01-09-2018, 07:55 PM
#31
Viper, did you need extended rear bump stops to keep the tires from hitting the fender when stuffed at full articulation with the 285s? Thanks.
01-10-2018, 12:35 AM
#32
Tactikool, I have not extended the rear bump stops on either 4Runner.
Keep in mind, I just got this 2017 4Runner, but on my 2015 with a similar suspension/tire set-up, I never had an issue.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
01-10-2018, 12:40 AM
#33
I recently switched the C4 Fab sliders from my wife's 4Runner, over to my new one.
So around Thanksgiving I ordered her the Expedition One sliders, and just installed them tonight..
01-10-2018, 01:03 AM
#34
Are those the powdercoat option Expedition Ones? I've been trying to figure out if their powdercoating includes the steps or not.
01-10-2018, 01:12 AM
#35
Yes sir...I had them do the powdercoating...The bolt on steps I believe are stainless steel. I'm undecided on if I will keep them bare or get them powdercoated as well.
01-10-2018, 01:36 AM
#36
Thank you. I really like the design of the sliders but don't like the uncoated steps. Good to know they could be removed and coated after the fact.
01-22-2018, 02:23 PM
#37
Loving your build so far! Just out of curiosity, what do you have up on your gobi rack behind the maxtrax? I have the same setup you have, but was wondering what im going to put back there (Storage boxes, etc).
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
01-22-2018, 04:49 PM
#38
looks great. love the stance
01-22-2018, 06:21 PM
#39
Icon Stage 3
So I'm the proud owner of a new TRD Premium as of this past Saturday. I've been lurking around trying to learn as much as I can. My question to you is: What led you to the Icon, specifically the Stage 3. I can't discern when to get off the 'stage train'; 1-7. Why was Stage 3 the one you chose?
01-22-2018, 07:00 PM
#40
First, sweet truck.
Second, kind of off topic question but just wondering what's the height of your garage door? I know its a weird question but just want to see if my 4runner will fit with inside my garage with a Gobi rack and yakima ski rack. Pretty much your set up. I am thinking about placing a order of the rack but I am worried that the truck will be too tall.
2017 Toyota 4runner TRD Pro
2012 Toyota Highlander
01-22-2018, 08:24 PM
#41
Very nice truck from fellow Burleson resident.
01-22-2018, 08:30 PM
#42
Thanks man! What you are seeing up there behind the Maxtrax is the Yakima Fat Cat 6 ski rack!
01-22-2018, 08:38 PM
#43
I've always liked Icon, and one of the main reasons why, is the ease of making front height adjustments compared with other options.
I chose Stage 3 because I wanted the extended travel front coilovers, as well as the rear link arms for some added strength.....I didn't really want/need remote reservoir shocks that the upper stages include at this point. Hope that helps!
01-22-2018, 08:41 PM
#44
Originally Posted by speedyglx
First, sweet truck.
My garage at home & at work are both at 84 inches....so got lucky there....I don't have too much room to spare, maybe a couple of inches.
01-22-2018, 08:43 PM
#45
Thanks brother! I hope to see you around one of these days! I assume you have a 5th Gen 4Runner?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
