Originally Posted by ForRun
Pro 2 coilovers. Sadly be a couple weeks till I can get them in.
Ryan, any idea what these are set right out the box?
Just an update with the stage 2. The shop had a hell of a time with these, pulled them and adjusted them 6 times now and they still are not right. Got home and passenger was 1/2" higher.
I called Eibach and talked to tech support and they told me something completely different than they told my shop. Told shop to adjust and test where it sits. Problem is you need to pull the strut each time.
I called Eibach and they tracked down the R&D guy who knows about these and this is what I was told.---- need to release the preload, said I should be able to compress the spring on the rig while it's jacked up. Then said 12 turns =1" of lift or 3 turns for 1/4". Perfect, I run to harbor freight and get the spring compressor for 30bucks....it don't fit on the coils. Maybe they sell coil compressor that will fit while installed???
What did I find out? Jacked the rig up to attempt the adjustment and since could do nothing put the tire on and done. I measured before and again afterwards. Just jacking it up and lowering it, not driving the rig raised the whole damn front 3/4". I can only recommend set the damn things, forget the alignment and put a few hundred miles and hope they settle. No wonder shop had a hard time, they move every time he lifted it up....without adjustment. Next is the 12 threads per inch theroy. My shop left them at 7 threads from the bottom. One side got 1.5" the other 2".....so much for the 12 threads per inch. Will report back in a few hundred miles. Anyone else, please report back findings, I really want to know if mine are ****ed up or if they simply need to settle.
Edit- I've read so much that for true measurements check at 1/2 tank of gas. After giving up the the day, had 1/4 tank. went to the gas station and measured before and after being a full tank. The measurements were identical, adding gas did nothing. Also the eibach rear springs got 1.5" lift, not the advertised 1"...maybe they will settle 1/2" ?
