02-20-2018, 12:12 PM
#16
Originally Posted by WallyT4R
My warranty expired anyhow but as far as I know unless they can directly tie a failure to a mod they have to honor the warranty.
As for cost,, look at how much we spend on less practical mods. 200$ is chump change compared to some of the stuff I have done, Like the 2K I just spent on a front bumper and winch.
02-20-2018, 12:13 PM
#17
^Be curious to know this too. I saw they have a remote location adapter, which to me make the most sense. I can’t imagine screwing a 4” tall filter directly to the adapter, seems like a scary scenario even with skids (if it even fits?), one good hit...
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
02-20-2018, 12:16 PM
#18
Sorry to hijack but would love to know how much clearance? I have the RCI aluminum skids also...If that aluminum skid was to pushed in from a rock hit or whatever, would it contact the filter?? Would the remote adapter be better?? Thanks, and again sorry for the hijack but it's not worth separate thread.
There's about an inch of clearance, the filter sets pretty far forward so it would take a really high and hard hit to make contact at that point in the skid. A remote would be an option but I didn't want to mess with the lines and the extra cost.
The XG16 is a little over 3.5 inches tall fwiw.
02-20-2018, 12:58 PM
#19
Oil-related failure will only concern the engine, and that will be expensive. They will say "no" and the owner will have to sure them for it. Engine work can exceed the small claims court limit, thus capping recoverable damages at that limit or requiring an attorney, which costs $$$.
So while you are correct, it may not matter. If Toyota says "no" then it gets ugly.
02-20-2018, 09:25 PM
#20
I don't expect there to be any issues with this mod,it was pretty simple and not near as complicated as say doing a front and rear lift, (not spacer). The Here is a couple of pics of the install. The Baxter part is very well made, heck it's a piece of art, and the Fram filter is highly rated.
So I used the Fram XG16 because it is the biggest I could comfortably install however, I did have to cut a un-used tab a bit to make sure there would be no issues when the engine flexes on the motor mounts, to 2 minutes to cut and paint. Baxter recomends the Mobil M1-102 filter which is plug and play. I wanted more surface area so I went with the XG16.
Baxter installed.
The piece cut from the un-used tab. About 2"x.5"
Where the tab was cut.
Finished product,, tons of room and can still access the filter through the "door" in the RCI skid.
02-20-2018, 11:20 PM
#21
interesting. I like this.
02-21-2018, 12:12 AM
#22
Real Name: Derrick
Real Name: Derrick
I was going to suggest this as well. If you are going to go through the trouble, it might be worth swapping the type of oil filter to make the whole thing easier. I went a step further and did the remote mount one on my 4Runner:
It was definitely on the expensive side and it doesn't come with -10AN lines or fittings for the lines (like the article in the Toyota Mag suggested). But it makes oil changes a lot easier. I used to have to take the skid plates off to get to the filter and it was a pain in the ass. Now, oil changes are a breeze.
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
02-21-2018, 12:21 AM
#23
Clever mounting location. Very cool.
02-21-2018, 12:25 AM
#24
Real Name: Derrick
Real Name: Derrick
Thanks, but I have to remount it soon. I ordered the Magnuson supercharger after this was installed only to realize it will interfere. It's okay though, I bought slightly longer lines that are black steel braided instead of that silver, which I like a lot better. So once Magnuson FINALLY starts to deliver their kits to California customers, I'll have to remote it somewhere.
02-21-2018, 10:40 AM
#25
My 2006 Tacoma 4.0 liter had the filter in that location. It was so easy to change. Never understood why Toyota changed it. Maybe cuz no one used the dealer to change the oil lol.
-2016 7%'er---RCI aluminum skids; C4Fab sliders; Rago Fab modular storage panels; Complete 3M ceramic tint; The Ultimate Camping Mod; Xenondepot HID kit; BFG KO2's
-1967 Stephens M416 military trailer---slow build
02-21-2018, 12:40 PM
#26
Sorry for the n00b question but did you find that you needed to add more oil due to addition of the oil lines? Also, can you post a pic from underneath?
02-21-2018, 12:48 PM
#27
Real Name: Derrick
Real Name: Derrick
Yes, but not very much.
02-21-2018, 12:50 PM
#28
Awesome. thx
02-21-2018, 02:16 PM
#29
Real Name: Dave
Real Name: Dave
Remote oil filter mounts
This is a great idea. I wonder if you considered mounting the oil filter inverted, with the spin-on threads pointing down, so the oil doesn't drain out of the filter when you remove it? The -10AN fittings come with 90 and 180 degree bends so running the lines straight is fairly easy.
I see several choices in remote oil filter mounts on Amazon. What brand is this one and is it any better than the $25 to $50 remote filter mounts I see on Amazon? Baxter does not show remote filter mounts, just the spin-on fitting with hose connection ports.
As far as I can tell in a quick search, 4 fittings and 2 hoses might cost up to 4x$9 + 2x$25 = $86. The Baxter oil filter location adapter for the 4Runner, with hose fitting ports, cost either $180 or $230, depending on whether it's side fittings or straight down fittings. Either one could work.
Thanks,
Dave
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
02-21-2018, 02:23 PM
#30
Real Name: Derrick
Real Name: Derrick
Thanks,
Dave
The mount catches the oil as it drains (has a small spill tray) so having it facing up isn't an issue (in fact it makes filter changes even easier). This is the Baxter mount, here is the link to the product:
Inverted Remote Oil Filter Mount
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
