Thread Tools Rating: Thread Rating: 28 votes, 3.57 average. Display Modes
Old 10-28-2020, 02:14 PM #2071
mark@eibach's Avatar
mark@eibach mark@eibach is offline
mark@eibach will become famous soon enough
Originally Posted by blackened_offroad View Post
you just did a stock kit? What's up with some people getting a positive rake and some getting negative?
A lot of this is contingent on where people put their front clip heights. I didn't see where JohnDoh put his.
2014 TRD OR, DCSB: Eibach / Magnuson / Nitto / WARN / ARB / Hella / Fifteen52 / Dirt King / Pelfreybilt / Autometer / Pelican / Switchpros
mark@eibach is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 02:31 PM #2072
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
so what do you need to do to end up with it flat or a positive rake? I absolutely do not want a negative rake. It's an incredibly amateur redneck look.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 05:53 PM #2073
Different strokes for different folks.
Some people prefer the pre-runner look, but when we develop our kits we're shooting for a level look. There are production variances, wear and tear, etc which effect heights so we test multiple vehicles, take our averages and finalize from there.
If you want a positive rake and are planning on extra weight, I would suggest bottom clip with our rear springs. If you are not running third row seats, and don't have any additional weight, second clip should get you approximately level. The 5th gen is a big challenge aesthetically as the rockers and fender arches cause the whole vehicle to look reverse rake despite measurements being taller in the rear.
Old 10-28-2020, 07:42 PM #2074
on an actual prerunner/trophy truck with the bodywork and long travel suspension is fine. Retail market passenger vehicles, whether SUV or truck, with a reverse rake look like shit. More accurately, they look like a dog trying to take a shit. My town is full of trucks with huge rims, low aspect ratio tires, and like 6" of reverse rake. Quite possibly the worst "customized" vehicle trend anyone has ever come up with.
anyway. with the clips in the correct positions to assure no reverse rake, what size tires fit under there on an otherwise stock vehicle?
Old 10-28-2020, 08:02 PM #2075
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
^this. I took a laser level to mine and a level 4runner can look nose high.
Another thing to consider, I have a marked spot in my garage I measure from to see where its at. I have parked in 4 different spots and get 4 different measurements on the same day
ForRun is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 10:04 PM #2076
scoplnr scoplnr is offline
Real Name: scott
scoplnr is on a distinguished road
Real Name: scott
Sorry to beat this to death, but back on pg 29 someone is saying the exact opposite per Eibach's recommendation. He said the second to the lowest because he had a winch and bumper and if there was no additional weight then use the lowest setting. I do run a RTT and camping gear and don't want the reverse rake.
scoplnr is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 09:19 AM #2077
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
The 5th gen has about a 1.75" difference between the front and rear height (SR5 and OR).
With the Eibach kit, their front lift coil is 1.75" higher than their rear lift coil.
If you want your truck level (assuming you have no additional weight), put the coil on the lowest setting (0").
If you want to retain some factory rake, you can:
add a spacer to the rear
-or-
get a taller rear coil
-or-
get the Eibach load leveling system for the rear so you can dial in your lift height.
nimby is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 09:26 AM #2078
nimby's Avatar
nimby's Avatar
Originally Posted by ttravv View Post
Here’s my lift. Not gonna lie... there is a slight reverse rake... but I’m not terribly OCD, and it doesn’t really bother me
This picture is deceiving because your horizon is crooked, making the front end look higher than it is. Take a look at your roof line compared to the top of the garage door behind it. It looks level with that line.
Have you measured from the center of hub to the bottom of fender on level ground? If so, what did you get?
Old 10-29-2020, 11:02 AM #2079
This is how we measure as well.
Old 10-29-2020, 11:07 AM #2080
I don't think this is the opposite of what we recommend.
He's got additional weight on the front and wanted it close to level, so he moved the perch to the second clip to accommodate for the extra weight and give him a more level look.
In your scenario, the first clip would yield the results you're looking for because you're loading the center/rear of the vehicle with no additional weight over the front axle.
This all being said, our HD rear springs have been test fit and are getting final revisions made before being sent to production. Once approved we'll be looking at about 8-12 weeks for production. I would estimate late January/ early February considering Holiday schedules.
Old 10-29-2020, 01:05 PM #2081
JasonXP JasonXP is offline
JasonXP is on a distinguished road
Could someone tell me what the final height of their 4runner is with the lift kit and 285s (specifically the KO2s)? Some of the parking decks here in the city are 76".
JasonXP is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 04:41 PM #2082
BEAR x SF's Avatar
BEAR x SF BEAR x SF is offline
BEAR x SF will become famous soon enough BEAR x SF will become famous soon enough
BEAR x SF's Avatar
Update on the stage 1 kit, when I installed the kit I did the recommended front setting at the first clip thinking it would be more than enough but added a half inch cornfed spacer to the rear to get 1.5" in the rear but ended up with 2" instead. That resulted in a factory looking rake but lifted and wish I had done the second clip instead. I waited a few weeks to see if the rear would settle and it stayed the same. I was preparing for bigger tires from 265's so when I went to a shop to have my bmc done and I also had them change the clip setting. I had the second clip in mind but they encouraged the third clip instead as a buy once cry once and said f*** it let's do it (thanks stellar built) and I was also going to upgrade UCA's anyway. Long story short, the rig looked exactly how I envisioned it when I first installed the lift after changing it to the third clip. Factory looking rake is gone and is completely leveled for now until I start adding weight to the front.
BEAR x SF is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 06:34 PM #2083
ttravv ttravv is offline
ttravv is on a distinguished road
After placing on my SCS wheels. I’ve noticed a more predominant amount of reverse rake. It’s actually kind of bother me now. I think I’m going to have to opt to get rear spacers. I’ll drive it a few more hundred miles to see if it’ll settle.
And yes you’re right. The photos don’t do justice, you have to see in person.
I’ll measure it soon when I have time
ttravv is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 08:34 PM #2084
RedRunner15's Avatar
RedRunner15 RedRunner15 is offline
RedRunner15 is on a distinguished road
So I’m about to install the Eibach pro truck kit on my limited. I’m wondering what would happen if I add a 1 inch cornfed spacers to the rear. I have third row, would it be level or would it give me some rake? I don’t want reverse rake.
RedRunner15 is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 09:29 PM #2085
nimby's Avatar
nimby's Avatar
Limiteds don't sit 1.75" lower in the front than the back, right?
Best to take a tape measure and measure from the middle of your hub to fender both front and back. If the front is more than 1.75" lower than the rear, you'll retain a small amount of factory rake.
If the front is less than 1.75" lower than the rear, you'll sit nose high. If this is the case, your measurements will determine how big your spacer needs to be.
Anyone running Eibach Pro-Truck Shocks with lift? DeepSea 5th gen T4Rs 9 05-07-2019 10:39 AM
Eibach Pro-Truck Sport Shock Review (4th Gen) Rannd 4th Gen T4Rs 13 09-14-2018 12:24 AM
Eibach Pro-Truck Shocks, any experience with them? rich045 4th Gen T4Rs 18 06-23-2018 02:59 AM
Eibach Pro-Truck Sport Shocks (Leveling Kit) OC4X4 5th gen T4Rs 6 07-09-2017 01:12 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
