Old 01-07-2018, 01:18 AM #1
jayhat's Avatar
jayhat jayhat is offline
jayhat is on a distinguished road
jayhat's Avatar
Compressor on rago modular storage panels?
Has anyone mounted a compressor inside the cabin on a rago modular storage panel?
Also (and this may seem ghetto) but could you drill holes in the little platform on a portable viair or smitty built compressor and mount that sideways on a storage panel? My thought was to cut the alligator clips off, solder on an Anderson connector, and run an Anderson to the rear cargo area.
jayhat is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 02:05 AM #2
Kenstaroni's Avatar
Kenstaroni Kenstaroni is offline
Kenstaroni is on a distinguished road
Kenstaroni's Avatar
Interesting idea, can't think of a reason why not at the moment. I've got the Orangeboxx ones and a Viair 400p myself...hmm....lol. Think Viair says just not to mount them upside down, I'll do some more research.
Kenstaroni is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 10:46 AM #3
lmturne1's Avatar
lmturne1 lmturne1 is offline
Real Name: Logan Turner
lmturne1 is on a distinguished road
lmturne1's Avatar
Your issue won't be mounting one, rather supplying the necessary power to the unit that has a significant amp draw so far from the battery. I know the ARB harness is ~6ft, but from the cargo area, you'll need at least double that and a larger gauge wire to compensate for the additional distance.
Final thoughts: Mount in the engine bay, or prepare to work for it.
'15 TEP. | ICON Stage 3 w/ Overland Springs & 700lb Coils | Billet Upper & Lower Links | ICON Track Bar | 285/75 Nitto Trail | Gobi Stealth | ARB Awning | ARB Twin Comp. | ARB Breathers | Geared and Locked | ARB Skids | Pelican Storage | Rigid Ind. | Switchpro | Rago Fab Molle | Pelfreybilt Front | Pelfreybilt Sliders | CBI Rear | Safari Snorkel | Vinyl Wrap | Warn Zeon 10-S |
lmturne1 is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 12:11 PM #4
jayhat's Avatar
jayhat's Avatar
So thatís a big beefy ARB, but what about a smaller portable? Are those pretty amp hungry? Sorry Iím decently savvy with electrical stuff, but the technical aspects of it - amp draw, understanding when youíll need higher gauge wire, what gauge youíll need, etc - are a bit beyond my understanding. I figured if a compressor has 10 awg wire on its leads, you could extend that ~10 feet with the same gauge wire.
Old 01-07-2018, 12:36 PM #5
Kenstaroni's Avatar
Kenstaroni's Avatar
I would think 8ga, maybe even 10 would be fine. Fused at the battery, ran in vehicle or underneath and come up in the Jack storage area, then route to location on PSD. If you ran it all on the driver side so it's on the battery side, and mounted to Driver PSD, distance wouldnt be too bad.
Old 01-07-2018, 12:49 PM #6
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
Just mount it in the engine bay.
I don't own a 4Runner anymore.
LawnDart is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 12:59 PM #7
Draggin Draggin is offline
Real Name: Ken
Draggin is on a distinguished road
Real Name: Ken
- An air compressor in an open cabin would be really loud.
- They also vibrate like crazy and if your mounting points aren't really solid that may be an issue. Even on a ground mount to a plate the portable VIAIR 450P wore through it's rubber mounts in 2-3 years.
Draggin is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 01:18 PM #8
jayhat's Avatar
jayhat's Avatar
I donít really want an arb at this point. I also want a dual battery with the second in the front battery location. This requires moving the secondary air pump and washer reservoir to the rear passenger location in the engine bay - the location everyone mounts the arb.
Old 01-07-2018, 01:20 PM #9
jayhat's Avatar
jayhat's Avatar
Good points.
Old 01-07-2018, 01:37 PM #10
LawnDart's Avatar
LawnDart's Avatar
And the amount of work required to route an air comp to the back of the vehicle on to window panel mounts is baffling easier?
