Old 03-18-2018, 07:50 PM #1
supertrdpro supertrdpro is offline
supertrdpro is on a distinguished road
2017 4runner trd pro squeaking issue!!!?HELP
My car just started squeaking on the passenger side interior. It sounds like it is coming from the dash or A pillar. Anyone else have this issue and also has a fix for this problem, its driving me crazy!
thank you
supertrdpro is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 06:33 PM #2
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
I have this issue too - same model. About to post on it and doing a search. Have you learned anything since posting this? Its unacceptable.
rob_dixon is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 06:51 PM #3
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
I developed this after my first dusty trip with the 4R and found that it was dirt between the dash & window, cleaned it, went away. Another trip, same sound, same solution. No idea why it was happening, just was.
Grape Ape is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 07:11 PM #4
rsimi72 rsimi72 is offline
rsimi72 is on a distinguished road
To clarify. Are you saying you cleaned between your dash (inside) and windshield or between your wiper cowling (outside) and windshield?
rsimi72 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 08:18 PM #5
rob_dixon's Avatar
rob_dixon's Avatar
Ha its funny you said this (dirt). Because I first noticed it after every time I went offroad on dirt trails. Because of it going away, and because I only noticed after being in dusty conditions I first believed this was dust particles rubbing against the window that eventually got swept away or “ground” down to where there was no longer an issue. However a dust spray can did not resolve the issue and then I noticed the squeaking even when the truck is clean and has not been taken off road. I also thought maybe it was temperature related, but this also does not seem to be the case – it is now common whether in 110 degree Phoenix heat, or 64 degree SF bay area chill.
It has been driving me crazy, which is how i found this post.
SO i dug further, and found the cause in the amazing forum. After sorting through a ton of posts and the fact that people define "rattle", "squeaking" and "clicking" all differently or interchangeably (come on guys, these are all very different sounds!!) I found these threads and now know it is 1 of 2 causes:
1) The fender liner (this was a 100% fix for some)
2) The windshield plastic trim piece in the corner of the windshield. (this was also a 100% for others - note the author of this solution specifically found the other (fender) didn't work and vice versa.
So is 100% one of those 2 things.
My "windshield creak/tick" and how I fixed it.
This is exactly my sound and issue, complete with Youtube video of the sound.
A squeaking/crackling noise resolved
Major Squeaking issue! (interior/A-Pillar)
I also found this buried on one form the service manuals (apparently)
T-SB-0141-10 Upper/Lower Windshield/Rear Glass Tick Noise
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, or at the top of the rear glass, the source of the noise may be the two stoppers bonded to the top of the windshield/rear glass, or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield/rear glass area.
Anyhoo.....this is a very common problem. I plan to do the fender fix myself and take it in to the dealer if it does fix it.
Old 08-12-2019, 08:37 PM #6
The fender liner is super easy to check. Before popping any clips, you might try gorilla tape to secure the rubber splash guard. If it fixes it, you can do the more permanent fix with new clips or the double-sided tape. Also, it’s pretty easy to pop those corner pieces at the base of the windshield if that’s what you are referring to. Pop them out and if the sound stops, either secure them better or get new ones. I just ordered new ones. Good luck.
Old 08-12-2019, 09:03 PM #7
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
Might try adjusting the hood bumper cushions. By unscrewing them, you increase the height of the cushion thereby increasing tension on the hood latch.
It eliminated the squeak I was having in my interior and also the squeak it made when I closed the door.
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 10:55 PM #8
rob_dixon's Avatar
rob_dixon's Avatar
This was it.
I recorded this with sound but do not know how to upload it so you can hear it.
4runner squeak found! - Album on Imgur
Old 08-21-2019, 11:01 AM #9
This was it.
Congrats! I assume you are adding 3M tape behind the rubber splash guard or buying more secure clips. I have been waiting for my gorilla tape to fail to do the same but that darn tape is holding strong after 18 months.
Old 08-21-2019, 01:04 PM #10
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
For splash guard "squeak" I used a drop of rtv (silicone) under each clip... it was about 3 yers ago- no issues.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 04:19 PM #11
mnelson71ss mnelson71ss is offline
mnelson71ss is on a distinguished road
Thumbs up Problem Solved - Thanks!
Had the same clicking annoyance on my new 2021 Off Road. Tried the wiper supply hose fix but it turned out to be the fender liner clips. On mine, the top two clips closet to the firewall on each side were engineered too small for the hole. A quick trip to Ace for some larger dia. clips and rubber washers to increase the thickness of the factory liner and the problem is solved.
I'm new to this forum but definitely not new to Toyotas. Anyway, I appreciate the info. Phantom squeaks and clicks drive me crazy. Thanks again!
mnelson71ss is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 10:40 PM #12
Gingahrunnah's Avatar
Gingahrunnah Gingahrunnah is offline
Gingahrunnah is on a distinguished road
This bothered me for months and I finally found the right combination of keywords and determination to locate people reporting the same issue. My wife thought I was crazy... she thought I was even more crazy when I discovered the culprit and wouldn’t stop celebrating.
Gingahrunnah is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 11:22 AM #13
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Just tell her it's like when she finds just the right cute shoes that she has been looking everywhere for.
delloro is offline   Reply With QuoteReply With Quote
2017 LE electrical issue BettysNephew 5th gen T4Rs 18 12-30-2017 11:43 PM
2017 4Runner TRD Off Road Premium (my 5th 4Runner 83-2017) nikilicious General Discussions 22 09-12-2017 12:06 AM
Spring 2017 Toyota Cruisers & Trucks issue *FREE* to download jediwebdude General Discussions 1 06-28-2017 11:50 AM
TCT Magazine 2017 Winter issue - free to download jediwebdude General Discussions 1 03-05-2017 10:31 AM
95 4runner squeaking.... 4runnercaruso Classic T4Rs 3 08-02-2012 05:27 PM
