Old 01-05-2018, 03:09 PM #1
snif6969's Avatar
snif6969 snif6969 is offline
snif6969 is on a distinguished road
snif6969's Avatar
Grounding on Rago CB Mounts
Hello Friends,
How did you ground your Rago CB mount ?
Since it's installed sandwiching the plastic bumper...
I'm guessing I also need to strip the paint by the mount/antenna mating surface
Thanks for your input
TRD Pro 4Runner
All-Pro/Shrockworks Armor
Dobinsons/Dirt King 3in Lift
Rago Fabrication Goodies
snif6969 is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 03:30 PM #2
vtecturtle vtecturtle is offline
vtecturtle is on a distinguished road
Originally Posted by snif6969 View Post
Hello Friends,
been meaning to post this. curious too. I got everything installed radio and all, didnt get to ground it so its not working yet.. Thinking maybe a longer ground and run it inside to ground? I google it and just see them mounted and not even wired.
vtecturtle is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 03:33 PM #3
boyguan boyguan is offline
boyguan is on a distinguished road
even on my diamond mount i ran its own ground and out it onto the plate. Since its a sandwhich plate and grounds from the entire plate. Run a wire and ground it from the back side to the chassis.
boyguan is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 03:38 PM #4
snif6969's Avatar
snif6969's Avatar
I know ! All the pics are missing the wiring !
TRD Pro 4Runner
Old 01-05-2018, 03:42 PM #5
snif6969's Avatar
snif6969's Avatar
Starting to think that - wire a ground from the rear drivers side light to the inner part of the mount.
Now the question is - are those screws a good grounding method ?
TRD Pro 4Runner
Old 01-05-2018, 03:55 PM #6
should be. test it with a multimeter after. Usually threads are not coated and should ground easily
Old 01-05-2018, 04:01 PM #7
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
RF grounds =/= electrical grounds, make sure you use a grounding strap and not just a wire
If this is for CB i would probably just get an NGP antenna though, you won't really be grounding to anything that makes sense as a ground plane in that location.
e60ral is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 04:05 PM #8
Zapper Zapper is offline
Real Name: Erick
Zapper is on a distinguished road
Real Name: Erick
Where is your mount located? Mine is on the passenger side of the hood. I ran a ground wire down to a bolt that was grounded. Some bolts attached to the body are not grounded, so check with a meter. Don't forget to tune your radio.
2016 TRD PRO... 275/70 KO2, SSO Bumper, Smittybilt X20 Winch, SSO Sliders, OME BP-51suspension-3" lift, RCI full skids, 3D Maxpride floor mats, XenonDepot 5K HIDs and LED fogs, ARB drawer/floor slide for fridge, ARB Element 63qt
Zapper is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 04:33 PM #9
snif6969's Avatar
snif6969's Avatar
I don't really know the difference to be honest, what should I look for ?
Yeah friend of mine has a SWR meter for that purpose
I will be using the Rago Antenna mount with a Firestik, just like in this pic:
TRD Pro 4Runner
Old 01-05-2018, 05:09 PM #10
maybe ill just run a strap with the antenna wire?
Ill be doing a new rear bumper so this mount will only be temporary but i would like to get this working already lol
Grounding on Rago CB Mounts-img_7217-jpg  Grounding on Rago CB Mounts-img_7216-jpg  Grounding on Rago CB Mounts-img_7221-jpg
Old 01-05-2018, 05:21 PM #11
snif6969's Avatar
snif6969's Avatar
Gosh that red antenna looks dope !
To be honest I'm not sure what's the preferred grounding method,
Antenna to mount to truck ?
Antenna to truck ?
TRD Pro 4Runner
Old 01-05-2018, 05:24 PM #12
manganos manganos is offline
manganos is on a distinguished road
OK OK - this is really a bonding issue and not a grounding issue since the vehicle is not really grounded at all.
manganos is offline   Reply With QuoteReply With Quote
Old 01-05-2018, 05:35 PM #13
Antenna to truck ?
thanks and beats me. Thats what im here for
touche
Old 01-05-2018, 05:36 PM #14
Banned
Banned
RF is on the skin of the wire, so RF grounding straps are usually flat braided cables so they have a lot of surface area. The orientation of the ground plane matters, so if you are using the rear quarter panel as a ground plane it's not the ideal orientation for antenna performance.
This is a poor description, but you can kind of think of the ground plane as what reflects the radio waves so the rear quarter panel is a weird orientation for reflecting radio waves from the antenna. You could also get a No Ground Plane (NGP) antenna which is specifically tuned to not need a ground plane.
If you just need enough range for trail coms I doubt it will make enough difference to matter, but if you are mounting to a plastic panel I would probably just get an NGP antenna and not worry about it. Firestik makes NGP antennas.
https://en.wikipedia.org/wiki/Ground_plane
Old 01-05-2018, 08:35 PM #15
CoolMax's Avatar
CoolMax CoolMax is offline
CoolMax will become famous soon enough
CoolMax's Avatar
@RagoFabrication
2013 Classic Silver Metallic Trail Edition w/ KDSS
CoolMax is offline   Reply With QuoteReply With Quote
Rago ditch bracket ToyRunner4Me 5th gen T4Rs 4 10-13-2017 09:48 AM
CB antenna mounts.. Specifically hood mounts. michaelreed 4th Gen T4Rs 2 03-16-2012 03:15 PM
The Grounding kit? Anyone done it? Some1esle Classic T4Rs 17 04-20-2006 05:37 PM
grounding steved Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-29-2005 08:39 AM
anyone have the TRD grounding kit? V8Limited4wd Engines / Suspension / Wheels / Tires / Audio / Accessories 15 12-30-2004 12:24 AM
