Old 07-10-2018, 12:27 PM #31
jahdai42's Avatar
jahdai42 jahdai42 is offline
jahdai42 is on a distinguished road
jahdai42's Avatar
where is everyone attaching the grounding strap to? My SWR is all the way up in 6 and I checked the ground with a multimeter.
2016 Trail,
jahdai42 is offline   Reply With QuoteReply With Quote
Old 08-08-2018, 04:37 PM #32
bancorat bancorat is offline
bancorat is on a distinguished road
Mine is grounded to both the chassis and body. SWR below 1.5 on the entire band.
Grounding on Rago CB Mounts-img-20180519-wa0018-1-jpg
bancorat is offline   Reply With QuoteReply With Quote
Old 08-08-2018, 07:08 PM #33
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
No reason to ground to chassis
Sent from my SM-G930V using Tapatalk
jhguth is offline   Reply With QuoteReply With Quote
Old 08-08-2018, 07:34 PM #34
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
I know this is off topic a bit but I wanted to check to see if there is anyway to "tune" the CB antenna without taking apart my center counsel to get to the unit , since mine is mounted there.
I am getting a lot of noise and want to address it without a SWR meter.
Second part to my question, are there any folks in OC equipped to check out my unit?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 08-09-2018, 07:07 AM #35
Why do you not want to use an SWR meter? For all you know your SWR is sky high and you've already killed your radio. A basic SWR meter is cheap, you can get one on Amazon with 1 or 2 day shipping for probably less than $20
You'll need to get to the end of the antenna cable at the radio to tune the antenna since the cable is part of what you're tuning.
Other than ruling out electronic noise by making sure you have power and ground run direct to the battery, there isnt much else for you to do without tuning the antenna
Old 12-11-2018, 02:17 PM #36
Hawaiano's Avatar
Hawaiano Hawaiano is offline
Hawaiano is on a distinguished road
Hawaiano's Avatar
Originally Posted by snif6969 View Post
Hello guys,
I successfully installed the Rago mount + CB antenna and got it work just right, key is grounding.
I used the Firering cable from Firestik, but the principle is the same with any other cable.
I had to sand down the beautiful Rago powder coat where the firering makes contact with the bracket.
Also on the bracket backing plate, I drilled a hole and installed a flush bolt from which I ran a bonding strap to the trucks body. I will try to provide pictures but the area is pretty hard to access afterwards.
Hope this helps.
I’m running the same set and have constant high swr and have a few questions. Which part of the body did you run the ground strap to? Also would you be able to post pictures of how you attached it to the backing plate? Even a drawing would be good for me I know it’s a pain to get to that backing plate. Thanks in advanced!
2016 SR5 4x4 midnight metallic, Icon 2.5 with reservoirs front and rear. Icon 2 inch rear springs. Falken Wildpeak AT3W, Nfab Nerf Steps
Hawaiano is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 03:14 PM #37
VARunner03 VARunner03 is offline
VARunner03 is on a distinguished road
Revival
Reviving this thread because I'm looking to do the same setup with my truck. Any updates on anyone's progress?
@bancorat , how long is your grounding strap, and once through the hole you drilled where it does it route through to make it to the frame. I'll likely do the same grounding strap setup that you have.
Thanks in advance!
VARunner03 is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 05:08 PM #38
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
Thanks in advance!
If all the parts come in and the weather cooperates, I will be installing this on the weekend. I have a 30ft grounding strap from work LOL so I will make sure everything works and the antenna's tuned before drilling a hole in my bumper to route it. I will keep you posted.
blksubykid is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 01:40 AM #39
Good luck, I hope everything works out for you. I look forward to hearing how it goes!
Old 02-06-2019, 09:54 AM #40
Thanks in advance!
I have two ground straps connected to the base of the antenna. They are both about 2.5 feet long, one connected to the body and one to the chasis. It is getting the job done for both CB and Ham bands. Good luck with the install, keep us posted!
Old 02-06-2019, 11:36 PM #41
Would you mind posting the link to the ones you have? A lot of the braided grounding straps I'm finding are only like 6-10 inches long. Thanks!
Old 02-07-2019, 09:31 AM #42
This is what I used. 10' x 0.35" Copper Ground Strap Cable+Do-It-Yourself Terminal Kit. Tin Coated | eBay.
Old 02-07-2019, 10:13 AM #43
remember that it's to create a reflective ground plane to reflect the signal up and out (counterpoise is a better term), it's not grounding like creating an electrical ground so if it's much further than a 6-10 inch strap it probably won't make a very effective ground plane.
Old 02-07-2019, 10:52 AM #44
Just like jhguth said, what you want to create is an antenna ground plane to effectively radiate RF from your system.
Old 02-07-2019, 07:36 PM #45
Ok I understand, thank you!
Rago ditch bracket ToyRunner4Me 5th gen T4Rs 4 10-13-2017 09:48 AM
CB antenna mounts.. Specifically hood mounts. michaelreed 4th Gen T4Rs 2 03-16-2012 03:15 PM
The Grounding kit? Anyone done it? Some1esle Classic T4Rs 17 04-20-2006 05:37 PM
grounding steved Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-29-2005 08:39 AM
anyone have the TRD grounding kit? V8Limited4wd Engines / Suspension / Wheels / Tires / Audio / Accessories 15 12-30-2004 12:24 AM
