10-08-2018, 05:35 PM
#46
Real Name: Jonny
Real Name: Jonny
Originally Posted by dot_tom
Thanks! I need to do a proper BMC (currently just have it trimmed enough to clear the 295s off-road) and pound down the pinch welds and hammer on the firewall a bit and then trim up the fenders some more. Then take it off road and figure out where else it needs some work.
Yeah, I hear ya. I’m running 285/75/17’s on a 2.5 lift. got a bit of work to do.
09-11-2019, 09:13 PM
#47
17x9 -38 F5’s on 2.5” Front lift and 2” rear lift and 285 KO2’s. A good bit of front bumper and fender liner trimming. Also trimmed the body mount. Removed mud flaps. No issues.
17x8.5 -10 with 285s would be easy to fit. 265's would be almost no work.
Were you running stock UCA's when you ran the 17x9 -38?
09-11-2019, 10:13 PM
#48
How does the 4.56 work with your 295s? Can you do 75 without too high of an RPM? Did you add a front locker when you did the swap?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
09-12-2019, 10:03 AM
#49
Real Name: Tom
Real Name: Tom
Where I live we all drive about 80-85 MPH on the highway. Does it no problem. After doing the 4.56 and full bumpers I could see how 4.88 would be awesome. 4.56 and 295 is great though. No issues.
I did not do the front locker. Just didn't have the extra coin at the time and my long travel rear setup helps greatly. But nothing beats a front locker.
Yes, and now I have Icon UCA's.
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
01-29-2020, 12:03 PM
#50
so there seems to be conflicting info in here. can anyone answer whether I will have issues with the F5 17x8.5 -10 offset 4.3 backspace with stock tire size and no lift?
01-29-2020, 08:33 PM
#51
Real Name: Ron
Real Name: Ron
It's hard to get the answer you want. I think a 1" wheel spacer with the stock 4th gen wheel will be very close to the 17x8.5 -10 (4.30 backspace). If possible to get one 1" spacer and put on before you order just to get an idea of what you will run into.
Maybe.
01-30-2020, 12:02 AM
#52
Maybe.
I talked to SCS on instagram since they dont have a phone number. they said it will fit will "very light" trimming of the fender liners and removing or heating part of the front mudflap.
01-31-2020, 10:42 PM
#53
Real Name: Ron
Real Name: Ron
At least they seem to know and didn't BS you and say there wouldn't be any rubbing.
02-23-2020, 11:33 PM
#54
Anyone run 285’s on a stock TRD PRO with F5’s? Considering a bmc but wondering if necessary.
05-21-2020, 03:16 AM
#55
17x8.5 -10 with 265 wildpeaks on trd pro suspension? might run 1.5"/1" top spacer later. Would like to keep my flaps and not trim bumper.. anyone know?
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
05-21-2020, 06:16 AM
#56
Real Name: Don
Real Name: Don
I’m running stock size tires on my new SCS wheels on my Pro. No issues with rubbing. Hope this helps. You just get a better look on the tires with the fatter wheel.
05-21-2020, 09:01 AM
#57
After reading a lot on this topic I don’t think there is a clear black and white answer.
I have Ray’s 10 (8.5”) running 265 AT3W (32”) with Rally Armor flaps and with stock suspension I get rubbing at full turn forward or reverse on the drivers side at full lock.
The mud flaps are less of an issue than stock but not as good as these from Rokblokz that have a cutout for the BM. Plus the Rally Armors are a ice magnet.
Toyota 4Runner (5th Gen) 2014-2018 Mud Flaps – RokBlokz
I have I lift sitting and waiting to be installed life just seems to constantly get in the way.
Front: 6112, 4th clip setting, 1/2” spacers (1” ish lift), JBA UCAs, Wheelers bump stops. This should net me 2.75-3” lift up front
Rear: 5160, Eibach load leveling coils and bump stops 250#, Black Gate Customs KDSS spacer (waiting on this). I can then adjust as needed for level with a trailer.
I know not compressed I will not have rubbing, but I am addressing it now knowing at full compassion I still could have issues. First step will be the Rokblokz flaps (not running flaps is just not an option for me), then a BMC at RSG if needed. I want to run 255/80 17 AT3Ws next and want to be prepared as well.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
02-18-2023, 01:57 AM
#58
Real Name: Vince
Real Name: Vince
I’m doing my research here before I buy an aftermarket wheels. I’m running TRD OR wheels, 295/17s, lifted 3/2”. However when I tried to add 1.25 spidertrax spacers after BMC…. It rubs. What offset do you guys recommend on my set up? What specs do these TRD wheels have?
