Old 12-18-2017, 03:59 PM #1
enyce enyce is offline
enyce is on a distinguished road
DRL / HighBeam Lights
Just a heads up if anybody run into this problem.
Yesterday I was testing my lights and I noticed the high beam were not turning on when activated. Then all of sudden the DRL lights both went out at the same time.
OK, check the fuses... wait there is no fuse for DRL lights. So i check all the fuses associated with the headlights ( Hi / Lo ). They checked out.
Finally I took a shot in the dark and replaced both DRL lights with 9005 bulbs from a parts store. Lights work now.
Anybody who runs into this issue I would highly recommend checking the DRL bulbs first. After I installed the replacements, I noticed the filament inside the bulbs were broken on both bulbs.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
enyce is offline   Reply With QuoteReply With Quote
Old 12-18-2017, 04:03 PM #2
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
What brand were they? China/Amazon?
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 12-18-2017, 04:57 PM #3
Phillips Crystal Vision Ultra bulbs
Old 12-19-2017, 02:01 AM #4
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Both DRL lights went out at the same time, while you were watching/testing.
You should have bought a lottery ticket.
nglayton is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 01:32 AM #5
grabgrass grabgrass is offline
grabgrass is on a distinguished road
It's those bulbs. I kid you not this exact same thing happened to me a few weeks ago. I didn't see when they went out so i started thinking it was fuses as well. I chased my tail for a few days thinking there's no way they'd both go out at the same time, only a week or so after putting them in. Blew my mind. I'll never buy those over priced Phillips bulbs again.
grabgrass is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 01:43 AM #6
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
The DRL bulb is the High Beam bulb. Go LED and disable the DRLs with the bent pin method & never look back. Better visibility and longevity.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 09:56 AM #7
manganos manganos is offline
manganos is on a distinguished road
Kind sir can you tell us what pin to bend? Pics?
Thanks in advance.
manganos is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 10:44 AM #8
Kenstaroni's Avatar
Kenstaroni Kenstaroni is offline
Kenstaroni is on a distinguished road
Kenstaroni's Avatar
Thanks in advance.
In fuse box in engine bay, there is a grey connector. Pull it off, and bend pin #2, this is the second small pin from the right with connector facing you and large pin on far left. Plug connector back in and no more DRL. Search this as there is a full write up with pics.
I was so excited this mod was so easy as I hated the DRLs..lol
Kenstaroni is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 10:49 AM #9
I did, wasn't lucky.
Old 12-27-2017, 11:00 AM #10
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
Thanks in advance.
This thread:
DRL Disable but keep Auto Headlights
Got to page 4, works like a champ. I did this last week.
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 11:31 AM #11
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
Just curious why disable your drl? It’s been pretty well established that having drl reduce accidents. I updated mine to xenon led. They have been pretty good so far.
mustangr2 is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 12:41 PM #12
CF_Machete's Avatar
CF_Machete's Avatar
Because the DLR mode voltage is less than the HB voltage. This is fine for halogen, but LEDs are voltage specific and it will reduce their lifespan. hence the flicker that you probably have with when using you DRLs... this will burn them out.
If you want to run DRLs with LED HBs, you want to run separate DLRs like a led strip or extra markers.
Old 12-27-2017, 01:46 PM #13
Interesting. Thanks for the info. I thought that is why you install the canbus module to help prolong the life and kill the flickering. Either way thanks for the knowledge drop.
Old 12-27-2017, 02:48 PM #14
CF_Machete's Avatar
CF_Machete's Avatar
Yes and no. The canbus simply puts your DLRs in HB mode all the time. Do you really want to Blind oncoming traffic at Dawn / dusk or on cloudy days?
Old 12-27-2017, 05:08 PM #15
trulli3300's Avatar
trulli3300 trulli3300 is offline
trulli3300 is on a distinguished road
trulli3300's Avatar
Try These
I just put these in two months ago. I've been hesitating thinking they will blind people..etc. Here's my two cents. The dual voltage that is produced in the high beam creates two light intensities. High and low(DRL mode). In DRL mode, they're pretty bright but no one has complained. Because of the low voltage, they flicker but only noticable in your peripheral vision, not central or directly in front of you. Totally fine and hardly noticable. If you flick the high beams on, they will produce all the light they are capable of and become very bright. If you only flash them, it is almost equivalent to the intensity of a flash bulb for photography. So far no problems and certainly much better than the stock halogen bulb. The pictured bulb is not the one that fits the 4Runner
trulli3300 is offline   Reply With QuoteReply With Quote
FS: 5th Gen: 9005 XTREME LED PRO HIGHBEAM/DRL KIT $125 - Chicago Michael M For Sale: T4R Items 2 12-08-2017 12:53 PM
Anyone has actual experience with TRS Morimoto XB LED Headlight as DRL/HighBeam? jicko 5th gen T4Rs 25 05-11-2015 08:54 PM
LED Highbeam/Foglight swap on 2014 LE HomieJaime 5th gen T4Rs 24 10-12-2014 07:53 AM
New headlight/highbeam, fog light bulbs aperionvi Engines / Suspension / Wheels / Tires / Audio / Accessories 5 07-20-2004 08:23 PM
