01-06-2018, 09:11 AM
#16
Originally Posted by e60ral
I'm well versed on what a GP is ;)
I remember back in the day of 16 pill davemades then when I was 13 I recieved my first ham ticket.
Not one place in the vehicle is an earth ground.
Then we can get into the discussion into the antenna and the placement of the antenna. Mounting it on the back with the Rago mount will give you a directional antenna. The best would be to locate the antenna in the middle of the vehicle to get an omni-directional pattern.
01-08-2018, 12:58 PM
#17
@ RagoFabrication
if you could help us on this matter that would be awesome
I was hoping somebody with a Rago CB mount could answer, they seem pretty popular !
What other options are there ? (no metal drilling, specifically for 4R)
TRD Pro 4Runner
All-Pro/Shrockworks Armor
Dobinsons/Dirt King 3in Lift
Rago Fabrication Goodies
01-08-2018, 03:13 PM
#18
Originally Posted by snif6969
@ RagoFabrication
Hey Guys...
For complete honesty....we are NOT CB experts and highly recommend consulting with a local CB shop.
With that being said, we do work with a local CB shop designing and manufacturing mounts for them.
We had a ton of requests for a lower bumper CB mount. This is the solution we came up with. When we consulted with the CB shop, they recommended the set-up we have posted on our website. As far as the routing, so far I haven't seen any one that has taken the time to hide the wires but it can be done with time and patience. We haven't wired ours simply because we don't have the time to tear out the interior to do it.
I know this isn't too helpful but I have sold a TON of them. Join our FB Group - Rago Cool Kids. You will get much more input from our customers.
Melissa Rago
01-08-2018, 04:06 PM
#19
Thanks for the reply
@ RagoFabrication
TRD Pro 4Runner
04-15-2018, 10:21 AM
#20
Anyone have their final solution? I just mounted this and am having high SWR. I may just have to go with the non ground antenna and coax.
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
04-16-2018, 11:37 AM
#21
Spent a good couple of hours last eve trying to get this resolved. The mount looks great, but it is 100% blackcoated. I filed off the bottom of the bracket to try and get better contact with the mount. The mount makes no contact whatsoever with any component of the body chasis. In order to get ground I have temporarily wired directly to the frame. And I do get good ground when tested on a multimeter.
I still get awful SWR. Above 3 on all channels. I have checked the cable as well as ground of the unit. My guess is that there is very poor "grounding plane" from the mount. My only other thought is I trashed the unit checking so many times with high SWR. I'm gonna give it another hour or so before I just head over to a CB shop later in the week and let someone with a lot more knowledge than me trouble shoot it.
2017 F12 Berlinetta
04-16-2018, 12:12 PM
#22
Im currently working on this exact setup (rago mount)
So far the only thing is left is to mount the mount and antenna.
but Im scared to even turn the damn thing on due to all the SWR and Grounding over information.
I bought:
Uniden PRO520XL 40-Channel CB Radio
4ft Black Firefly (B000QB917Q)
18' RG-58A/U Coaxial Cable With Pl-259 Connectors
CB RADIO ANTENNA HEAVY DUTY SO-239 STUD MOUNT (BULK) - FIRESTIK K-4A
Firestik SS-3H Heavy Duty Stainless Steel Antenna Spring
So I have the CB all hooked up and an ready to mount the rago and antenna...I was planning to run a ground to the stud mount and then through the bumper to the frame...and Im wondering what people with this set up did for antenna cable routing?
Last concern is the Antenna tuning. All I have read is "Dont fry your unit" but how in the hell can you tune it knowing it isn't tuned to start with and start adjusting from there? Wouldn't you fry it out of the gate just by trying to tune it? I have some friends lined up to help me tune it with the SWR meter and such, its just I dont get where and how the "frying" gets activated.
