02-06-2020, 04:59 PM
#1516
official vendor
official vendor
In other news we have started development on ball joint tubular UCAs
2019 TRD Off Road
2007 GT3
1982 911 SC
02-06-2020, 05:49 PM
#1517
Allow it to fit the Icon Delta joint! (Or come up with something similar for low maintenance and those of us in wet or snowy climates)
02-06-2020, 11:26 PM
#1518
Originally Posted by RusPro17
Thank you I don’t mind waiting. But question on the rear to raise will you still use Eibach rear springs to raise it. I was going to go with the Cornfed spacers but I don’t want to do that and then if I decide to go the Eibach springs. Only want to do this once. Thanks.
I prefer springs over spacers and the Eibach spring is a perfect 1" increase solution for not that much more than spacers.
02-07-2020, 12:01 AM
#1519
Spacers will work also. Just my 02 cents. On my 19 I put the eibach rears in before the fronts. Yes it looked stupid with the rear being way high but what I noticed immediately how they helped road manners, lean around corners etc. truck felt planted.
Eibach is also releasing (no one knows when) rear adjustable springs. My pro and 3/4" drivers side lean so these will level the rear from right to left. also if you plan on towing for a day just crank up the springs and good to go
02-07-2020, 09:25 AM
#1520
uh its called a balljoint, no need to reinvent the wheel and sell an overpriced joint
02-07-2020, 11:54 AM
#1521
I mentioned the Delta joint because it was one of the best.. there are several other options, I just wouldnt want the standard uniballs where I live.
02-07-2020, 02:06 PM
#1522
Soo,,, this will be separate, or available as a kit with the new springs for the TRD_Pro Fox shocks?
Also, HURRY UP AND TAKE MY MONEY!!!!
02-07-2020, 04:12 PM
#1523
Ryan since you've already leaked some other stuff that is in development, when will the customizable pick and choose Pro Truck be available?
- Shocks adjustable from 1" to 3" lift
- A couple different front spring rates
- Rear springs in a couple heights (starting at stock) and a couple spring weights
To save all the extra SKUs, I have left off multiple colors to make your life easier.
If you could have something like that for Monday that'd be great. There's a $12 Fandango gift card with your name on it!
Her, Him & The Moose (RIP Moose 2010-2020) - Adventure bound
2018 TRD Off Road - First 4Runner!
@mooset4r on Instagram
02-07-2020, 05:07 PM
#1524
official vendor
official vendor
Everything you mentioned is in the works except for custom colors. That will never happen
2019 TRD Off Road
2007 GT3
1982 911 SC
02-07-2020, 05:18 PM
#1525
[Jack Sparrow] Aha! So we've established my proposal is sound in principle, now we're just haggling over price. [/Jack Sparrow]
The Eibach "Grow As You Go" kit is an 11/10 winner and we're willing to start a change.org petition to make the owners name it after you.
02-07-2020, 09:52 PM
#1526
Real Name: Kirk
Real Name: Kirk
DANG IT!!! a day late and $$$ short. Wonder if it is too late to return my, as yet uninstalled, SPC's....
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
02-08-2020, 07:43 PM
#1527
An adjustable REAR coilover as a complete bolt-on suspension system that replaced the rear springs and shocks would be off the charts slick. 4-corner adjustment!
02-08-2020, 09:13 PM
#1528
official vendor
official vendor
We’ve been talking about that in this thread for months. It’s 4 weeks out at this point
2019 TRD Off Road
2007 GT3
1982 911 SC
02-08-2020, 10:54 PM
#1529
@ Ryan
i need some info before ordering
can you please explain what would be the differences between using your pro truck lift kit with or with out the springs thanks
18 FunRunner
02-09-2020, 01:29 PM
#1530
Banned
Real Name: Tobias Fünke
Banned
Hi Ryan,
Idk if you have been following all the fun I have been having with my Dobinsons lift. But, long story short I think I want to order the pro kit front shocks and coils.
I have to pull my suspension apart for the 3rd time. If it looks like the coils they are swapping (Warranty) are the same length, I can not waste anymore of my life, and put the eibach stuff in it’a place.
Assuming they correct the issue what’s the return policy?
