04-03-2019, 07:32 PM
#376
Originally Posted by northcoast
Are you certain the lower spring perches on your front suspension are correctly oriented? Sometimes people put them in upside down and it gives the vehicle more lift in the front than intended.
04-03-2019, 07:36 PM
#377
If it doesn't improve, I'll have them check again. Like I said, I'm a bit new to all of this, so I have to go at their word.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
04-03-2019, 09:21 PM
#378
official vendor
official vendor
Yes, this is common. Get a pic of the bottom of the front springs.
2019 TRD Off Road
2007 GT3
1982 911 SC
04-03-2019, 09:37 PM
#379
The rear is lifted 1" with the kit, and supposedly, the goal of the kit is to lift and level. I'll give it some time to settle. We're on the lowest setting in the front.
Where was the snap ring set? When I received mine it was set higher for added weight. Took me more time then I care to mention to figure it out. The instructions kind of contradict each other.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
04-03-2019, 09:44 PM
#380
I will do so when I get better light. FWIW, the Eibach label printed on both front springs is right side up, if that matters. Does that, by chance, indicate if it's correct?
Edit: I just looked at the instructions online, and they indeed say that the logo on the springs should be right side up, so we should be good there.
04-03-2019, 09:45 PM
#381
It's set on the lowest, confirmed.
04-03-2019, 11:42 PM
#382
For those comparing Falken Wildpeak's with BFG KO2's:
275/70/17 Falken C = 57.1 lbs
285/70/17 Falken E = 58.9 lbs
285/70/17 Falken P = 50.5 lbs
275/70/17 KO2 E = 55.18 lbs
285/70/17 KO2 C = 50.33 lbs
285/70/17 KO2 E = 57.87 lbs
2014 SR5 4x4, TRD skid plate, TRD Pro black wheels, Toyota OEM LED Fogs (black), black logo overlays, Eibach Pro Truck Lift Kit, 285/70/17 KO2's.
04-04-2019, 01:23 PM
#384
Right on! Just ordered. Will worry who will install it later
04-04-2019, 02:21 PM
#385
official vendor
official vendor
down to 6 kits..wow!
2019 TRD Off Road
2007 GT3
1982 911 SC
04-04-2019, 03:55 PM
#386
That's not the part I was referring to. When you have a chance, take a picture of the bottom of the spring and how it sits on that plate that is resting on the snap ring. This will tell us if that plate is upside down or not.
04-04-2019, 07:39 PM
#387
Driver's side:
Passenger's side:
04-04-2019, 07:54 PM
#388
Confirmed, your lower spring perches are 100% upside down. Also, the ball joint looks damaged (ball joint could just be bad picture).
04-04-2019, 08:24 PM
#389
Was that a new kit installed? Looks like they beat the hell out of it.
04-04-2019, 08:59 PM
#390
Dropping it off tomorrow morning. Appreciate all the help. Hopefully this will have a good outcome.