2014 SR5 / C4Fab Slimline Bumper w/winch / Extreme LED 30" Lightbar / C4Fab Rock Sliders / Bilstien 5100's / OME 885s Front Springs / Icon 2" rear Springs / TRD Intake / TRD Skid Plate / TRD Wheels / Rally Armor Mud Flaps / General Grabber AT2s / Prinsu Roof Rack / CREE LEDs / Custom Livery
04-16-2018, 12:28 PM
#23
I've your exact same set-up except I went with the Uniden 510XL. I have one other mount here that I am going to try and use this afternoon if I can break away from the kids. Its a holiday here in MA and wifey is out of town on business. I'll PM you if I have any luck. Love the look of the Rago mount and the location, but have my doubts on it. I've also considered a no ground setup.
I got the 510 for 35 bucks so not the end of the world if I fried it.
2017 F12 Berlinetta
04-16-2018, 12:36 PM
#24
Hello guys,
I successfully installed the Rago mount + CB antenna and got it work just right, key is grounding.
I used the Firering cable from Firestik, but the principle is the same with any other cable.
I had to sand down the beautiful Rago powder coat where the firering makes contact with the bracket.
Also on the bracket backing plate, I drilled a hole and installed a flush bolt from which I ran a bonding strap to the trucks body. I will try to provide pictures but the area is pretty hard to access afterwards.
Hope this helps.
TRD Pro 4Runner
04-16-2018, 01:40 PM
#25
Thanks for the info. The Rago piece is beautiful, and I still may try and make it work. However I just tried for kicks another mount that screws into the hatch with Allens. First shot saw an SWR of 1 on channel 1 and 1.6 on Ch 40.
I ordered up a grounding Strap from Amazon yesterday. I'll try your set up and see what I just get just because I love the Rago look so much. .
2017 F12 Berlinetta
06-04-2018, 05:57 PM
#26
Grounding
The y key to make it work and lower your SWR is getting good ground. I drilled a hole on the bumper beneath the mount to bring the cables inside the car. Used 1/2" copper braided flat strap to ground the mount at two point, chasis and body. With that and some antenna trimming I was able to get the entire band with a Firestik KW6-R and also a 102" whip. Longest Bandwidth was with the whip. I also run a ham stick for the 20m ham band. All works great!
06-05-2018, 03:04 AM
#27
Oh thank God someone who actually was able to complete it and posted pics! Been looking for this for awhile now.
Would love to complete my project here as I've done so much work already. Currently the coax is run instead the cab, but I can just as easily reroute it and drill a hole. I have 3 drilled already for the mount, another is not going to hurt.
Did you make a new cable end for yours? I've got the tools, just not the experience with it yet.
Thanks again! Can't wait to see if this fixes my high SWR issue.
06-05-2018, 10:26 AM
#28
You don't have to reroute the coax the ground is what will make the difference. The Rago Mount lacks ground as it is mounted on a plastic bumper. In my case a drilled the hole because I didn't want to deal with the cables every time I opened a door. Ran the cables inside the cabin by taking out the rear driver side break lights housing (drilled a hole in body as well). The coax for both antennas is run inside the panels and ends up beneath the drivers seat were both connect to a Yaesu 857D. I used RG-8X coax and soldered the ends after running the cable. I'll try to take more pics today and post them. The issue is the ground, I was having the same issues as you did. Installed the ground cable and started to see the SWR dips. That's what I used for ground, found it on ebay with terminals an all. See the ground cable circled in blue. I used heat shrink tube on both cables for weather protection.
06-05-2018, 11:14 AM
#29
Real Name: Ben
Real Name: Ben
The product page says this is their recommendation. A grounding strip.
"We recommend a 5ft Firestick, stainless steel spring with ground, and a braided ground strap."
I'll be installing mine this week, so this was a good thread to stumble upon.
2014 Toyota 4runner Limited 4x4 - Rago Fabrications Modular Factory Rail Support System, Fyre Flys LED Interior Kit, OEM Plus Audio JBL Enhancement Package, Shrockworks TE Rocker Trim, Uniden 520XL CB with Wilson Lil Wil Antenna(soon to be Firestik II, 17x8 FN FxPro wheels KO2 385/70/17s, Toytec BOSS Suspension, Tandem Offroad Rock Sliders
06-05-2018, 08:15 PM
#30
Thank you for the response and the pics, really helped seal it alot.
