Ryan at Eibach
The new coils you are making for the TRD pro 4runner sound awesome, but I feel like you can cut back on the lift maybe .5 inch or so. I'll explain:
1st the increased height would require new rear coils to level it out. Otherwise it will squat.
2nd The TRD pro 4runners already sit a inch higher than stock sr5/trail 4runners, so now you are maxing out the height to the point of almost needing other modifications. (Diff drop, upper control arms, sway bar relocation)
3rd a lot TRD pro owners like there custom tuned fox shocks. Going 1.8 inches higher will surely alter the tunning.
4th if down the line one gets driver side lean which is pretty common, you will be adding even more strain on the frame by adding a leveling spacer.
Regardless, I want to see custom coils made, but would love for them to be a bit shorter for peace of mind.
