Old 10-01-2019, 11:27 PM #46
Keech Keech is offline
Keech is on a distinguished road
Originally Posted by snif6969 View Post
Hello guys,
I successfully installed the Rago mount + CB antenna and got it work just right, key is grounding.
I used the Firering cable from Firestik, but the principle is the same with any other cable.
I had to sand down the beautiful Rago powder coat where the firering makes contact with the bracket.
Also on the bracket backing plate, I drilled a hole and installed a flush bolt from which I ran a bonding strap to the trucks body. I will try to provide pictures but the area is pretty hard to access afterwards.
Hope this helps.
Hi where did you run the ground strap from the backing bracket to? IÂ’ve been under the 4Runner for days and can not find a close enough place to connect the strap.
Keech is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 01:43 AM #47
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
Originally Posted by bancorat View Post
I have two ground straps connected to the base of the antenna. They are both about 2.5 feet long, one connected to the body and one to the chasis. It is getting the job done for both CB and Ham bands. Good luck with the install, keep us posted!
bancorat, so one braided cable is mounted to the inside of the vehicle and the other to the bottom of the truck.. somewhere near the spare tire?
macscac is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 09:20 PM #48
The_Reaper's Avatar
The_Reaper The_Reaper is offline
The_Reaper is on a distinguished road
The_Reaper's Avatar
There is a grounding post behind the left tail light inside the panel where the jack mounts. would that not be sufficient to ground the antenna? I don't know much about antennas, I need to learn as well. I just figured any ground that is good enough for my tail/brake lights should be good for an antenna. Unless that causes some weird interference. I just ordered the Rago mount as well, but if that's not going to work well I can mount to my ladder or rack I guess.
The_Reaper is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 08:13 PM #49
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Bump.
Did anyone go with the no ground antenna option with this mount? Curious how that setup is working.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 03:38 PM #50
big44g big44g is offline
Real Name: Gary
big44g is on a distinguished road
Real Name: Gary
Originally Posted by OYOTA TRD View Post
Bump.
I don't have this mount, but I do have two of the Rago ditch bracket antenna mounts (on the hood). I am using a GMRS antenna and Ham 2m/70cm on the other. Both are no ground antennas and work great with no SWR issues. I am sure you can use a no ground antenna on this mount within the GMRS and HAM bands.
_____________________
2016 Magnetic Grey Trail, Southern Style Sliders, Rhino Rack
big44g is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 09:19 PM #51
Bugser's Avatar
Bugser Bugser is offline
Real Name: Bob
Bugser will become famous soon enough
Bugser's Avatar
Real Name: Bob
I do the same as above.....works fine....is it the best? Nope! Better than on the tailgate lip or driver's tail light corner. The best is an NMO mounted dead center of the Runner......did that on all my past vehicles with huge sucess - and leaks. Leaks are why I went the Rago Ditch mount. Also ran Outbackers, Hy-Gain HF cans and single band Firsetick type HF antennas all with success. But in mobile systems, success is relative - can you hear the other station or not.
A good mobile antenna reference site is:
KOBG.COM
Pay particular attention to:
Antenna Myths
Bonding
This is an in-depth discussion by a guy who is very knowledgeable on the subject...... It may take you a while to digest it though!
Cheers
Bob
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
Bugser is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 11:09 PM #52
Mudhorn's Avatar
Mudhorn's Avatar
Thanks for the info. My needs are very basic, just for comms with trail buddies. Never too far apart.
Definitely keep all the info in my pocket if I ever upgrade needs.
Old 01-17-2021, 05:37 PM #53
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Any updates on this?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 03:53 PM #54
bancorat bancorat is offline
bancorat is on a distinguished road
Yes, I used a ring terminal on the braid and attached it to one of the chasis bolts near the spare tire. The other is connected to the body inside the tail light housing where the jack is. Sorry for the late reply.
bancorat is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 11:30 PM #55
Schriner13 Schriner13 is offline
Schriner13 is on a distinguished road
Just installed my mount. Tried running a braided ground to body and frame of the mounting bracket back plate with no luck. Ground off powder coat where fire ring makes contact and ground the recesses where the screw heads go. Swr is 3.5+ with a 5’ fire stick
Schriner13 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 12:10 PM #56
Brick Sprickly's Avatar
Brick Sprickly Brick Sprickly is offline
Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light
I have this same mount/antenna setup.
Did you grind both the top and bottom of the fire ring connection? Seemed to work better for me. Also, since the grounding strap is attached to the backing plate under the bumper area, you'll also have to remove some powder coat on a screw hole top surface of the mount (the inside beveled surface). This way, the screw itself will connect your ground to the chassis via the backing plate to the strap.
Fire ring-->bracket mount-->screw-->backing plate-->braided ground strap-->chassis
I think you're on the right track but there might be something minor preventing a good connection. I also used dielectric grease throughout.
Lastly, how/what did you do to run the coax to the front? Which route did you take? Do you have excess coax you had to coil up anywhere? Pinched/crimped coax at odd angles?
2019 TRD Pro Voodoo Blue "Cobra Commander"
Brick Sprickly is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 02:00 PM #57
Grounding on Rago CB Mounts
I ground all the screw heads still no go. Ran coax through bumper up behind til light and then down inside the paneling all the way to drivers seat then under into the consol. No Loups or kinks. Continuity where I should and none where I shouldn’t
Old 04-08-2021, 02:07 PM #58
Can you post a pic of ur setup outside of the vehicle? Also where did u mount the strap to the body
Old 04-08-2021, 03:59 PM #59
Might be an issue with where you mounted the grounding strap then. I picked this spot:
Old 04-10-2021, 07:45 PM #60
Got it working moved the ground strap a few times and finally got it to work of the grounding post in the compartment the factory jack goes in
Rago ditch bracket ToyRunner4Me 5th gen T4Rs 4 10-13-2017 09:48 AM
CB antenna mounts.. Specifically hood mounts. michaelreed 4th Gen T4Rs 2 03-16-2012 03:15 PM
The Grounding kit? Anyone done it? Some1esle Classic T4Rs 17 04-20-2006 05:37 PM
grounding steved Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-29-2005 08:39 AM
anyone have the TRD grounding kit? V8Limited4wd Engines / Suspension / Wheels / Tires / Audio / Accessories 15 12-30-2004 12:24 AM
