Originally Posted by Havik
They aren't race cars, that is true, but they are vehicles that tend to not be even on smooth pavement. They tend to be on inclines/declines and/or leaning. This coupled with a wet sump oiling system can lead to oil starvation. Having even oil pressure helps. Also, if keeping things stock is your thing, why are you on this forum?
Stock sucks!
If you are driving on a slope steep enough to cause oil starvation, your filter isn't going to help, no matter if it is TDR bling or oem. ....custom oil pans and pickup tubes designed for that type of driving are available that help somewhat. Do you have one? Even with a special oil pan, if the slope is steep enough you will lose oil pressure, so you better shut off the engine and use your winch.
BTW--stock does just fine for most people. If you are a rock-crawler/hopper that drives super technical trails , what are YOU doing on this forum?
Now back to the original thread....pardon my rudeness.
