Originally Posted by brian0128
How do you clean it off in the spring? Pressure washer? I would be interested in having mine done but I’ve already been driving on salty roads for 2 weeks.
Pressure washer hooked onto hot water line...I hit it with Simple Green as well. I go through a bit of cleaner and crank up the water heater temperature, but the amount of dirt the Fluid Film holds by the end of winter is disgusting. It is black instead of its tan color.
If you get it done, you have to make sure to get all the salt off...that is why I do mine early fall...no road salt chances yet.
