01-27-2018, 05:32 PM
Real Name: Um, Phil?
PSA: So, have you ever checked your spare?
No? I suggest you learn now, before you're on the side of the road .... at night ... in the rain/snow.
Why? Because it's a PITA, and you really should check the pressure anyway. (Mine was 49#)
Helpful hints: Take a flashlight, the owner's manual, a phillips, and something to lay on.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
01-27-2018, 06:36 PM
Something go wrong last night in the dark rain?
I check my spare twice a year. Every time I install, and then remove the studded winter tires. It's easy to drop it a bit and check the pressure when the rig is on the lift.
01-27-2018, 06:44 PM
Real Name: BobH
Real Name: BobH
Reposting an old one of mine. Yes, it's a PITA.
Spare Tire Access 2013 TE
01-27-2018, 06:58 PM
Real Name: Chris
Real Name: Chris
Lube the crank mechanism at least a couple times a year also. I do it twice a year when I check the tire pressure. Really not a big deal to get to at all though, very simple to crank down and back up.
01-27-2018, 07:07 PM
Ha. No. Just getting ready for the winter road trip to warmer places, and it occurred to me what it would be like learning in shitty conditions.
01-27-2018, 08:35 PM
I check it several times a year and look at it as a competition with myself to see how fast I can crank the spare down and back up. Could be a handy skill in the breakdown lane.
Plus-I keep the PSI a few pounds above what is needed in case I get lazy and forget to check it.
01-27-2018, 08:37 PM
I was hoping you were going to tell us how to do it. Disappointed.
01-27-2018, 08:38 PM
I added an after market hose to mine so I can check it without dropping the tire. Unfortunately can't remember where I got it from
01-27-2018, 08:48 PM
Very small opening & from lack of use I can't find much in the dark like I used too !!!!
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
01-27-2018, 10:32 PM
Real Name: Dave
Real Name: Dave
Originally Posted by BobsTrail
After I figured out how to let it down, I put the spare back with the valve stem facing down, but toward the front, closer to the diff for less chance of ripping it off when off road. No more hassle to check the pressure, although I usually don't check it due to laziness
We need an updated version for the Pro.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
01-27-2018, 11:27 PM
Real Name: Jeff
Real Name: Jeff
Wait...
We have a SPARE?!!!
HERE FISHY FISHY FISHY!
01-27-2018, 11:59 PM
Real Name: Dave
Real Name: Dave
Check that spare
Two summers ago I checked the spare in my 1995 Jeep Grand Cherokee, Orvis Edition in preparation for a long trip into Zion and Grand Staircase Escalante. It sits in the back cargo area under a leather cover and I hadn't looked at the spare for about 10 years. I took it out of the back and checked the air pressure. Zero, nada, no pressure. That would have been useless in case of a flat. I filled it and it's been fine for two years now.
Yes, check that spare. I've been working on a lift of my 4Runner for the last few days, lying under the car a lot. The spare catches a lot of dust when off road. The crank mechanism is covered in dirt that's stuck to the grease. That's getting cleaned and lubed before I put the spare back.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
01-28-2018, 09:47 AM
I only help the kids with homework, I don't do it for them.
01-28-2018, 10:46 AM
Know that there is a slight angle you have to master to lower the the tire. Once you know that it is easy. I want to say it's about 10 degrees towards to the drivers side. You will be there all day unless you figure that out.
2016 TEP
01-28-2018, 11:35 AM
With a proper inflator you don’t have to lower the tire and it takes 5 seconds to check the pressure. I check mine everything I check the rest of my tires (once a month).
