06-15-2019, 06:45 PM
#76
Real Name: Duan
Real Name: Duan
Originally Posted by On Point
The easiest way to do it is dry fit the rack on the backbone system exactly where you want it to sit. Mark on the rack where you need to drill the holes.
"The rack has 3 cross bars that must be bolted to the underside of the rack. Placement of these crossbars is determined where you want the rack to sit on the Backbone system. This is where you will have to drill the rack in order to align the crossbars in the correct location. If you mount the rack too far forward on the Backbone rails you will hit the XM “shark fin” antenna, if you mount the rack too far toward the rear of the vehicle you may have an issue opening the hatch if you have a ladder installed."
I did that yesterday. I took it per the manual 125 mm from the rear.
I got confused and forgot to bolt the crossbars so I had to take the platform off and bolt it up
2018 TRD Off Road Premium
Rotiform SIX-OR | Toyo Open Country RT 285/70/17 | Bilstein 6612/5160 OME 2895 | Rhino Rack | Valentine One | Rexing Dashcam
IG: @daohaus
06-16-2019, 09:42 AM
#77
Originally Posted by SnowYeti
Yeah there is no way it will work, I have the 83” and it just barely cleared the sunroof. It is recessed and hits the underside of the rack preventing it from being moved forward to allow the air to go up and over the rack. The fairing made the noise worse for me. Working on using the parts to design a fairing on top vs. on bottom to see if that helps, plus wind deflection over my RTT. I prototyped a fairing going from the roof up and over the rack by 7 inches using the Rhino parts. The size of the fairing was ridicules
Really a poor design by Rhino for this application
I bought the fairing as well and took it off after 2 weeks as it would make flapping noises. i adjusted several times and could not get to sit right or help with wind noise. Sucks as its non-returnable. Rhino owes me!
2019 4Runner - Silver with KDSS, RCI steel engine skid, RCI aluminum gas tank skid, Cooper AT3 LT (2018 version) 265/70/17, 3/4 Rhino Rack on backbone system, Philips X-tremeUltinon Fog Lights
2015 Inferno TRD Pro - Sold
06-16-2019, 07:42 PM
#78
Real Name: Duan
Real Name: Duan
I adjusted the fairing today and moved it back a bit as it was making this horrid squeaking noise with the rubber pad on the roof. Hopefully it'll fix it
IG: @daohaus
06-17-2019, 01:14 PM
#79
Real Name: Duan
Real Name: Duan
is it just me or am i doing something wrong.
The last "twist" nut is being stubborn with me and will not go fully perpendicular to the crossbar to securely lock in place.
Is there a technique for this? do you manually rotate the "twist" nut or will it rotate into it's place as you're tightening it? I've been manually rotating it on the other mounting points.
The twist “nuts” turn 90* into the underside channel of the crossbar and tighten down to secure the rack. There will be 6 points that this will be done at.
*Note – this twist “nut” turns into the channel of the crossbars that you had to mount and/or drill to the underside of the rack.
IG: @daohaus
06-17-2019, 04:26 PM
#80
i'm sure you've tried it, but make sure the twist nut is in the correct orientation. also, if i recall, i believe I twisted it manually and then held in place with my finger as I tightened the bolt.
Car History from 1st to Present: -1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro (Sold ); 1982 Jeep CJ-7; 2014 Trail 4Runner
The creator of the "TRAIL" badge
http://www.toyota-4runner.org/5th-ge...blem-made.html
06-17-2019, 05:48 PM
#81
Real Name: Duan
Real Name: Duan
thanks, definitely making sure that it's sitting int he channel nicely.
i'll try to tighten it and see if it rotates itself or if i should revert back to manually rotating it
IG: @daohaus
06-17-2019, 07:36 PM
#82
I did two things
Held it pushed up as I tightened by hand as mention
Also there was very light friction between the bolt and the t-slot nut. I added some blue thread locker and let it dry for about an hour. This really helped to make sure the nut rotated. Frankly I was getting pretty frustrated before I did this
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
06-19-2019, 05:01 PM
#83
Real Name: Duan
Real Name: Duan
I did two things
Man, i feel you on that frustration.
The one I was having problems with was the driver's side crossbar closest to the driver's door. I looked and the crossbar channel wasn't in perfect alignment with the backbone so it made the rotation of the t-nut that much more difficult. I loosened up that bolt that secured the crossbar and tapped it into place and it worked out.
So glad it's over because it was getting on my nerves.
IG: @daohaus
06-23-2019, 06:02 PM
#84
Originally Posted by DanHampton
I have rails running the length of both sides. They work great giving me a point to tie down kayaks, paddleboards and the cargo bag for it. Highly recommend .
I took your advice. I like them. They are functional AND they look good. Thanks for the recommendation. Now I’m just waiting for the lift kit to come in and then I’ll be done...maybe 😂
07-12-2019, 04:01 PM
#85
I thought that too, then came the gobi ladder, the ko2's, accessories for the rack, sliders...... It'll never end .
07-12-2019, 04:13 PM
#86
I am wrapping up my custom fairing. I used most of the hardware and parts supplied for the Rhino version (which was a terrible design) and flipped them to the top. Designed a 1/8th in aluminum fairing and had it water jet cut, then bedliner. I have a SS hardware sent out to PCbolts for black powder coating.
Wind noise is drastically reduced, very close to no rack levels. Highway speeds with the sunroof open are no longer an issue. Once I get my RTT I will post more photos showing how it will divert the air over it.
12-17-2019, 09:27 PM
#87
Issues with backbone, not the platform.
Trying to install the Rhino Rack Backbone on my '16 trail and found the mounting holes in the backbone are smaller than the white plastic threaded tubing that they mount to on the 4runner. I had assumed the white tubes would fit into the mounting holes of the backbone, but they do not.
According to Rhino Rack, the backbone sits on the threaded tubes and the white threaded tubing will be pushed into the roof of the 4runner when the backbone is tightened down.
I asked if the backbone could be removed without the threaded tubing falling into the headliner and Rhino Rack said, "We have never had to remove a backbone and are unsure if the threaded tubing would be accessible if the backbone was ever removed."
Is this how everyone has installed their backbone rails?? They sit on top of the white threaded tubes and are tightened down until the tubes are pushed into the roof?
My apologies for posting on an old thread. I'm at a loss as to how this makes sense or how to proceed...but I"m no genius. Any advice would be greatly appreciated.
12-18-2019, 01:28 AM
#88
Real Name: John
Real Name: John
Yes it is okay to perch the backbone rails on top of the plastic bolt sleeves. They will compress as you tighten the bolts to secure the backbone rails to the roof.
One thing I strongly recommend is to go heavy on the butyl tape and waterproofing of the holes. One of my friends recommended this to me after she had to re-do her installation because water got into the headliner of her FJ. When I did mine I put down a double layer of tape and injected silicone into the bolt holes. It’s been five months and no evidence of leaking.
One other thing that I did was to swap out the provided channel nuts with ones that have springs on the back (they’re standard M8 by the way). On my first install attempt I had a terrible time getting the channel nuts to stay square in the channels while I started the bolts on them.
Also I mounted my rack well forward to clear the tailgate ladder so I had to raise it up to clear the roof antenna. I did so with machined aluminum spacers and stainless steel fender washers to provide a generous perch for the c-channel.
2015 T4R SR5 in Super White
03-08-2020, 07:01 PM
#89
@ Arishtat
Do you know what size unistrut nuts you used? I can't stand the factory Rhino design and would like to do something similar to the ones you are showing.
