Originally Posted by Jetboy
The weak link is likely the rear axle. Toyota has never offered an SUV that I know of with a v8 with an 8" rear axle that wasn't awd. I have been curious about swapping in a 100 series or 200 series rear axle as part of an upgrade. Diamond axle makes a bolt in housing to use a 9.5 rear diff. That would be part of the plan for adding a supercharger to a non-limited model for me.
Unless you come up with a way to turn off torque managment... you won't need a bigger diff outside of 4Lo. The added power is not a problem in the higher gears as the torque at the wheels is greatly reduced.
Even though the kit adds lots of usable power there is plenty of ECU nannies limiting stress on the trans and drive-line.
