02-21-2020, 12:27 PM
#1561
Real Name: Kirk
Real Name: Kirk
Originally Posted by Ryan at Eibach
And here our first TRD Pro lifted with factory fox shocks! I'm pretty stoked on this kit. It really brings the PRO to life.
This is about 1.6" of lift in the front and 1" in rear. You'll be able to buy this as a four spring kit or just the fronts if you wish. Pricing TBD.
Looks GREAT! Also, just looking at the pic, 33's appear to work with very little effort...especially with the stock wheels.
Would the new "Adjustable Rear set" be available with the front springs...as a package....please?
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
02-21-2020, 12:51 PM
#1562
Real Name: Don
Real Name: Don
Lift
Hey Ryan,
Question on comparing this lift. So by using your fox suspension and changing the coils the front and rear out. So it will lift the pro 1.6 higher in the front and 1 inch higher in the rear correct. Is that making the pro higher then it is already? Comparing to guys using the Cornfed spacers 2/1.5.
02-21-2020, 12:59 PM
#1563
official vendor
official vendor
Originally Posted by RusPro17
Hey Ryan,
It's YOUR Fox suspension, which is already on YOUR 4runner.
Yes, if you lift the PRO 1.6" in front and 1" in rear it makes it higher than it is from the dealer.
2019 TRD Off Road
2007 GT3
1982 911 SC
02-21-2020, 01:08 PM
#1564
Real Name: J
Real Name: J
@ Ryan at Eibach
Are the springs ready to go or still in R&D?
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
02-21-2020, 01:12 PM
#1565
Real Name: Don
Real Name: Don
Thanks Ryan, Just making sure Incase I decide to wait for these springs instead of doing the Cornfed spacer lift.
02-21-2020, 04:20 PM
#1566
Hey Ryan,
Let's say I paired those new Pro coils with some Eibach Adjustable front shocks and set the clip to 0" (this is for my SR5 4x4). Would I get a 1.6" lift from the coils?
02-21-2020, 04:43 PM
#1567
official vendor
official vendor
Originally Posted by nimby
Hey Ryan,
The springs we are discussing right now only fit an OE Fox PRO shock.
2019 TRD Off Road
2007 GT3
1982 911 SC
02-21-2020, 07:36 PM
#1568
Looks great!
Did you take hub to fender measurements by chance?
02-22-2020, 01:59 PM
#1569
Curious...what color is that trd pro in the pic? Looks like cement but has the 19+ roof rack. Guess it’s white?
02-22-2020, 04:59 PM
#1570
Its definitely Cement with a 19/20 rack.
02-22-2020, 11:16 PM
#1571
Or a 19/20 with a cement wrap.
02-23-2020, 09:35 AM
#1572
TRD Pro Fox Shock Clunk
Seeing the complaints in the above thread about the Pro with Fox Shocks making loud Clunking sounds in cold weather - makes me like my OR with Eibach Springs and Eibach Shocks even more.
Ryan - when you start getting complaints of noises by Fox Shock owners, you might keep the above thread in mind.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
02-23-2020, 09:50 AM
#1573
not to be a complete asz, but the fox shocks and the shocks ryan sells aren't apples to apples. that thread is dumb i agree lol
02-23-2020, 04:53 PM
#1574
Anyone replace the rear springs with a heavier rate 2" lift? Im leaning toward the dobinson 220lbs but not sure if its enough. I've read that the eibach springs are 206lbs in the rear. Otherwise I'd be going with the 271lbs dobinsons.
I've had the pro kit since about summertime last year and will be putting on a roof rack and RTT soon so it has me a little concerned with all the extra weight. I noticed some slight sagging in the rear when loading up the trunk with wood/water and all my camp equipment for a 3 day trip in winter.
Hey Ryan, any new ETA on the adjustable rear springs? Will upgrading to different rear springs affect the geometry too much with the pro kit shocks?
02-24-2020, 01:26 AM
#1575
Curious about the center hub to fender measurements as well. Stock pro is about 20.75, so technically these new coils should be 22.35
