03-20-2018, 11:49 PM
#31
Real Name: Dave
Real Name: Dave
On line gambling
Joined in March. 1 post.
Is this a spam or a scam? Advertising gambling is not permitted on this site.
You've been reported.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
03-21-2018, 12:06 AM
#32
Real Name: Dave
Real Name: Dave
Bottle jack & Hi Lift
Anyone using a 6 ton jack is overkilling the job. And a jack that big weighs a lot. I've got a 20 ton jack I used for lifting girders under houses. I don't carry that jack very far and you could lose 2 mpg putting that steel boulder in your car.
If the car weighs 5000 pounds and 60% is on the front axle, or 30% on either front wheel, then you need to lift 1500 pounds. That's 3/4 ton. The only reason to get anything bigger than a 2 ton jack (4000 pounds) is if the jack height needs to be taller. For my lift I bought a 4 ton jack just because it was taller. I have a floor jack for working in the garage. And I used jack stands once I got it lifted.
I think the standard OEM jack is a worm gear screw jack, not hydraulic. But it will always work no matter how you treat it. If you leave a bottle jack on it's side for a while the fluid can run out.
I've looked at HiLift jacks quite a bit. It's the ticket when you can't get under the truck. But I see very few places on the truck where you can use it, other than the rock sliders.
I've used the ratchet jacks on older cars, but not since I was a kid. Those cars had slots in the bumper where the ratchet lever was inserted.
03-21-2018, 12:20 AM
#33
Originally Posted by rkwfxd
Got a link?
amazon sells it, but I've actually seen them at home depot of all places.
03-21-2018, 01:18 AM
#34
Originally Posted by ADK Explorer
Ha ! I'm 55. When I was a teenager these were in the back of every car. I've changed a lot of tires on the sides of roads with them.
Been there, done that. They worked just fine for me too.
03-21-2018, 09:09 AM
#35
Found it.
Thank you
03-21-2018, 09:51 AM
#36
Real Name: Steve
Real Name: Steve
I've got ten years on you, and never had a car with a bumper jack. Those were on US cars with bumpers as high as your waist. ;) My Model A didn't have a jack, My VWs had a screw jack that fit in a slot under the running board, Fiat and Mitsubishi had scissors jacks, and MG has a bottle jack. The Ranger and F150 had bottle jacks. Then back to scissors jacks on the Subarus.
Like most replies, I carry the factory bottle jack and a couple scraps of 2X12.
Steve - Northern Ohio, USA
2021 Toyota LC200 - 2017 Hiker Squareback Trailer - 1958 MGA Roadster
Wandering around on occasion, always lost
03-21-2018, 10:45 AM
#37
Originally Posted by Jay_P
You carry this around all the time, or just on the trails? Seems like it would be a huge thing to lug around full time.
Depends It usually stays in my truck 99.9% of the time, the handle is mounted with quick fists to the hatch and the jack stays strapped down with my tool bag in the back corner. The 1.5 ton has a pretty small footprint and weighs maybe 10 lbs at most so it really hasn't gotten in my way and if I need to fold the seats flat all of it fits on the rear floorboard's with the seats folded. Its been nice the couple times I've used to help change random peoples tires lol.
I do need to get around to making a removable extension and the skid plate/ sand float for it (they sell them but I'm to cheap to buy something I can make myself)
I have maybe $200 total in truck tools.
kobalt 119 pc socket set - $24.75 on sale lowes
harbor freight 1.5 ton jack- $59.99 plus 20% coupon
Stanley soft tool bag- under $15 on amazon
beat up makita li-ion impact- $10 yard sale
harbor freight moving blanket- $9
couple shackles- free
a couple crescent wrenches, 3/8 extensions, socket adapters, breakerbar, metric and SAE allen key set, pliers, dykes, bunch of large zipties, roll of duct tape, baggy of bolts and nuts, box of wood screws, pack of jb weld and a tire plug kit, probably some other stuff I'm forgetting in that bag but its all had its use for us before either out shooting and fixing targets, wheeling fixing jeeps, helping some old lady change a tire, or pulling parts at the junk yard.
Old pics. Nothing is strapped down, no tool bag in pic, etc. Gives you an idea of the size of the jack and how the handles mount. Everything usually rides in the driver corner with a ratchet strap. It works okay for now until I get free time to build cargo drawers with a dedicated jack mount which will probably be in 20never.
2014 sr5 premium bilstein 5100's 1.75", 17" method NV, LT285/70 falken wildpeak a/t3w, hids, full led swap, custom sliders
2013 ktm 500exc desmog, euro mapped, supermoto
1951 chevy 3100 bagged and body dropped in progress
IG: r.tinniste
03-21-2018, 10:54 AM
#38
I've had a couple of different setups over the past 8 years.
Used a HiLift, which can be very effective, especially with the ARB footprint thing, but it can also be very deathly. I've had my hilift fall out a handful of times, luckily most of the time hubs were dropped on soft dirt or sand.
Next jack was the safejack by Bogart Designs. Those jack extensions work well if you buy a quality bottleneck jack. Don't do what I did and get a cheap Torin from amazon.
My last setup is the pro eagle and it's the best! I keep mine on the back of the passenger seat directly behind the driver, it fits perfectly on the back folded down (*ratchet strap that thing down, wouldn't want that thing flying around in an accident). Works on loose rock, mud, sand, whatever! Might even weight less than a hi lift!
Andrew
2010 Battleship Grey SR5 4x4
Sweet mod list.
03-21-2018, 11:06 AM
#39
That jack is way smaller than I pictured. Doesn't seem to take up much space at all.
2018 4R SR5 4x4 | 2" RC Leveling Kit | 17" Method NV Wheels | 285/70/17 Falken Wildpeak AT3 | 32" AuxBeam Light Bar | Amber Grill Marker Lights | Xenon Depot 5k HID's
IG: Jessyam_ph
03-21-2018, 01:04 PM
#40
Just need a solid piece of wood with the HF racing jack and you are good to go!
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
03-21-2018, 02:15 PM
#41
harbor freight 1.5 ton aluminum jack. Still haven't gotten around to making a skid plate for it
How high does that get the t4R? Max height listed at 14 & 3/4" which doesn't seem like a lot??? I'm trying to decide which jack to buy
03-21-2018, 02:24 PM
#42
OEM bottle screw jack and 4x 12"-2x4's 100% effective 98% of the time
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
03-21-2018, 05:10 PM
#43
Enough to lift from the axle and the A-arm's and get my 285's a inch or so off the ground. You would need to buy or make an extension to make it really useful.
I'm sure you could make one of these work or just make something along the lines.
https://www.kartek.com/parts/kartek-...el-flange.html
https://www.kartek.com/parts/pro-eag...ry-1-inch.html
IG: r.tinniste
03-21-2018, 06:50 PM
#44
My friend recently gave me his small jack. i believe it holds 1ton?
03-21-2018, 08:02 PM
#45
I carry some tire plugs and have an ARB compressor. Hopefully that covers most incidents. If not factory jack.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
scissor jacks
platch |
3rd gen T4Rs |
10 |
05-27-2014 07:11 PM |
Floor jacks?
ebg18t |
4th Gen T4Rs |
10 |
01-13-2013 04:19 PM |
Floor Jacks?
cangler |
Maintenance/Detailing |
7 |
04-12-2012 10:16 AM |
My jacks too small
noobshooter |
4th Gen T4Rs |
16 |
02-27-2012 11:46 PM |
4Runner jacks
Bill_V |
3rd gen T4Rs |
12 |
08-15-2008 02:41 AM |
