Thread Tools Rating: Thread Rating: 6 votes, 3.33 average. Display Modes
Old 07-22-2020, 01:12 PM #61
fred smith fred smith is offline
fred smith is on a distinguished road
TIS techstream
Originally Posted by fvlewg65 View Post
If you buy the TIS Techstream from Amazon ($100) then you can program your own TPMS sensors and not have to worry about the light, you can even adjust the psi that turns on the light, set it to 5psi and never have the light go on again!
Which model techstream advertized on amazon will allow me to change the tire pressure in the TPMS on my 4 runner?
fred smith is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 01:11 PM #62
Disable TPMS 2017 4 runner
Originally Posted by zeindog View Post
Since this is my first post here I couldnt start a new thread, however, I do believe I have the bypass solution for 5th gens. I have a 2018, I bought access to toyotas technical information system to download the schematics. It turned out to be the same as my 2014 Tacoma. The tpms light needs to see 3.2v or higher to stay off, unlike a ground on older generations. No big deal heres what I did. Drop the drivers side dash panel below the column. Look to the left of the column and there should be a gray box with one bolt holding it to the subdash. Unplug the wiring and locate pin 5&6, dark green and light green next to each other. The dark greeb is the light output, and the light green is 5vdc supply to the antenna module. Jumper those two wires together and plug it back into the module. The test is when you turn your ignition on you should no longer see the tpms light. I havnt driven yet but so far this looks like the solution many including myself has been after.
I am not an electrician BUT you state "tpms light needs to see 3.2v or higher to stay off, unlike a ground on older generations" I do not understand how a bulb needs 3.2v to stay OFF.
I so want to disable this system, but need to understand your logic. Please be kind enough to reply
Old 07-23-2020, 01:18 PM #63
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
I use the old school TMPS. That was call LATAC (Look At Tire And Check) - "Hmm. Looks a bit low, I should check that."
When did mankind become so dependent on technology that it was mandated by the feds that I can't determine when my tires are off. It's not like it won't drive funny if it's low.
itr1275 is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 12:29 PM #64
WayMaker WayMaker is offline
WayMaker is on a distinguished road
Just wanted to say thanks to zeindog. I installed this solution this morning on my 2018 SR5.
I had ICON Rebounds installed a couple days ago and the tire shop couldn’t install the oem TPM sensors without scratching the wheels (they claim).
So happy to find this workaround.
WayMaker is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 01:01 PM #65
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
2020 is much more user friendly.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 08:28 PM #66
guatepa's Avatar
guatepa guatepa is offline
Real Name: Donald
guatepa is on a distinguished road
guatepa's Avatar
Real Name: Donald
Great pics, easy to follow. Worked great for me as well. Thank you ZEINDOG for posting on the bypass.
2010 4Runner Trail, ARB/OME, 275/70-17 BFG KO2
guatepa is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 03:51 PM #67
I took the plunge and followed the instructions, knowing that if it did not work, I could just undo the connection. It worked ! and I must thank you for the posting. I still do not know however, why or how a bulb needs 3.2V to stay OFF. If anyone can help educate me, please help.
Regards to all, and many thanks,
Old 11-30-2020, 05:23 PM #68
bwoody bwoody is offline
bwoody is on a distinguished road
thanks for this fix, just bought a 4runner and one TPMS must be bad, have manually checked all the tires. Light still on.
bwoody is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 10:20 PM #69
agoff71 agoff71 is offline
agoff71 is on a distinguished road
I believe run flat tires required TPMS cause they could pass the eye test but be flat.
Sent from my moto z3 using Tapatalk
agoff71 is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 04:43 PM #70
Run flats were originally for sports cars with out the space for a spare tire, like a Corvette. Then the became mainstream when the manufactures figured out they can delete the spare to "add cargo space" and pass along the cost of a $8 flat to a $300 tire. Oh wait that specific tires is out of stock, on back order or no longer available. Lets replace all 4 for $1500.
They don't belong on everyday cars for regular people.
Old 12-15-2020, 07:33 PM #71
johnnymac johnnymac is offline
johnnymac is on a distinguished road
Buy from amazon
Hi, I would like to purchase a tool to do this and not bypass the sensor...but I understand there are multiple parts! Turn on the sensor, read the sensor, and then save it in the ECU (or somewhere).
Since my local Toyota will charge me $300 if the sensors have to be reprogrammed, I want to just purchase the tool and go anywhere to swap the tires.
I have a 2014 4Runner.
Preferably I get a tool doesn't need a PC...but what is best for 1 tool to do it all? What does everyone think about this all-in-one?
Amazon.com: Autel MaxiTPMS TS501 TPMS Relearn Tool OBD2 Scanner, Upgraded Version of TS408 with Program MX-Sensor, TPMS Diagnostic, Sensor Activation, Key Fob Testing, Relearn by OBD Function Diagnostic Scan Tool: Automotive
johnnymac is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 09:44 PM #72
TommyG's Avatar
TommyG TommyG is offline
TommyG is on a distinguished road
TommyG's Avatar
Embrace your TPMS.
Here's a Scangauge2 programmed for 4Runner tire pressures.
It also has a fifth reading for your spare tire if you equip it with TPMS.
TommyG is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 11:33 PM #73
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Finished this mod faster then a school boy on prom night.
5th gen TPMS disable-c42d2fd7-1a08-45ae-8223-1c48646785cf-jpeg  5th gen TPMS disable-99c2ff1f-e336-4216-bbeb-4db2a997b1ae-jpg
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 02:12 AM #74
tundradan tundradan is offline
tundradan is on a distinguished road
Great Mod!
tundradan is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 12:36 PM #75
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
Even on the 2020 and 21's you still need to read the TPMS tag info and load them into the ECU if you didn't swap your factory ones. Once the tag info is in, you can swap between summer and winter wheels if you wanted and it will automatically find them.
It will not automatically find a new sensor if it wasn't loaded into the ECU. I'm using an ATEQ scanner to do it and it works fine. Then you can handle everything through the dash.
ragin_cajun is offline   Reply With QuoteReply With Quote
TPMS Disable Issue? antjan514 4th Gen T4Rs 0 05-03-2012 11:47 AM
04 runner ltd - TPMS disable shortop 4th Gen T4Rs 1 02-20-2012 12:18 AM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
