Old 09-13-2022, 12:00 AM #1
ToyRunner4Me ToyRunner4Me is offline
ToyRunner4Me is on a distinguished road
Truck dances side to side or steering wheel feedback
hi,
It's been awhile since I have posted. I wanted to share my experience and maybe it might help someone who is having a similar problem. Recently when I drive on the highway and on on the city streets, I would feel a feedback on the steering when I go over a bump, a dip or even breaking. In the canyons, the VSC would kick in which it didn't before. I wasn't sure if this was normal or not. I check my suspension for leaks, sway bar, KDSS, alignment, etc. I recalibrated the KDSS and no luck. I drove my friend's 4r to see if his was the same. I then drove my 4r on the same path (freeway with bumps and dips). Mine was not solid. I notice that the 4r would dance side to side or steering wheel feedback when I let go of the gas pedal because I wanted to keep a distance from the car ahead. The 4r would dance again when I step on the accelerator. From this I thought it was the rear panhard bar. After inspection, the culprit was the rear driver side upper link. The nut had come off. I didn't want to take it into the dealer cause I don't trust them, can't find a good KDSS mechanic and didn't want to pay an arm/leg for the fix.
ToyRunner4Me is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 09:09 PM #2
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
So what did you end up doing: DIY on the nut or take it to a Mech?
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 09-14-2022, 07:08 PM #3
I have a spare nut. I used red lock tite and a lock washer. Getting the 17 mm socket in the tight spot to torque was not doable so I had to use a box end adaptor for the 3/8 wrench. I torque it to 59 ft/lb.
Truck dances side to side or steering wheel feedback-img_20220914_160416-jpg
Old 09-15-2022, 12:05 PM #4
apc9199's Avatar
apc9199 apc9199 is offline
apc9199 will become famous soon enough
apc9199's Avatar
I need to check this on mine. I have almost exactly those same issues since I bought my 2015 4Runner used in 2020 and the Dealership cannot figure it out.
apc9199 is offline   Reply With QuoteReply With Quote
feedback , kdss , rear , side , steering
Missing something on the left side of the steering wheel? Neel 4th Gen T4Rs 6 02-10-2010 09:54 AM
right side steering wheel control mod? rraabb11 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-03-2006 04:23 PM
Steering Controls on the Right Side of the Steering Wheel subzero Engines / Suspension / Wheels / Tires / Audio / Accessories 10 08-03-2006 05:16 AM
'04 RIGHT SIDE steering wheel controls trdtim Engines / Suspension / Wheels / Tires / Audio / Accessories 13 02-17-2006 07:50 PM
Right side steering wheel with SWI-X in Works! trdtim Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-16-2006 04:20 PM
