12-13-2017, 10:50 AM
Is it true that leaving your headlight setting on "Auto" will damge your HID?
I replaced my headlight bulbs with HID's shortly after I bought it. Then I discovered that my new T4R Limited has an automatic setting for the headlights, so I left the setting on there.
2 months later, I noticed the driver's side headlight would randomly blink. Two nights ago it completely went out. I went back to the place I bought the HID kit and the seller asked me all sorts of questions. He told me not to leave the headlights on "auto" something to do with the car's computer not getting the correct response from the after market HID kit and it keeps sending "power" to the headlight, thinking it's not coming on.
We also found the culprit on why it was not lighting up, the fuse has blown and the ballast was shot (it was hot when we pulled it out).
I thought the seller's explanation made sense, but if he is BS'ing me I would like to know.
Any thoughts, experiences on this matter?
12-13-2017, 10:54 AM
sometimes auto settings will cause your lights to turn on for a brief time such as in a tunnel, this can potentially damage the bulb as HID bulbs don't well with short on/off situations and need time to warm up.
2017 MGM TRD Off Road Premium
12-13-2017, 11:03 AM
Banned
Banned
if this is something you are worried about just use a time delay relay instead of the relay provided with your HID kit, should cost about $20
12-13-2017, 11:12 AM
Didn't know that was an option. Thanks for the info!!!
12-13-2017, 11:43 AM
Real Name: Um, Phil?
Absolutely not. The only thing that is said to be unhealthy for HID is using "flash-to-pass", where repeated very short 'bursts' are used.
The 'auto' setting is no different than turning your lights on/off.
I'd sure like to know who the vendor is.
Let's ask an expert
@ XenonDepot
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
12-13-2017, 12:01 PM
Let's ask an expert
@ XenonDepot
https://en.wikipedia.org/wiki/High-i...discharge_lamp
Specifically - End of life - "Factors of wear come mostly from on/off cycles versus the total on time. The highest wear occurs when the HID burner is ignited while still hot and before the metallic salts have recrystallized."
12-13-2017, 12:21 PM
Real Name: Chris
Real Name: Chris
I've heard of ballasts being damaged by a vehicle starting if the headlights are in the on position because the voltage is spiking while the starter is turning, but not sure the auto would cause this necessarily, although like arehman11 said they can cause your lights to fire on and off if you go through shade or tunnels, but I'd bet the damage was more because the headlights were trying to light while the vehicle was being started, especially if you're not using a relay harness...
12-13-2017, 12:29 PM
I could see that being the case if the auto feature is constantly turning the headlights on and off, but I find that the 4R auto-on/off feature is super conservative and waits forever to turn the headlights on unless it's legitimately dark.
As a data point, I've had my XenonDepot Philips 4300K HIDs installed with auto-on/off always selected for about 6 months now and I haven't had any issues.
@ XenonDepot
can you weigh in?
12-13-2017, 01:12 PM
Let's ask an expert
@ XenonDepot
It is a local mom and pop vendor near my house (a suburb in Northern Orlando).
12-13-2017, 01:49 PM
I can see how the Auto feature can possibly shortening the life of the HID especially if the lights are being turned on-off more compared to turning it on manually. However, the shop's explanation is wrong. The Auto feature is simply a sensor that triggers a relay which send power to the headlights, it is either on or off just like using the manual switch. Sounds like a defective ballast.
2017 SR5P Super White
SCS, Falken, Bilstein, ToyTec, SPC, SSO, Prinsu, Morimoto
12-13-2017, 04:48 PM
... He told me not to leave the headlights on "auto" something to do with the car's computer not getting the correct response from the after market HID kit and it keeps sending "power" to the headlight, thinking it's not coming on.
#1. This guy doesn't know what he's talking about.
#2. I'm more inclined to think crappy components.
12-13-2017, 05:06 PM
Real Name: Caleb
Real Name: Caleb
Our ballasts have a lower start-up draw then a lot of other ballasts, which means that they draw less power when they are first turned on. I had our ballasts installed in my T4R (with no harness) for years with no issues.
Steve
12-13-2017, 05:20 PM
Steve
Steve, it's nice you took the opportunity to plug your product, but I tagged you hoping you'd opine on the OP's question, concerning HID and auto headlights.
12-13-2017, 05:46 PM
He may not, and it might have been a crappy HID kit. This was my first time to try HID's and found a local store that sold it.
The seller is not a crook by any means, in fact he diagnosed what was wrong and replaced the ballast for free.
I consider this a learning experience and as soon as the ones I have burn out, I will definitely buy the best ones.
12-14-2017, 11:37 AM
Real Name: Caleb
Real Name: Caleb
@ philsey
- ballasts having a higher start up draw will have an issue with auto headlights, as there is not enough power going to the ballasts to ignite the bulbs. As a result, the ballasts will lock up, and you'll need to shut the vehicle off, wait a bit, and then try to turn the lights back on.
Steve