An air compressor is going to be a far more valuable use of space, and a higher priority than a dual battery.
Old 01-07-2018, 02:00 PM #11
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a jewel in the rough Xtremluck is a jewel in the rough Xtremluck is a jewel in the rough
Xtremluck's Avatar
I would also be concerned about safety. Air compressors are not light and it would be the last thing I would want flinging at me or my passengers in a collision.
'12 Silver 4Runner SR5: 14+ facelift, Pelfreybilt front, CBI Rear, Warn M-8000S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, Icon CDCV suspension w/UCAs, OME 899, Nitto RG 285s, Full RCI Skids, Metaltech Sliders, Gobi Rack, ARB Awning, Rotopax,1up Hitch Rack
Xtremluck's 2012 SR5 Build Thread
Instagram - @Aperture20
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 02:13 PM #12
LawnDart's Avatar
LawnDart's Avatar
They also tend to get pretty hot. I've personally never seen an air comp explode, but it IS a pressure vessel after all.
That said they get excessively hot during long work cycles, like airing up 6 tires, or 3-4 vehicles because I seem to be the ONLY guy on a run with a compressor because everyone else is lazy and don't have theirs.
Old 01-07-2018, 02:52 PM #13
HerT4R's Avatar
HerT4R HerT4R is offline
HerT4R will become famous soon enough
HerT4R's Avatar
@jayhat , I am going to second LawnDart here. He is right. I at one point thought I would do the dual battery before the ARB Dual air compressor and the air compressor came first (in the passenger firewall location on a Bandimount) and I cannot even begin to describe how useful the compressor has been (tubes for boating, air mattresses, compressed air for cleaning things off, tires, etc.)
To put it in perspective I went ahead with a solar setup and the compressor over a dual battery setup. (Dual is still on my radar) but I would NEVER move the compressor out of the engine bay. It gets hot, its loud, and i like not having to open any doors (not even the hood) to get to the air. Also the ARB dual is HEAVY, maybe too heavy for where you want to put it (unless i missed it and you wanted to go with a smaller, lighter air compressor).
I understand you are going to do what you want to do, but seriously contemplate your REAL needs and then make a decision.
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
HerT4R is offline   Reply With QuoteReply With Quote
Old 01-07-2018, 05:00 PM #14
jayhat's Avatar
jayhat's Avatar
I guess I donít understand why it matters what order I buy MY stuff in. I also already have a portable viair that works just fine for now.
The reason I want a dual battery (and also a SPOD) first is I want my electrical system in order before I add anymore electric stuff. I donít want to wire a bunch of stuff to my primary battery only to have to move it all to a second battery, reroute/re cut/terminate wire etc.
Is there any other location in the engine bay to mount the arb ASIDE from the time passenger rear engine bay location?
Old 01-07-2018, 05:05 PM #15
jayhat's Avatar
jayhat's Avatar
I am super paranoid about that. All my gear (a lot) is stored in sturdy boxes, strapped down with weight rated straps and biners, and covered with a safari straps weight rated big cargo net. Believe me, Iíd take that into account. There is way more gear and weight in the back than an arb compressor already.
I am not saying I will do this but if it did, it would be mounted to a steel platform with steel bolts. I am fairly sure it would be very stout. I was actually asking more about my current viair compressor vs the arb. No idea how heavy an arb dual is but my viair is not that heavy.
Modular storage panel comparison - Rago, Orangeboxx derryck 5th gen T4Rs 17 08-07-2020 07:34 PM
Rago Modular Factory Rail Support System RagoFabrication 5th gen T4Rs 40 12-16-2019 07:11 PM
4th Gen Modular Storage Panel RagoFabrication 4th Gen T4Rs 44 09-22-2018 02:07 AM
Installing Rago Fabrication Modular Panel - 3rd gen 4runner - **Pictures!** ramonortiz55 3rd gen T4Rs 28 12-03-2017 02:18 PM
Rago modular panel storage Dane Hauler General Discussions 15 10-21-2017 08:08 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
