02-08-2019, 07:45 PM
#61
Thanks would love to see it!
02-20-2019, 09:25 PM
#62
Has anyone mounted a RTT on the Rhino 3/4 Rack?
03-04-2019, 01:27 AM
#63
I have the Pioneer 49 by 76 version and getting a ton of wind noise at about 50 mph. Has anyone used the flaring with the sunroof? It looks like it may be an issue as the 76 inch lands right in the middle of the sunroof.
03-04-2019, 10:07 AM
#64
Possible Fix
I was told a way to reduce the noise is to apply Gorilla Tape across the underside of the crossbars. I don’t know if this works or not but it is on my list of things to do.
03-05-2019, 02:45 PM
#65
RLT v Backbone
Thanks for all the helpful info. Apologies if I missed it somewhere in here, but I can't figure out if there's any functional difference between the RLT mounts and the Backbone. Is there a max load difference? It it purely aesthetic? Does anyone have insight?
Thanks.
04-19-2019, 09:48 PM
#66
for those running the rhino rack backbone rails. how do the rails do "naked" any issues taking the platform off when not in use and just leaving the rails up there with no cross rails or anything else?
also how is the overall wind noise with the pioneer platform 76"
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
04-20-2019, 09:32 AM
#67
I have the 83” version sitting in my basement, really glad I read your post. I just had a very simular issue with aero Yakima bars. They have a t-slot channel on the bottom as well. I used with without installing their rubber filler and they were really loud. Installed their rubber filler, no issues now. So this tip of using tape makes total sense. Thanks
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
06-08-2019, 01:35 PM
#68
Thanks for this. It is exactly what I’ve been looking for. My Rhino Rack 3/4 Backbone and Pioneer Rack arrived yesterday. Can’t wait to install. These posts have been very helpful in helping visualize the process.
06-09-2019, 08:25 PM
#69
Finally got it installed. Pic is too big to upload. I will have to do it from my pc tomorrow. Installed per directions and the rear door does not open. Turned the platform around and the rear door opens perfectly. 4 points of contact. I will have to drill the platform to take advantage of the middle mount.
06-10-2019, 07:48 AM
#70
Here are the pics. You can't tell the clearance when the rear door is open, but it's about a half inch.
06-10-2019, 07:51 AM
#71
Rail
Has anyone used the rail system for the Rhino Rack? If so, are they worth it?
06-14-2019, 03:52 PM
#72
Real Name: Duan
Real Name: Duan
Rhino-Rack Install Write Up
OP did you follow the drilling guidelines that were in the backbone instructions?
I'm a little perplexed because I drilled the holes and when I put the rack up top,I found that the portion that was drilled doesn't even come close to the mounting tabs on the backbone.
2018 TRD Off Road Premium
Rotiform SIX-OR | Toyo Open Country RT 285/70/17 | Bilstein 6612/5160 OME 2895 | Rhino Rack | Valentine One | Rexing Dashcam
IG: @daohaus
06-14-2019, 08:03 PM
#73
I have rails running the length of both sides. They work great giving me a point to tie down kayaks, paddleboards and the cargo bag for it. Highly recommend .
06-14-2019, 09:29 PM
#74
Yeah there is no way it will work, I have the 83” and it just barely cleared the sunroof. It is recessed and hits the underside of the rack preventing it from being moved forward to allow the air to go up and over the rack. The fairing made the noise worse for me. Working on using the parts to design a fairing on top vs. on bottom to see if that helps, plus wind deflection over my RTT. I prototyped a fairing going from the roof up and over the rack by 7 inches using the Rhino parts. The size of the fairing was ridicules
Really a poor design by Rhino for this application
06-15-2019, 05:11 PM
#75
The easiest way to do it is dry fit the rack on the backbone system exactly where you want it to sit. Mark on the rack where you need to drill the holes.
"The rack has 3 cross bars that must be bolted to the underside of the rack. Placement of these crossbars is determined where you want the rack to sit on the Backbone system. This is where you will have to drill the rack in order to align the crossbars in the correct location. If you mount the rack too far forward on the Backbone rails you will hit the XM “shark fin” antenna, if you mount the rack too far toward the rear of the vehicle you may have an issue opening the hatch if you have a ladder installed."
Car History from 1st to Present: -1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro (Sold ); 1982 Jeep CJ-7; 2014 Trail 4Runner
The creator of the "TRAIL" badge
http://www.toyota-4runner.org/5th-ge...blem-made.html
