automotive retail outlets.
I’ve heard a couple people chime in that the DJ comes with the optional standard fittings and all you need to do is make the choice to replace the needle style.
It’s also been noted that if you decide to switch out, the optional “dust cap” won’t fit over the top anymore. Which is probably why they chose to go with a needle zerk fitting to begin with.
Personally I’m replacing the needle fitting with a standard unit as I’m not going to be running the dust cap.
And NO, you don’t need to add any grease to the ball joint as it comes pre-greased from Icon. What I would recommend doing is contacting Icon and see what brand of grease they use. I know it’s a moly blend, but sometimes the grease soap of a particular brand doesn’t mix well with another brand and you’ll have to push all the original grease out during maintenance or you could end up with an oily mess running down your coilovers.
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 09-28-2018, 09:08 PM #12
I use this on Delta Joints and U-Joints.
ICON Delta Joint Users - Chime In Here-capture-png
Old 09-28-2018, 10:26 PM #13
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Yes use Li,
Lithium grease on delta joints when that time comes (new are already pregreased as stated by ChrisJHarney) but other than that no issues at all been on for over 12k on my FJ pro suspension.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 03:22 PM #14
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
Sorry to revive an old thread, but I ordered a set of these and was curious about greasing. I just got off the phone with Icon and they said it's fine to use the same moly grease for bushings and delta joints.
Not saying that you're wrong, just curious why you suggest otherwise?
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 03:01 PM #15
My bushings swelled up and had to be replaced after 3months due to lubing with Moly grease.
I had to buy new bushings from ICON, they would not warranty them due to using the wrong grease, your call.
ICON Delta Joint Az4runnin 4th Gen T4Rs 7 09-05-2017 04:01 PM
Icon Delta joint install Question mavrick1903 General Discussions 0 08-03-2017 03:43 PM
Flowmaster super 40 delta flow or 50 series delta flow? Austin12345 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-23-2015 03:27 PM
Leaking CV Joint or Ball Joint?? Hard to Tell - Pics Inside 4WDFTW 4th Gen T4Rs 21 11-06-2014 05:46 PM
What's up? New icon 3.5 in. lift. any other icon users out there? pros and cons? mitymouse6969 New Members 3 02-22-2013 04:58 PM
