01-17-2019, 04:12 PM
#31
Originally Posted by gdvan01
Thanks for the links. I ordered these. Figured they are worth a shot being that they are Amazon Prime.
2019 TRD Off-Road Premium
285 Cooper STT Pros - Tandem Offroad 612 Charlie in bronze
Dobinsons - Front: C59-300, GS59-574 Rear: C59-505, GS59-701 - JBA UCAs
RSG Metalworks Sliders - Angled - RCI Skids
01-17-2019, 11:03 PM
#32
Real Name: George
Real Name: George
Mine are still going strong...
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
01-18-2019, 07:23 AM
#33
Good to hear. I will probably put mine in this weekend, depending on the cold.
02-27-2019, 01:45 PM
#34
I'm looking to order LEDs for the interior of my 2019 LE. So many choices here!
Few of questions here:
1) The HD Pro kit offers a choice between Pure, warm and bright whites. I'm tending towards warm for interior and pure for the tail gate but do you know the color temps of these and what have others bought?
2) While I would like really bright interior lights when parked I am concerned about them being used when driving (map light for example). Any solutions to this? What kind of brightness are these bulbs?
3) Do we need Canbus bulbs for the limited?
Reason: Added addition question.
02-27-2019, 03:25 PM
#35
4Runner Interior LED Light Swap
Originally Posted by GreyBear
We went with the set from HID Kit Pros based on the excellent install video by WanderLost. (One of the LEDs for the map/puddle light was defective, though.) WanderLost didn't show the puddle light install and when we saw how someone else did a big dissassemby of the mirror housing, we skipped it.
I see the the HID Kit Pro kit and it’s a bit more expensive that some of the others. Doing it all except the license plate lights comes so $99 including shipping. Is it worth the extra money over other bulbs out there?
Also has anyone tried there CREE reversing lights?
02-27-2019, 05:16 PM
#36
Real Name: Chris
Real Name: Chris
I think the HID Pro Kit is overpriced for what it is
03-08-2019, 10:44 PM
#37
HID Kit interior lighting
We didn't shop around or try to compare LED types. I was disappointed that one was broken at the solder connection. I figured I could solder it back on but there was no way due to the minimalist construction approach. While putting them in I was worried about breaking them. So I'd guess they are no better than others, but don't know how good/bad others are.
These are definitely brighter than stock, but not to the point of interfering with driving, IMO. I went with the warm color for the interior and I like result so it was good choice for me. In my only other experience, I once replaced some camper lights with LEDs and the blue tint was awful so didn't want to risk "pure white" casting the bluish tint here.
__________________________________________________ __
2017 T4R Off Road Premium, KO2 tires, Bilstein shocks, OME springs, SPC UCA, Front Runner 3/4ths rack, RSG rock sliders, C4 Fab aux battery tray, Eaton 31S relay/fuse box, Blue Sea ACR, Molex ML-XT connectors, Air-On-Board push switches, Rago ditch light brackets, VisionX pod and scene lights, Rago rear window molle panels, rear diff+locker breather relocation, C4 Summit hatch ladder, custom flip up license plate holder, Dometic fridge DIY box, DIY drawer bank, DIY power panel with solar controller.
04-16-2019, 05:58 PM
#38
How did you guys get the LED bulbs to fit the dome light receptacles?
Now, I tried this on a 4th gen, a 2007 SR5, but these flat wouldn't work even though the fitment chart shows they do. I looked at pictures of some of what you guys posted here, and the ends/contacts look the same, which results in an effective length too long, and a tip too blunt. my vehicle has in the receptacle contacts that have openings in them, and the OEM bulb has a spike on the tip each end that must be fitted in those holes/slot to secure the bulb. the LED did not have these, and the ends were blunt, rather than sharp-sloped like the OEM bulb - it would just pop right out
Anourney 6Pcs DE3175 DE3021 DE3022 C5W 31mm/1.25'' Festoon LED Bulb, 2
4 SMDs 3014 Chipset LED Replacement Bulbs for Internior Car Licese Plate
Dome Map Lights DC 12V with 12 Month Warranty
https://www.amazon.com/Anourney-Fest.../dp/B07L9NXXFH
04-16-2019, 06:42 PM
#39
I bent one of the domelight's metal tabs back a little bit more
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
04-17-2019, 01:12 AM
#40
Originally Posted by RobotTrader
Another option here would be arclightleds. He's a 4runner owner and custom built his interior LEDs that can switch between red and white. While they're expensive he does give you anywhere from 50 to 100+ LEDs on a panel vs others that give you around 10 at most. Plus they give back some functionality with the red LEDs as a bright white light firefly LED is almost useless and dangerous when driving at night.
I started with the map lights and then got the dome and tailgate lights, all of them switchable.
The instructions are very well written, and I love the ability to use the red lights at night.
Only downside is the price. But they are certainly well made.
2018 4Runner TRDORP MGM MODS: TRD Intake, full set of ARCLight Icraus Premium lights,Precision LED interior door/exterior lights, Rago MOLLE panels, Ellis Precision shift knobs w/Custom engraving, N-Fab nerf bars, 3-1 LED DRL/Fog lights.
04-17-2019, 11:27 AM
#41
Originally Posted by 97BlackAckCL
It's really not bad, if you pry off just the back shell you run the risk of breaking the clips that hold the shell in. I've seen others mention that. Honestly the mirrors take about 5 minutes, you pop off the mirror which is 4 clips then you can access the clips that hold the back shell piece on, then it's just a couple screws, very simple.
Here's what it looks like inside
And here's where the bulb is
Having done this 2 or 3 times now I really recommend just removing the mirror glass and then popping the painted shell off. It really just makes it easier to access everything without breaking the clips. Like I said, 5 minutes tops, reassembly is also simple, the turn signal and trim pieces literally snap back into place, easy peasy
Doing this, have you noticed any shake in the mirror while driving? I swapped out the bulbs in my Lexus GS450h and now the mirror has a noticeable shake while driving on highway speeds. Is this a problem with the 4runner?
04-17-2019, 12:24 PM
#42
Real Name: Chris
Real Name: Chris
I've had my mirrors apart 2 or 3 times and haven't noticed any rattling, just make sure not to break the clips
04-17-2019, 12:44 PM
#43
@robtotrader
What's the point of the red light on the tailgate? Can you explain how that's used?
Build thread
04-17-2019, 02:29 PM
#44
Originally Posted by mscot
@robtotrader
Bugs are not generally attracted to red lights, so if you are out camping, or just unloading the back at night, you won't attract bugs when the tailgate is open.
Or if you and your SO camp in the back, you can use them for general lighting without lighting up the whole cabin with white light if the other person is asleep.
04-17-2019, 04:46 PM
#45
I put the red LEDs on the mirror lights that point down when you unlock the vehicle with the FOB. Just because it looks cool. All the others are white.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
