Thread Tools Rating: Thread Rating: 26 votes, 3.46 average. Display Modes
Old 01-07-2021, 04:41 PM #2146
DSRunner DSRunner is online now
DSRunner is on a distinguished road
Originally Posted by mark@eibach View Post
Are you both running our spring in the rear?
I am not. I'm using the ICON 2" for the rears.
DSRunner is online now   Reply With QuoteReply With Quote
Old 01-07-2021, 05:04 PM #2147
mark@eibach's Avatar
mark@eibach mark@eibach is offline
mark@eibach will become famous soon enough
We call out a 1" lift for our our rear spring, so using an Icon 2" will certainly be more lift in the rear.
2014 TRD OR, DCSB: Eibach / Magnuson / Nitto / WARN / ARB / Hella / Fifteen52 / Dirt King / Pelfreybilt / Autometer / Pelican / Switchpros
mark@eibach is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 05:28 PM #2148
Thanks Mark. I think you might be getting me mixed up with @daesonn who was disappointed about his/her rake. I'm happy with the 2" lift I got in the rear but the issue was with my front lift. I'm only getting 2" (driver front) & 1.75" (driver passenger) with the Eibach Pro Truck coil & struts. I was hoping to get 2.75".
Old 01-07-2021, 05:59 PM #2149
Ah, sorry about that you're right!
Old 01-11-2021, 07:05 AM #2150
4251craigt 4251craigt is offline
4251craigt is on a distinguished road
Doesn’t make sense... it’s a 2.75 front lift , how are you only getting 2 & 1.75...?
4251craigt is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 03:47 PM #2151
I did some more measuring this weekend. To account for differences due to slight slopes, I took multiple measurements. My driver side ranged from 1.75" - 2" of lift and passenger side ranged from 2.25" - 2.5" depending on the direction I parked. Talked to Dave from Eibach and he mentioned its likely due to my higher rear 2" Icon coil (compared to the 1" Eibach coil) shifting the more weight to the front. That makes sense to me but didn't realize it would make that much of a difference. Anyways, I ended up ordering some top plate spacers to get me closer to 2.75".
Old 01-12-2021, 02:57 PM #2152
Runnin4MO Runnin4MO is offline
Runnin4MO is on a distinguished road
Originally Posted by 4Runnin4Fun View Post
I had the same assumption, bottom clip to eliminate factory rake. I called Eibach and spoke to an engineer, he explained that I should probably use the second clip to eliminate factory rake and the third if you have added weight up front.
When and who did you speak to at Eibach? I called them 2 weeks ago and got this response...
When I spoke with Eibach they said a lot of folks with no added weight choose to place it on the 2nd clip right from the start and are very happy with the height. I on the other hand have an extra 220#going up front and said I will definitely need to be on the 2nd clip anyway. I asked, will I need to go to the 3rd clip because I want to sit right at 3"with all the weight, he said it will sit at about 2.9"with that weight on the 2nd clip.... If I go to the third it will effect the handling to much.
Mark, can you verify what clip to put the fronts on to get almost 3" WITH an added 220# bumper and 90# full roof rack? We're getting conflicting info from Eibach support.
Thanks!
Runnin4MO is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 08:42 PM #2153
Thanks!
This is rough, but if you take the 220 / 2 you get load per corner. Then take the 90 / 4 you get 22.5 roof rack per corner. SO your total added weight to each front spring is 132.5.
If your spring is 650lbin. it takes 650lb to compress the spring 1 inch. Now divide 650 by 132.5 and you get 0.2, so approximately 1/4" compression at the spring. I don't have the motion ratio in front of me though, so its hard to say what that looks like at the fender well.
Old 01-13-2021, 12:10 AM #2154
biratley biratley is offline
biratley is on a distinguished road
How much will ride comfort and travel be affected by going to the 2nd or 3rd perch
Sent from my iPhone using Tapatalk Pro
biratley is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 03:41 PM #2155
As long as the shock at rest is not in the top-out zone then ride comfort should not be effected. We designed the damper to function within the 2.75" height range so provided you are around that range at static you'll retain the same amount of up and down travel. If anything, the additional weight will make it slightly more compliant then rigs with no weight on the front.
Old 01-13-2021, 07:00 PM #2156
thomas1 thomas1 is offline
thomas1 is on a distinguished road
Originally Posted by PCMSF View Post
Just got off the phone with Eibach, thanks for talking me through everything, Kevin @ Eibach! Super helpful.
With the sale going on, just ordered the Eibach Coilover 2.0 System instead of the Stage 1. Preassembled saves me shop labor and I like how adjustable it is and I can go lower in front.
Anyone running this system?
I did exactly the same. Have you gotten any updates on delivery? I was told in December parts were on backorder and they expected to ship in January. Emailed last week and was told parts were in and kits would be going out early this week. Called today and was told parts were backordered and weren't due in until 2/26.
Maybe Mark knows something different?
thomas1 is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 08:45 PM #2157
bear1998 bear1998 is offline
Real Name: Bryan
bear1998 is on a distinguished road
Real Name: Bryan
I ordered the Pro Truck Lift Kit from Wheelers....first i was told mid January...now im told early to mid February....if its not shipped by the 15 th of February...im cancelling my order n getting my money back...going to another manufacturer.
This is BULLSHIT!!!
bear1998 is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 09:06 PM #2158
Eibach Pro-truck lift
This is BULLSHIT!!!
Good luck with that , almost all manufactures are on backorder #covid
Old 01-13-2021, 09:13 PM #2159
Real Name: Bryan
Real Name: Bryan
I can understand the backorders...but to keep putting back shipping dates is not right. Seema like bait n switch.
If the world would stop tomorrow...im sure it would be covid
Old 01-13-2021, 09:24 PM #2160
This is BULLSHIT!!!
I ordered directly through Eibach, I don’t think they charge you until the product ships.
Anyone running Eibach Pro-Truck Shocks with lift? DeepSea 5th gen T4Rs 9 05-07-2019 10:39 AM
Eibach Pro-Truck Sport Shock Review (4th Gen) Rannd 4th Gen T4Rs 13 09-14-2018 12:24 AM
Eibach Pro-Truck Shocks, any experience with them? rich045 4th Gen T4Rs 18 06-23-2018 02:59 AM
Eibach Pro-Truck Sport Shocks (Leveling Kit) OC4X4 5th gen T4Rs 6 07-09-2017 01:12 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
