Originally Posted by DannyLlama
I know this is off topic a bit but I wanted to check to see if there is anyway to "tune" the CB antenna without taking apart my center counsel to get to the unit , since mine is mounted there.
I am getting a lot of noise and want to address it without a SWR meter.
Second part to my question, are there any folks in OC equipped to check out my unit?
Why do you not want to use an SWR meter? For all you know your SWR is sky high and you've already killed your radio. A basic SWR meter is cheap, you can get one on Amazon with 1 or 2 day shipping for probably less than $20
You'll need to get to the end of the antenna cable at the radio to tune the antenna since the cable is part of what you're tuning.
Other than ruling out electronic noise by making sure you have power and ground run direct to the battery, there isnt much else for you to do without tuning the antenna
Sent from my SM-G930V using Tapatalk
